BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BM3 vs MHD - All Aspects
proTUNING Freaks
      01-14-2019, 09:33 PM   #23
bimmerace
Drives: F30 335i xDrive M-Sport
Thanks guys, this was very helpful. Does anyone have Dyno results for both for WHP/WTQ comparisons? Also, I heard one of these two was coming up with the X-Drive to RWD hack like xHP is, any ideas on who it was? I was so deep into a forum that I can't remember which one it was!
      01-14-2019, 09:40 PM   #24
FastF30
FastF30's Avatar
521
You can't go by dyno... all dyno's read different... MHD has the Torque clutch Nm's on it's logging but until BM3 get's it there is no other true way of comparing unless you test same car same day same time same etc, etc................ besides if your so stuck up on max hp then your gonna get a custom tune anyways...
ceedawg467.50
harkes1077.00
      01-19-2019, 04:50 AM   #25
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Originally Posted by ronanz View Post
Very true. But to be fair, VAST majority of issues were/are user related...not platform related.
FACTS!!!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      01-20-2019, 06:28 AM   #26
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Originally Posted by nawfoo View Post
Not a complaint but after I flashed my BM3 stage 1 91 octane I lost the ability to auto start/stop. guess its supposed to keep the car cooler after stage 1.
I don't think BM3 does anything that messes with auto start/stop.
      01-20-2019, 08:11 AM   #27
Korvo
Respect My Authoritah
Korvo's Avatar
Drives: 2014 335i M-Sport
When I flashed BM3, I noticed that my sport gauges go higher. I also think that while this change was made, my LED settings were reset. I swapped them and got an error last night. Will have to use BimmerCode to check and see if BM3 messes with any settings.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
      01-20-2019, 09:34 AM   #28
KC Bimmer
Drives: 2013 335i xdrive
So I’m currently FBO running JB4 only and looking at adding PS2 here soon. So if I understand correctly it sounds like both BM3 and MHD have PS2 maps I can use and could ditch the JB4, right? I’m contemplating additional fueling via WMI for which I’d need to use JB4. If that route is JB4 with MHD and BEF still the only option? A little concerned getting that one dialed in correctly as I’d like an option if possible that I wouldn’t need to run logs regularly as this is my DD. Also looks like BM3 has PS2 with XDFI 35 map option. That costs more but might be easier to set the tune and have consistency. Thoughts?
      01-20-2019, 10:07 AM   #29
insane11
Drives: 435i GC
Bm3 doesn't have ps2 map.. I'm running ps2 with the xdi pump on Bm3 with custom map.
      01-20-2019, 10:28 AM   #30
KC Bimmer
Ok, good to know. Their site says additional maps available for upgraded turbos. So which turbos are supported? Stage 1 only?
How do you like your setup? Pros/cons? Thanks
      01-20-2019, 01:39 PM   #31
insane11
Drives: 435i GC
you can run stage 2 map on ps2 but custom tune is better to maximize the ps2.
      01-20-2019, 03:32 PM   #32
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
Originally Posted by Martin.328 View Post
Best thing about mhd is that evetything is done through your phone. You dont need anything else other than the cable.
When I was doing my research this was a huge plus for me as I have an Android phone. When I had a JB4 having to have a laptop in the car was burdensome. I keep the cable in the glovebox and when ever I want to do anything I just whip out my phone and its easy.
Last car: 2011 335i Msport. JB4. Vrsf CP
      01-20-2019, 05:21 PM   #33
newyork326
Drives: 2015 335 M Sport X Drive
It was pretty cold last night and I guess I didn't drive the car much. Drove it today and the auto start / stop came back.
So I am going to be pulling the trigger on BM3 but can someone enlighten me on the after the fact costs that are going to come along with this? I understand you get one free time with the initial 600 bucks. What is the cost of additional OTS tunes? What is the cost to have a custom time done?
      01-20-2019, 05:36 PM   #34
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
I'd suggest purchasing the "Map Bundle" for the additional $50 as it'll include all stage variations including E30
Custom tune pricing is set by the tuner, I'd suggest contacting tuner directly for pricing
My Build Thread can be found HERE
      01-21-2019, 02:22 AM   #35
harkes
harkes's Avatar
China
1077
Drives: M135i, E39 M5, NSX and AE86
I have run BM3 for the last two years and recently switched to MHD. ONLY reason being that the support for PWG is better with MHD and that my tuner prefer this platform.
BM3:
+ Huge OTS base
+ Resell value
+ Self tune - if you dare :P
+ Flash times (not including connecting to agent and logging in)
+ Cloud based operation, everything is accessible from everywhere
- Agent (a F-ing pain to work with in almost all aspects )
- Lack of PWG tuners
- Buggy (new platform so to be expected)
MHD
+ Simple app, feels very solid
+ PWG support
+ Huge tuner base
+ In app log reader
+ Connect directly to OBD
+ Logging features like ign retard and clutch torque
- Longer flash times (~5min for map change with slow cable)
- Upload to Datazap to have access to logs
- No cloud so backup is recommended
I am 99% sure the same can be achieved on both platforms with a custom tune. My guess is that the BM3 OTS is more powerful.
(A Dane in China)
aps335.50
      01-21-2019, 03:05 AM   #36
bradsm87
Australia
595
Drives: F25 LCI xDrive30d
BM3:
+ Huge OTS base
+ Resell value
MHD
+ PWG support
+ Huge tuner base
+ In app log reader
You can self tune with MHD as the backup and flash tool. You just use the free TunerPro XDF definitions in order to use TunerPro to tune.
When you say PWG support, probably more correct is that MHD may be quicker to bring in OTS map updates. When it comes to new ROM support, unfortunately, they are slower. If you went from BM3 to MHD, you actually would have been downgraded from a 2018 ROM to a 2016 ROM.
      01-21-2019, 03:58 AM   #37
harkes
harkes's Avatar
China
1077
I am aware of the ROM "downgrade". My car was born in 2012 so no matter both are an upgrade and it drove just fine on the 2012 version
(A Dane in China)
      01-21-2019, 04:12 AM   #38
bradsm87
Australia
595
I-Step update is one of the best things you can do to these cars!
They drive "just fine" stock but we still tune them don't we?
Car enthusiasts - When "just fine" isn't enough.
      01-21-2019, 11:49 AM   #39
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
bm3 has a PS2 map for N55 PWG, not EWG. I'm not sure why but the map for PS2 is Stage 2H if you have PWG.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      01-22-2019, 10:12 AM   #40
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Originally Posted by FSociety View Post
Last but not least, check how there's barely any MHD Results on Dragy ;-) and if there is they're much slower than BM3 OTS
Anyone in Tri-State can msg me if they want to compare with some BM3 cars as there's barely any MHD willing to go to Mexico. All for fun enjoy !
Aren't all the OTS maps free now?
      01-25-2019, 12:46 PM   #41
bimmerace
Now that we know some of the differences with pros and cons, does anybody have any of these tunes at high altitudes? I constantly go from 11k down to 5k ft., back and forth. The Jb4 freezes (stops responding) constantly and causes the car to go into limp mode until I restart the car, in the middle of this drive.
      01-25-2019, 04:12 PM   #42
harkes
harkes's Avatar
China
1077
JB4 is not a proper tune. I also used it for 3 years on my M135i and it was 24/7 work to keep it running optimally. JB4 is boost based as opposed to a flash tune that SHOULD be load based (not all are). A load based tune will in/decrease boost depending on altitude so you always get the same performance.
(A Dane in China)
      01-25-2019, 04:52 PM   #43
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
I live at 3200 ft, drive up to 5,500ft through the mountains. Never had an issue with BM3.
      01-26-2019, 12:33 PM   #44
ronanz
ronanz's Avatar
Same here, I’ve travelled in and around the Rocky Mountains and Utah...have gone anywhere from 2000’ to 10,000’ with zero bm3/tune related issues
However, I have experienced misfires at high altitude in which a plug change resolved.
