06-29-2021, 08:52 PM | #1 |
Rep 188
Twice today while making my way home from work, I experienced brief hesitation while under WOT. On one occasion I was in 4th gear, the other in 5th. Both times it happened, at some point as I climbed RPMs there was a short pause in acceleration and I could hear the BOV release. Otherwise it pulled strong, no stuttering anywhere.
Last week I changed plugs, I did coils last time. Car idles smooth and feels great. I haven't had a chance to pull logs yet but intend to sometime this week. Just wanted to get this out there to see what comes to mind before I can provide data. -z '15 435i MHD Stage2
2015 M-Sport 435i xDrive (6MT)
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S |
07-01-2021, 10:45 AM | #2 |
Rep 562
Drives: 2017 BMW 330i xDrive
Gonna need to pull codes and run those logs to get anything definitive. To me, it sounds like the car ran into some issues with knock and had to pull back the timing. I'd avoid pushing the car until you can run the logs and check for codes.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
10-03-2021, 07:29 AM | #4 | |
Rep 188
The problem is still noticeable, although I have tried not to push it. I changed plugs a couple months ago, I had replaced coils the last time, about 25k miles ago. I will use Bimmetlink for logs, any readings in particular I should target?
10-04-2021, 09:22 PM | #5 | |
Rep 7,602
07-22-2022, 07:25 AM | #6 |
Rep 5
Similar issue for me just after buying my used 2013 328i xDrive. Previous owner had just changed coils and plugs. Found that one of the plugs had a hairline crack. Replaced plug and it resolved the issue.
08-07-2022, 03:29 PM | #7 |
Rep 188
I have not been able to reproduce my issue. I have since learned the "don't do" of going WOT at lower RPMs which, in hindsight, is probably what was happening. Should have been downshifting instead of just flooring it.
While mine has not been terriby helpful in your case, I'm glad you were able to resolve your issue.
