10-08-2021, 09:18 PM | #1 |
Rep 107
With MHD flash what do you monitor?
I have a 2014 435i on MHD stage 2+. I was just curious what does everyone monitor live while driving?
2014 435i/VRSF CATLESS DP/AWE MIDPIPE&EXHAUST/VRSF CHARGE PIPE/BMS INTERCOOLER/TURBOSMART BOV/INJEN INTAKE/MHD STAGE2+ Last edited by boosted14; 10-09-2021 at 05:08 AM.. Reason: clarification |
10-09-2021, 12:33 AM | #2 |
Rep 7,591
10-09-2021, 05:05 AM | #3 |
Rep 107
i will edit the title of the thread. im not talking about what you monitor for data logs, im asking what different people monitor live while driving in which that thread is useless to the question asked.
2014 435i/VRSF CATLESS DP/AWE MIDPIPE&EXHAUST/VRSF CHARGE PIPE/BMS INTERCOOLER/TURBOSMART BOV/INJEN INTAKE/MHD STAGE2+ |
10-10-2021, 06:03 AM | #4 |
Rep 70
I usually monitor boost, intake temp, coolant temp, and oil temp. I have others on the screen, but most are too dynamic to serve much purpose as a gauge. It would be nice to have an indication for knock detection, but again it is very dynamic. You could theoretically log all of the cylinders ignition timing and look for retardation, but that would be pretty difficult while driving.
10-10-2021, 08:35 PM | #5 |
Rep 107
Thank you for your reply. I monitor:
Boost coolant temp oil temp oil pressure throttle position fuel rail pressure boost target gear Im just trying to get a sense of what others monitor.
10-10-2021, 08:45 PM | #6 |
Rep 2,354
You dont need to monitor anything. Keep your eyes on the road - please.
(A Dane in China) |
10-10-2021, 09:07 PM | #7 |
Rep 107
I can multi task
10-10-2021, 10:42 PM | #8 |
Rep 2,354
Just out of curiosity - why do you want to monitor?
(A Dane in China) |
10-10-2021, 11:28 PM | #9 |
Rep 107
So I can see a problem approaching before it gets bad. I don't want to rely on a sensor alert to happen by that time its usually a worse problem than if i could see it coming.
10-10-2021, 11:37 PM | #10 |
Rep 107
My phone is on a window mount that sits between my dash cluster and my nav screen so its in eyeline so i can still watch the road. I also have the mhd adapter linked to my phone with a private IP address so i can still use cellular service to use maps, texts, or calls.
10-11-2021, 02:36 AM | #11 | |
Rep 2,354
Personally I only use oil temp (when is the oil hot enough for WOT) and STFT (is WMI working correctly). And only during logging sessions.
(A Dane in China) |
10-11-2021, 03:25 AM | #12 |
Rep 107
I'm still learning. lol
10-11-2021, 03:55 AM | #13 |
Rep 2,354
Great - we all started from scratch. In terms of engine damage prevention I would show IAT and oil temp then. Dont go WOT if oil temp is too low or if IAT is very high as this will increase the risk of knock - but again - the DME has already got this figured out with timing tabels to compensate for high IAT... So really you dont need to monitor anything
(A Dane in China) |
10-11-2021, 05:38 AM | #14 |
Rep 107
I appreciate all your feed back and yes it does look cooler with more gages!
10-11-2021, 11:01 AM | #15 |
Rep 7,591
Here's my monitoring from top to bottom, left to right:
Boost mani - Boost target IAT - Throttle position Rail pres mean - Rail pres Req Trans temp - coolant temp There's no reason to put oil temp because its on the dash, and if its below 160 its too cold anyways. You also don't need gear because XHP shows that on the center display. These gauges are more for making sure you (1) dont have boost leaks and (2) didn't overshoot ethanol content. Sort of like debugging gauges. Pair relevant gauges next to eachother - if you cant see boost and target at the same time its kindof pointless. If i am driving hard canyons/AutoX, move IAT, trans temp, and coolant temp up toward the top (or whatever is easiest to see) and swap boost target with oil pressure. |
10-11-2021, 12:41 PM | #16 |
1296
Rep 3,529
gear actual and ltft are the only things I monitor real time. those are the only things that are important in the moment.
10-11-2021, 07:56 PM | #17 |
Rep 107
I don't think my car shows what gear I'm in. I will replace the boost target to something else thank you for that.
10-11-2021, 08:15 PM | #18 |
Rep 7,591
10-11-2021, 09:23 PM | #19 |
Rep 107
Ill have to check that out then
