06-27-2017, 09:07 AM | #23 |
Rep 71
In most cases, staggered wheels is just a difference in width, having the rear wheels/tires wider than the front. For a while there, like in the case of the 330ci, they would +1 size the rear wheel. This shouldn't affect this as long as the overall diameter remains the same. Example: (225/45ZR17 F, and 225/40ZR18 R)
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler 1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress. |
06-27-2017, 11:56 AM | #24 |
Rep 1,805
49K Transfer case blew on mine for the 2nd time (1st time at around 32K)
$5,000 repair covered under warranty. Lots of hesitation during acceleration.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
rocksnap19.50 |
06-27-2017, 12:27 PM | #25 |
Rep 1,076
06-27-2017, 01:16 PM | #26 |
Rep 474
Drives: 2014 328D xDrive
07-03-2017, 11:12 PM | #27 |
Rep 29
Update of my post of 500 miles ago
Transfer Case was replaced under warrantee @ 41,000 miles. No computer codes were thrown. Just me noticing some very subtle issues with the drivability. When going thru a medium sized corner and under low/mid acceleration, I could feel the car doing a "stutter". Disconnect the TC, the issue went away. It seemed to be making a subsonic noise/rumble that was masked by the long on tooth stock tires.
07-05-2017, 07:47 AM | #28 |
Rep 474
Was the noise it was making a rhythmic humming sound? Like on/off, not constant? My car is doing this, thought it was the tires originally but after my last service the noise didn't change any (assuming they rotated tires during service...).
07-05-2017, 03:22 PM | #29 |
Rep 8,942
Mine is creeping up on 60K, had the transfer case and rear diff replaced (under warranty) around 52K
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-11-2017, 07:02 AM | #30 |
Rep 466
07-11-2017, 07:03 AM | #31 |
Rep 466
07-11-2017, 07:08 AM | #32 | |
Rep 466
Trust. You would not want to see or chance that after you feel the wrath of the transfer case bill. Take our advice young grasshopper |
07-11-2017, 07:10 AM | #33 |
Rep 466
So did you have a CEL for the NOX sensors? Mine has been lit up but im not sure which sensor it is. Ive been riding it out till my DEF runs out. I was told it could be the DEF I used since it was close to a year being stored. IDK but ill try it out since the sensors are 600+ each and i dont know which one is triggering it
07-11-2017, 12:41 PM | #34 |
Rep 474
Just broke 50,000 on my 2014; had a wheel hub replaced at 49,600 due to whining noises
(from the hub, not me ) |
07-11-2017, 12:48 PM | #35 |
Rep 3,533
Oh, I have no intention on going staggered (I like being able to rotate my tires and the BMW 405m 18" wheels I have don't have a staggered option). Just wondering what the risk profile looks like for square setups.
07-12-2017, 06:51 PM | #37 | |
SQUEAKY
104
Rep 322
07-12-2017, 07:48 PM | #38 | |
Rep 700
07-16-2017, 09:23 AM | #39 | |
Rep 205
07-16-2017, 09:25 AM | #40 | |
Rep 205
You can take your chances. If it happens to your xdrive, your pocket is not going to be very happy unless you have a lot of cash to burn. I don't... ...and a square setup helps to turn the car better. |
07-24-2017, 07:31 PM | #41 | |
Rep 1,805
How is this any differenent from other staggered setups on x-drive cars? is it a diesel issue?
08-14-2017, 08:39 AM | #42 |
Rep 71
I'm very curious as to how a staggered width set up vs square as it's been put here, can cause failure to the transfer case?
I can completely see a circumference variance causing problems, as it would cause bind on the system. But tire width should have absolutely zero affect on it to the best of my knowledge. Can someone please elaborate?
08-15-2017, 06:39 PM | #43 |
Rep 30
I have 119,XXX miles on my 2014 328d purchased new in December 2013. I have had 3 transfer cases replaced (warranty) at 50k, 90k and 115k. Car left me stranded on the highway each time..Dealer can't explain it but it doesn't seem to be that prevalent on internet searches. Anyway, other than a broken horn, i've done maintenance as CBO suggests. Nothing more, nothing less and runs great.
08-15-2017, 06:59 PM | #44 | |
Rep 1,076
What are your tire sizes? And in what wheels? |
