10-03-2019, 06:56 PM | #23 | |
1288
Rep 3,502
Im an xdrive auto car. And honestly i dont see how the hell its even possible. There are no videos online anywhere that i can find. Im at a complete loss. I have the oan and rack cover off. |
10-04-2019, 12:46 PM | #25 |
1288
Rep 3,502
No, am I supposed to? I havent been able to find any videos or anything much less a good actual write up on what I need to do. Other than... get it from the bottom.
10-04-2019, 12:50 PM | #26 |
Rep 1,115
Are you following this guide? The water pump might only be necessary if you're doing the diverter valve at the same time.
https://www.2addicts.com/forums/show...e+inlet&page=2 |
10-04-2019, 12:54 PM | #27 | |
1288
Rep 3,502
I didnt see anything about the water pump in those directions... Not doing the diverter right now anyway.
10-09-2019, 02:50 PM | #28 |
1288
Rep 3,502
Finally got her done. Basically the data suggests once i hit 41.4lb-min on the maf i see no more regardless whats happening so im unable to verify anything. Logs shortly
10-09-2019, 10:10 PM | #30 |
Rep 5,377
Curious what your initial impressions are with the Pure Turbos Inlet? Getting mine installed in a few days.
10-10-2019, 09:36 AM | #31 | |
1288
Rep 3,502
Post install observations... Its louder. There is a noticeable more intake noise (already running the injen intake). Its about a half inch increase in diameter so it is a rather big change so its not surprising there was a noise change. Driving the car I dont really notice anything. However, I haven't been able to drive the way now in about 10 days due to time frame where i started pulling things apart in preparation for the install till yesterday.
10-10-2019, 09:53 AM | #32 |
1288
Rep 3,502
Here is the logs...
This was the last log before the inlet http://www.bootmod3.net/log?id=5d87c19fc090c658131412ee Log from yesterday post inlet http://www.bootmod3.net/log?id=5d9e32c1ae729b770a4213b2 You can see that I hit 41.4 on the Maf reading and it never climbs which Im guessing is because Im maxing it out, so I have no basis for comparison to see if it reads higher on flow or not. Not really seeing any real signs of change on the waste gate duty cycle. Since Im an EWG car, they are always high and BM3 says I do not have a leak based ont he numbers. Did it hurt performance? Nope... but did it help? No idea tbh. I would say that its obvious why it would help with an aftermarket turbo set up and maybe on stock running really high boost. Mods are.. Injet intake Charge Pipe VRSF 5" IC Catless DP BM3 E30 Map BMW Trans Flash
10-10-2019, 10:03 AM | #33 | ||
Rep 5,377
I've got the M Performance intake which maybe sounds a little louder than stock because it has an extra air intake hole in the bottom of the air filter box. (That hole faces forward.) I use a drop-in aFe Pro Dry filter. Now I'm curious to see if I notice any sound difference. Please post before and after logs if you can. I'm very curious to see if you have the same increase in MAF readings and how much they differ from 5000 RPMs on up. I haven't recorded a log but I may give it a try so that I have some "before" data before my installation. |
10-10-2019, 11:33 AM | #34 | |
1288
Rep 3,502
Logs are above.. as you can see, my results were useless.
10-23-2019, 10:37 AM | #35 | ||
Rep 5,377
1) Pure Turbos Inlet 2) Turbosmart N55 Diverter Valve My "before" logs weren't useable but I did get one good "after" log and will put the link below. I also attached a summary page of my MAF readings versus yours. Mine peaked at 4.1 higher than yours. http://www.bootmod3.net/log?id=5da5d76bc090c64dcce41c79 Our cars are the same: 2015 335 N55 EWG So I'm trying to understand how our mods may differ to see what may be different. You had previously listed your mods as: Injet intake Charge Pipe VRSF 5" IC Catless DP BM3 E30 Map BMW Trans Flash Pure Turbos N55 Inlet Pipe My mods during my log were: M Performance Intake/ stock air filter Evolution Raceworks Charge Pipe Wagner Competition EVO1 FMIC Fabspeed Catted Downpipe BootMod3 Stage2 N55 EWG 93 Octane BootMod3 Auto Transmission Flash Pure Turbos N55 Inlet Pipe Turbosmart N55 Diverter Valve/Blow Off Valve, Plumb Back model I'm scratching my head trying to figure out what might cause the differential. 1) Our intakes are very different. Bryan and I were discussing that some intakes can sacrifice actual power to make noise but we didn't discuss the mechanism for why that happens. 2) Our BM3 tunes are different due to fueling but I would assume that an E30 tune would be the same or better than a 93 Octane tune. 3) My DV is an upgrade from stock but my assumption is that wouldn't come into play at all with the accelerator floored in 3rd gear. That's a small snap shot of data when the valve on either car should not open. Somewhere in this thread it was mentioned that there is some correlation between MAF value and horsepower/torque. Do you know what that value is? Where is comes from? How accurate it is? Any thoughts on all this? |
10-23-2019, 10:58 AM | #36 |
Rep 1,115
You can't compare cars running different tunes, in different climates and altitudes. You needed to have a before and after log on your car to make any meaningful comparison. Right off the top Phantom and your ambient pressures aren't the same, which has an impact on airflow.
harkes1071.50 |
10-28-2019, 04:45 PM | #37 | |
1288
Rep 3,502
The difference is the intakes... I guess we cant use any of the data for comparison sake because we have different intakes. There is something interesting that I noticed after looking at my older logs though, more on that in my reply below. Yeah. there is a relationship between maf numbers and power. the higher the number the higher the HP. Ive seen numbers ranging between 7-10hp per... so using 10hp... 40 on the maf reading would be 400hp etc.. 41 would be 410hp etc... but there isnt an exact number but it does give you a good easy way to see power increases or a decrease.
10-28-2019, 04:49 PM | #38 | |
1288
Rep 3,502
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc Last edited by n55david; 10-28-2019 at 05:03 PM.. |
10-28-2019, 09:29 PM | #39 | ||
Rep 529
Looks like you live in a location with very dense air (ie. not high elevation). People comparing maf readings or doing mods based on maf readings seems pretty misleading, it really has to do more about air density than air flow. More dense air has more oxygen.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
10-29-2019, 08:39 AM | #40 | |
1288
Rep 3,502
We have the same car, 2015 ewg n55. and hes seeing higher readings
10-31-2019, 07:12 PM | #41 |
Rep 1,282
Where can you buy inlet 2 from? I asked mike from extreme and he said they don't.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
10-31-2019, 08:21 PM | #43 |
Rep 1,282
Thanks! Do I need an adaptor for this to fit stock turbo?
