BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode and screen mirroring
      04-09-2018, 08:39 PM   #1
bimmer4lif3
Drives: M440 gran coupe, E46 M3
I have read on other forums that screen mirroring can be done with Esys has anyone been able to do it with bimmercode yet?
      04-10-2018, 07:41 PM   #2
oguz kuruca
Drives: F83 BMW M4
I looked through the options I could not find it. If anyone else finds it, it would be awesome!
      04-10-2018, 08:34 PM   #3
rlmesq
Drives: 2018 440i M Sport
In BimmerCode expert mode, you can do anything you can with ESYS. Just find the values and change them.
Billfitz8243.00
      04-15-2018, 10:44 AM   #4
bimmer4lif3
I haven't used the expert mode as of yet because everything I wanted was readily available. That being said I did find some info on it but don't know if it will work but I will share it to see if anyone else knows what to do with it.
Enable WiFi Hot-Spot
3000ENT_MC_WLAN_STREAM_DMP_COVERARTset to: aktiv
3000ENT_MC_WLAN_STREAM_DMP_VIDEOset to: aktiv
3000ENT_MC_WLAN_STREAM_DMPset to: aktiv
3003WLAN_STATUSset to: aktiv
3003WLAN_MODUSset to: ap
3003WLAN_SIGNAL_STRENGTHset to: outdoor
3003WLAN_CHANNELset to: channel_1 -14
      04-29-2018, 09:23 AM   #5
bimmer4lif3
Anyone had any luck streaming youtube to nav screen without any hardware?
      11-14-2018, 04:47 AM   #6
Dark_knight
Drives: 430i M Performance
Originally Posted by Vapotrini View Post
Thanks a lot for sharing this! I finally got it to work on my android phone after applying those setting and after a bit of experimenting. There' was one more setting that I had to enable for it to work though.
Long story short, you also need to enable WLAN_WIFI_DIRECT in TELEFON_TELEMATIK and it should show up after that. Also, on my unit WLAN_MODUS was named WLAN_AP, make sure it's set it to active as well.
It's incredible how much I wanted this feature before I actually got it... Huge Anti climax and wasn't worth the long search and secrecy tbh.
NBT_EVO /ID6
Hi is this the complete list of codes for screen mirroring on my f32 430i? Is there a thread that covers everything required?
      06-10-2019, 03:32 PM   #7
dushanrules
Drives: BMW F30 M Sport 2018 Car
I tried with my F30 LCI (Japan imported) and can confirm you dont need to adjust WLAN_SIGNAL_STRENGTH set to: outdoor & WLAN_CHANNEL set to: channel_1 -14. I actually these changes gave me errors in the screen, worked perfectly when removed.
NBT_EVO /ID6
      07-22-2020, 03:51 AM   #8
micatech
MICATECH
Drives: 330i F30
What am I doing wrong???
Have spent a fair bit of time trying to get screen mirroring working on a 2017 F30 330i. Its a NBT EVO id5 version.
I do not see "screen mirroring" appear at all anywhere.
These are the settings I have applied.
Made the following changes:-
3000ENT_MC_WLAN_STREAM_DMP_COVERART set to: aktiv
3000ENT_MC_WLAN_STREAM_DMP_VIDEO set to: aktiv
3000ENT_MC_WLAN_STREAM_DMP set to: aktiv
3003WLAN_STATUS set to: aktiv
3003WLAN_AP set to: aktiv
3003WLAN_SIGNAL_STRENGTH set to: outdoor
3003WLAN_CHANNEL set to: channel 14
WLAN_WIFI_DIRECT enable
Is there something wrong or missing? Any help appreciated.
      07-28-2020, 09:54 PM   #9
micatech
MICATECH
Drives: 330i F30
I finally gave up trying with Bimmercode as all the above changes did not work on my 2017 F30 330i. I decided to purchase "screen mirroring" from a 3rd party and it came via email and I placed it on a USB stick and it worked perfectly. I immediately wanted to know what changes had been made that made it work so I trued reading the Headunit via Bimmercode but now Bimmercode "cant read Headunit" ecu. All other ECU's seem fine. Unhappy with this I did a restore of the headunit via Bimmercode and it restore OK BUT I still cannot read the ecu via Bimmercode. Why??? I restore with the very first backup. Anyhone know how I can fix ecu so Bimmercode can read it again?
      07-28-2020, 10:36 PM   #10
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
I read on another thread (don't have the link handy) that a certificate was changed when the USB enabled screen mirroring in the headunit and Bimmercode no longer recognizes it. Copy your Bimmercode backups to your computer and reset the app and it should be able to connect again.
      07-29-2020, 10:08 AM   #11
F30Bully
F30Bully's Avatar
Drives: BMW 340i
So these settings only apply if you have the external device?
      11-25-2020, 03:33 PM   #12
akastixx
Drives: '18 320i xD > '19 430i xD
I got it to work without the outdoor/channel part like dushanrules said.
I also enabled the options on https://f30.bimmerpost.com/forums/sh...03&postcount=2
I think one of these were not on mine, so I skipped it.
Thanks!
2018 320i xDrive
EDIT 6/2021 - 2019 430i xDrive, same steps
      12-31-2020, 06:43 AM   #13
SerTan
SerTan's Avatar
45
Drives: BMW 320i M Sport F34
Sorry to resurect old post i bought f34 UK 2016 done all setting but for some reason Vehicle WiFi tick box is not selectable for some reason. Any idea why?
The 3003WLAN_MODUSset to: ap ( i cant see MODUS in 3003) can that be why im having issue as it was not changed.
      01-02-2021, 05:43 AM   #14
SerTan
SerTan's Avatar
45
Ok i guess no one knows much about it. My guess i might not have wifi antenna installed, ill check install it if it needs to be and see what happens.
      10-21-2021, 08:55 AM   #15
driverbmwx
Switzerland
Drives: BMW 435D Cabrio
Hello. have you already set up the antenna. Has it helped?
If I am not mistaken, this antenna is 61119308571?
      03-22-2022, 03:28 PM   #16
Vexter182
Drives: 2011 E90 M3, 2007 S2000
I know this an old post but I was able to get screen mirroring enabled! I now can have Waze on my screen from my android phone
Is it possible to keep my audio connected with bluetooth? I want to be able to change the volume and track with the steering wheel mounted controls
      03-23-2022, 10:36 PM   #17
dv8ed
Drives: 2013 F30 328i N26
Is screen mirroring worth it? I heard screen is small not full screen?
2013 F30 328i N26
      05-03-2022, 04:06 AM   #18
JohnTravol
Drives: BMW 420d
After enabling Screen Mirroring on my F36 realised that my Motorola Android phone does not support Miracast since Google dropped it in 2016 or thereabouts. Tried with a Samsung tablet and it all works as expected, but it's only slightly more than half of the iDrive screen. So, the lesson is, this Screen Mirroring only works if your device supports Miracast standard and does not work if it supports Chromecast!
      07-28-2023, 05:36 AM   #19
erorodic
Drives: BMW 5
Hi guys,
I activated with expert mode, mirroring, video in motion, wlan, miracast in headunit 3000, 3001, 3002 and 3003 groups.
I see now on my iDrive7 menu "screen mirroring"
I see in iDrive7 display says : Miracast connect your mobile with bmw59864, I open on my Samsung "screen view" it founds screen mirroring bmw59864, but I can't get last request on iDrive7 to connect with question "would you like to connect yes/no".
So everything works good until last step when I have to connect Samsung mobile with Miracast screen mirroring in iDrive7 to make screen mirroring connected.
Does anyone of you had similar issue?
It works perfect with my old BMW car and iDrive6, but with iDrive7, probably I forgot to activate some parameter with bimmercode and don't know which one in Headunit option
