06-19-2018, 06:58 AM | #1 |
Rep 15
Engine coolant
I just checked the coolant level today and it’s low and needs topping up.
Plan on getting some Nulon concentrates and mix it with distilled water. Do I have to top up with the same blue colour coolant that is in the car or can I top up with the newer Nulon Coolant One. Thanks. |
06-24-2018, 06:40 PM | #3 |
Rep 168
drain and refill with recommended coolant type, as suggested above it not wise to mix coolants. they different chemical properties based on color and brand .
If you mix them you may have possibility of turning it into a jelly which will not be good for your car at all. you can however Top it up with Distilled water if you are close to a service cycle. |
