BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > OFFICIAL Slammed/Stanced (F30/F32) Thread
      09-19-2018, 10:45 PM   #1123
CHI3F
Drives: 2015 335i xDrive
Hello, all.
Just picked up a set of Work VSXX.
F- 19x8.5 et40 (thinking of adding a 12mm spacer)
R- 19x10 et23
Would I be able to run 235/35, 265/30 without rubbing? 335 xDrive on Dinan Springs.
      09-19-2018, 11:19 PM   #1124
theEZV
Russia
178
Drives: F30 335i; Looking for F80
Originally Posted by CHI3F View Post
Hello, all.
R- 19x10 et23
Those rears are very aggressive. No way you're gonna fit a 265 even if maxing out stock camber. You need rear camber arms and fender roll/pull. A 245 (or probably 235/35) is more realistic and even then I don't think maxing out the stock camber (should get around -2.5 or so) will fit without fender work.
      09-20-2018, 01:34 AM   #1125
jv004
Drives: X3M Comp
Hello, all.
R- 19x10 et23
That's pretty aggressive rear at et23, not saying it's impossible but you'll need some work to make it fit. You might need to stretch the tires and add camber.
      09-20-2018, 01:36 AM   #1126
Smee
Smee's Avatar
505
Drives: BMW M4 F83
Also 235 35 20 and 265 30 20 aren't a good match for xdrive
235 35 20 and 275 30 20 are a pretty much identical set.
      09-20-2018, 01:54 AM   #1127
kedafoe
kedafoe's Avatar
Switzerland
62
Drives: F31 335i xDrive
Hello, all.
R- 19x10 et23
Front is way too thucked and rear is too agressive. It will look ridiculous. You would need at least 20mm spacers in the front to look as same as in the rear and it would still look ridiculous because of spring height lol.
265? no chance. I run 225/35 on 19x10 ET25 in the rear and I could not fit more with max stock camber, which is -3.2 at my height by the way. And even tho I have a slight fender pull, it is still rubbing on the rim lip during hard dips.
      09-20-2018, 02:08 AM   #1128
kedafoe
kedafoe's Avatar
Switzerland
62
He has to if he wants it to fit.
That is not completely correct. In purely mathematical terms I agree with you (+0.1% rolling circumference). But xDrive is not designed for a positive deviation in the rolling circumference.
If we go for stock we have 225/40 and 255/35 on 19” or 225/35 and 255/30 on 20” which gives us a rolling circumference of -0.7%. That’s what the xDrive was designed for. So from this perspective 235/35 and 265/30 is the better option because it is -0.8% = total difference of -0.1% to stock.
I also had both combinations on my last setup and had less vibration issues with 235/265 than 235/275.
      09-20-2018, 09:55 AM   #1129
kern417
Cheapskate
4450
I don't think the difference from stock matters. You just need to make sure the fronts and rears aren't too different. If both are smaller or taller than stock it's not that big a deal if both diameters are similar.
      09-20-2018, 10:03 AM   #1130
Smee
Smee's Avatar
505
Drives: BMW M4 F83
my issue with 235/265 is unless they wear evenly and you change all 4 every time you are at risk of smashing the 1% rule
a new 235 with a half warn 236 will be closer to 2% rolling diameter difference
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      09-21-2018, 02:38 AM   #1131
kedafoe
kedafoe's Avatar
Switzerland
62
It does. Like I said I had vibration issues with 235/275 -> so I discussed that issue with BMW technical support from Munich and they told me that positive deviation is not good for the xDrive and you should always go out from stock. Which also made sense in retrospect because I had no more issues when I put on 235/265.
But that counts for every tire combination my friend. BMW says you should never have more than 2mm difference in profile front to rear.
So if you have to change tires you should always change all fours. If you don’t follow that rule you will have problems with no matter what combination, even stock lol.
      09-22-2018, 09:30 PM   #1132
KushPatel
Drives: 2013 F30 335xi M Sport 6MT
335i X Drive M Sport.
305 Forged FT107's
19x9.5 ET35 Squared
255/35/R19 Squared
H&R Sport Springs
DaFish157.50
Mr. Tasty427.50
Logicoeur992.50
hybris204.50
      09-23-2018, 07:27 AM   #1133
DaFish
DaFish's Avatar
Drives: 2014 435iX, FBO
305 Forged FT107's
19x9.5 ET35 Squared
255/35/R19 Squared
H&R Sport Springs
NICE !!
How does it handle? It must feel great... Assuming no rubbing on the front?
I should have done this.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      09-23-2018, 12:37 PM   #1134
KushPatel
Originally Posted by DaFish View Post
NICE !!
Thanks! Absolutely no rubbing at all.
It handles better than stock but the bumps are quite painful with the springs lol. I’m gonna upgrade my shocks/struts with Bilstein B8’s as soon as possible
DaFish157.50
      09-23-2018, 05:29 PM   #1135
Malloy
Malloy's Avatar
988
Drives: '05 M3 | 6MT | Slicktop
Not stanced, but pretty low and well fit. -2.1F, -2.7R.
OG TE37 18x9.5 et28, PSS 255/40/18 square.
Appreciate 8
Vulpe279.50
cngo56.00
kern4174449.50
not.ramos209.50
cdwalls702.00
BMW BRAD204.00
      09-23-2018, 06:45 PM   #1136
radiation
radiation's Avatar
Drives: '13 e92 335i
Are any of you xDrive guys having problems with front axles/cv boots? I'm torn on what to do with my car. I wanted a RWD to begin with since it doesn't snow too much in Ohio, but they just don't exist around here, and I made an impulsive decision and ended up with an xDrive.
Now I'm not happy with the way it handles or the ridiculously goofy ride height, and want to do coilovers. I'm worried that even at the highest setting on something like a KW SC I'll run into issues with excessive front end wear. I come from the lifted truck world, and told myself with this car ride height was staying stock. Don't know if I should just sell the car and travel south to get something RWD or take my chances and modify the xDrive.
It seems like most people on here only keep their cars for a couple years and less than 50k miles so it's hard to gauge long term reliability. I'd like to keep this car for 100k + miles but if I'm going to have to do CV boots every 10k that's not going to work.
      09-24-2018, 03:44 AM   #1137
kedafoe
kedafoe's Avatar
Switzerland
62
I have 60k miles now and no issues at all.
Only hypothetical issue you could have are vibrations from the front drive shafts and the transfer gearbox. Depends on how low you go and which tire sizes you choose. The latter is the most important. If you keep the rolling circumference as stock as possible you will be happy.
If you really want to do aggressive stance and riding low af it would be best if you get an rwd for those purposes beofre you invest money in your current car. If this is not your goal at all, you will be fine with the xDrive anyways.
      09-24-2018, 07:27 AM   #1138
kern417
Cheapskate
4450
      09-25-2018, 12:12 AM   #1139
wurstrocket
Drives: 2015 BMW 435i msport
heres my 435d
Smee whats the setup? I got a 435 and im looking to get something similar. Whats the offset you went with on the back and whats the width?
Also what you running for suspension?
      09-25-2018, 05:16 AM   #1140
Smee
Smee's Avatar
505
Drives: BMW M4 F83
20x8.5 et35 - 235 35 20
20x10 et42 - 275 30 20
tbh the front could maybe do with 3 to 5mm more spacing to be perfect.
im lowered on HR lowering springs (28832-1)
      09-27-2018, 08:26 AM   #1141
Luismpr
Drives: 2015 f31 bagged
F31 328xdrive
running
18x9.5 with 15 mm spacer 215/40/18
18x11 245/35/18
Should be able to run a 18x10 +25/20 ish upfront
front airlift camber plates
stock rear suspension
BTW i have the rear megan camber and toe arms but didnt need them so if anyone wants to buy brand new parts for cheaper than megan sells, slide in the PM
      09-27-2018, 03:14 PM   #1142
elising
Drives: 2017 M4 Comp
I
      09-28-2018, 12:12 AM   #1143
kedafoe
kedafoe's Avatar
Switzerland
62
Originally Posted by Luismpr View Post
running
18x11 245/35/18
perfectly executed
check your PM
      09-28-2018, 02:19 PM   #1144
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
that hyundai tho
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
s3ri3s1188.50
lfepro.g188.00
David0ff1059.00
aggressive, f30, low, slammed, stance
