BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > TTFS XDI-35 HPFP Upgrade + PS2 Turbo Build/Result Thread! 500+ whp
      08-26-2019, 05:39 AM   #133
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
Originally Posted by Munchi435i View Post
Any updated logs?
There seems to be 2 knock events in your log just FYI.
Im starting to have some fueling concerns with my PS2 and might just bite the bullet and purchase the XDI-35 pump for peace of mind....and better performance lol
Good eye... timing and knock resistance is much better with a little ethanol mixed in. No updated logs, I'll try and grab some on a cooler night.
Originally Posted by luchocamp View Post
No piggybacks game
One custom tune for best fuel availabe US$600
Another custom tune everyday fuel US$600
Another custome tune looking for best track ( circuit or drag ) results US$600
JB4 ( ) for me is the best way to go
After all the expensive hardware upgrades, I rather spend money for a tune done right
Jb4 is okay, it makes the cars run inconsistent. I have nothing against them and I ran JB4 for nearly 2 years. My experience with JB4 was the car was not as smooth and ran inconsistent. Plus they are known the fry and cause electrical shorts. My car runs much better without it once I removed it. Could I pick up more power and use as a boost controller with it? Maybe. But that's not a big enough reason to put it back in for me.
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
harkes1078.00
      08-29-2019, 03:31 AM   #134
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Originally Posted by F30_SixSpeed View Post
Updates: XDI-35 HPFP has proven to be a nice option and I don't have any complaints with it. Recommend for people that need more fueling for stock and upgraded turbos. Best thing IMO is I run flash only, no piggybacks.
Sharing a datalog of a 93 PUMP GAS on 21 psi. ~90 degree temps.
http://www.bootmod3.net/log?id=5d465fe0c090c66f5cf2a0a1
Pump can take it, but 17-19psi seems to be the limit on 93 for octane. Could be very interesting to see a dyno with 21psi vs 18psi on same 93. I wonder if you gain much on those 3psi due to timing impact. Awesome stance
(A Dane in China)
      10-15-2019, 02:21 PM   #135
F30_SixSpeed
1171
Updated original post.
Finally got a chance to hit the rollers again! 528 whp and 570 wtrq
Again this is with PS2 Turbo, FBO, XDI-35 HPFP, custom tune + supporting mods.
Runs were all consistent with and awesome power curve as well. Car is running FLASH ONLY and 93oct/boostane for these runs. Car is certainly a blast to drive!
      10-15-2019, 02:52 PM   #136
insane11
Drives: 435i GC
What rim are those
      10-15-2019, 02:59 PM   #137
F30_SixSpeed
1171
Originally Posted by insane11 View Post
What rim are those
OEM 437m
      10-15-2019, 04:41 PM   #138
ChrisFulton
Drives: m235i
93 octane plus boostane?
18 psi or 21?
Really appreciate you posting. I'm about to do something similar. Just waiting to see if there is going to be another HPFP option.
      10-15-2019, 07:11 PM   #139
F30_SixSpeed
1171
18 psi or 21?
This was 21 psi. 93 plus boostane on these pulls.
      10-15-2019, 07:50 PM   #140
luchocamp
Drives: 18 BMW M2LPower
If your car run inconsistent you most have a diferent problems.
I had over 20 paseses between 10.6 and 10.7 day, night, different tires, etc.
Also in M3 S55 full weight 10.11@140.5mph over 20 passes running with JB4 in 10.1 and 10.2 range.
Maybe you need understand how JB4 operates... but anyways use whatever you fell is better for you.
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires
instagram @luchocampusano YouTube Lucho Campusano
      10-16-2019, 08:26 AM   #141
F30_SixSpeed
1171
Like I said my setup runs terrific on my current setup... without the JB4. I don't really need it, so why add another thing that is prone to fail? I appreciate what you have done with all your test cars, but that doesnt mean if someone does something different you should bash them. For the record, my jb4 was installed correctly and I know how to configure it. If you read my original reply that you quoted too, that reason alone is why i dont want to run it.
See below:
      10-16-2019, 08:57 AM   #142
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
I've been pretty lucky with my stock HPFP. Targeting 18 pounds of boost at the moment with a custom BM3 tune.
View post on imgur.com
      12-04-2019, 09:21 PM   #143
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
Updated numbers. Been back to ttfs and I'm running my e50 tune now....xdi 35....pure stage 2.....lpfp stage 2
Bmw m235xdrive.
Made 506 whp
Stanio67.00
      12-05-2019, 05:12 AM   #144
T_H_O_M_A_S
Drives: M140i
only 4.5 degrees timing , when thats upped , the hpfp will crash
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      12-05-2019, 07:55 AM   #145
XxThe_RemedyXx
967
Hey bud thanks for pointing that out. I'm still learning about timings and how they relate to all aspects of the engine. Can you go into a little more detail as to why you believe the fuel pump will crash? How do I counter? Back off boost, better fuel?
      12-05-2019, 09:31 AM   #146
T_H_O_M_A_S
Drives: M140i
that 4.5 is alos taken on 1 point . check if its the same across the rpm band .
but in short , more timing could yield more power , power comes out of burning more fuel .
      12-05-2019, 12:00 PM   #147
XxThe_RemedyXx
967
Thanks! I sent a message over to Carey (my tuner) to see what he thinks. Much appreciated.
      12-09-2019, 08:41 PM   #148
enlimalima
Drives: 335i F30 PWG
See below:
Which tuner at BM3 platform provide you with the custom map?
How many custom map did they make for you and how much does it cost per custom map?
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
      12-17-2019, 12:21 AM   #149
enlimalima
So i just realize BM3 maps S2 and S2H has drop down menu to opt for XDI-35. Do you think it's worth the extra bucks to buy custom map or will S2/S2H will do just fine?
      12-29-2019, 08:35 AM   #150
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Hey man, how's the clutch doing.
Youtube/Instagram/TikTok: @kern417
      12-30-2019, 09:56 AM   #151
F30_SixSpeed
1171
It's a very stout clutch. No problems!!
      12-31-2019, 05:46 AM   #152
kern417
Cheapskate
4450
sweet, i'm about to install mine to prepare for future upgrades. you kept the stock flywheel?
      12-31-2019, 09:14 AM   #153
F30_SixSpeed
1171
Yea it was in good condition and I didn't want to loud chatter with a single mass flywheel. Personal opinion. Worked out fine for me, would do it again.
kern4174449.50
      12-31-2019, 01:04 PM   #154
kern417
Cheapskate
4450
Yep, that's my plan too. Appreciate it
