BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Cs style taillight
      11-19-2020, 03:54 AM   #1
Nomana
Nomana's Avatar
1289
Cs style taillight
Found it on FB
rcaso26205.00
      11-19-2020, 09:27 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I prefer the stock lamp.
      11-19-2020, 01:05 PM   #3
rcaso26
rcaso26's Avatar
205
Drives: 2015 328i xdrive
I saw these tail lights on facebook too. I think these would look cool on a aggressively modified f30 or a f80. Otherwise, I think it's a little overkill.
      11-19-2020, 04:57 PM   #4
royjovero
Drives: 2015 328i
I literally hopped on the forum because I saw these on FB. I want
2015 328i N20 - bootmod3 93 Octane Stage 2, VRSF catless downpipe, FTP Motorsport turbo inlet pipe charge pipes, Active Autowerke FMIC and exhaust, Injen intake, BC coilovers with Hyperco springs, ADV.1 wheels, other shit...
      11-19-2020, 05:51 PM   #5
rlmesq
Drives: 2018 440i M Sport
The Ferris wheel in the first picture is appropriate. The lights along the edge remind me of the Zipper carnival ride.
      11-19-2020, 06:52 PM   #6
eff32fl
eff32fl's Avatar
61
Drives: 2018 430i M Sport
These tail lights from the CS and GTS are awesome looking. I don't believe you can retrofit them to an F32 though. I believe they're only compatible with M4's, whether base or otherwise. I'd like to hear if someone was able to retrofit them though. Although they're $10k lol.
      11-19-2020, 09:08 PM   #7
Pauloxxi
Pauloxxi's Avatar
Drives: 2014-320Xi / 2017-330Xi
My wife has an F30 2014 and I an LCI... Quite frankly I like more the pre-LCI tail light with straight line instead of the curvy lines.
The only one I would consider to change is the blackline... otherwise stay OEM and no leaks.
Diegs1419.00
      11-19-2020, 10:06 PM   #8
Billfitz
Billfitz's Avatar
$10k tail lights? If that doesn't say 'more money than brains' I don't know what does.
      11-19-2020, 11:29 PM   #9
eff32fl
eff32fl's Avatar
61
Right lol. Even if I did have or save up $10k I don't think I could go through with spending that cash on a pair of tail lights. They're so pretty though!
      12-01-2020, 07:29 PM   #10
fortythirtyfive
Drives: 435i MS
These are aftermarket remakes - Dubsesd was talking about a project a while back, a few guys in the US had teamed together to try and build these, however it looks like a Chinese manufacturer ran with the plans and made it themselves.
There was a post on IG recently regarding these to be stolen prototype designs, with many flaws supposedly.. that said at £480 it's not bad to say they're literally plug and play. The light up pattern is managed via an internal controller, so in theory if they did release a 4er shape then they should be compatible.
Current: F32 2015 435i M Sport - Alpine White - Scorpion catless DP, MPE with optional turboback straight pipe valve control, CF aero kit, Morph carbon valances, 405M's, 12 & 20mm spacers, retrofitted ICON headlights, retrofitted blackline LCI rear lights.
      12-02-2020, 02:31 AM   #11
Cityofangeles323
Cityofangeles323's Avatar
Drives: Bmw 320i
Vland will be releasing these mid December for 2012-15 F30s. These do look cool imo, but all your other exterior mods need to be on point.
      12-02-2020, 09:39 AM   #12
Nomana
Nomana's Avatar
1289
Cool btw is there for f32?
      12-03-2020, 02:36 PM   #13
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
dubsesd posted about something similar on his IG (same username). Not sure if they're the same as the ones pictured but same idea. The ones he posted about are by a new (?) company called Solas Illumination Co.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD | Retired: Jet Black 2013 328i 8AT xDrive |
      12-06-2020, 10:58 PM   #14
eff32fl
eff32fl's Avatar
61
Appears to be only for F30 and F80 unfortunately. I'd buy a set of these if they were available for F32 but sadly doesn't appear to be the case, based on what I can see at least.
Another recent thread about these lights:
https://f30.bimmerpost.com/forums/sh....php?t=1777820
      12-07-2020, 01:18 PM   #15
WillLowe
Drives: F32 435d
I emailed the seller and apparently these are in the process of being made for the F32/F82. The seller however did state it will be a good while before they are available to the masses
Nomana1288.50
      12-07-2020, 01:25 PM   #16
Nomana
Nomana's Avatar
1289
Good news
Thank you
