08-17-2018, 06:39 PM | #1 |
Rep 79
Drives: 2018 440i
Engine warm up
Coming from a 2011 535, it used to take like 10-15 minutes for my engine to reach operating temp, in the new 2018 440 it seems to get up to temp in under 5 minutes.
Is this normal, and can I push the car this early from a cold start? |
08-17-2018, 06:54 PM | #2 |
Rep 3,876
I have the same observation in comparison to my 2011 Audi TFSI.
The BMW gets up to temperature noticeably faster. Whether you can push it already then - I follow the principle "don't if you don't necessarily have to"... Prefer waiting a bit longer.
08-17-2018, 07:11 PM | #3 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I let the temp gauge needle move off cold to let the oil warm up. You can beat on it after start up but why are you in that much of a hurry? Warmer oil flows better and keeps everything from wearing under high stress. I laugh at all these videos that show cold starts and you hear them gunning them to get the pops/burbles on video with condensation still coming out of the pipes......
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
08-17-2018, 07:19 PM | #4 |
Rep 79
Drives: 2018 440i
Not really in a hurry, always let the car idle for a minute on cold start. Just I use my oil temp gauge as an indicator that it's ok to go into sport mode, don't like the idea of doing it so early.
I also drive light footed for the last couple min of the drive to kinda let everything cool off. |
08-23-2018, 10:45 AM | #5 | |
Rep 63
Was the the e46 m3 that had lights on the tachometer that slowly increased "redline" as the engine warmed up? |
08-23-2018, 11:01 AM | #6 |
Rep 5,369
On a stone cold motor, 70-90 degree ambient air temps, and per my Torque app, it take approximately 10 minutes of steady driving for the oil to get up to 180 degrees which is the bare minimum temp for hard driving/heavy boost. If it's colder out, especially below 50 degrees, add 5 more minutes. If it's 20 degrees, the oil has trouble getting up to and maintaining 180 degrees.
08-23-2018, 11:05 AM | #7 | |
Rep 4,109
Drives: BMW M3
Personally I drive for about 10 minutes before getting on the gas. The engine oil gets up to temp fast as you've observed, but there are other fluids to consider - differential, transmission, etc. Not sure if they warm up as fast. Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
08-23-2018, 11:20 AM | #8 | |
Rep 3,211
the coolant circuit is bypassed on coldstart then shortly aided by a heater then later coolant kicks in so it gets warm quicker but I would still wait for operating oil temps b4 getting on boost turbos r delicate creatures b58 also continues cooling the turbo after you shutoff so no need for the ancient practice |
azuritschwarz347.50 kern4174446.50 |
08-23-2018, 12:25 PM | #9 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Get in, start the car & drive off. Don't push it till the oil temperature gauge needle starts to move up before running hard. If you have a water temperature gauge instead of an oil temperature one wait till its at normal operating temperature.
Takes longer for the oil to warm up & oil is the key. I have both gauges in some cars & its a pretty big spread between water & oil coming up to operating temperature. You can have heat in the car with cold oil.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
08-23-2018, 01:01 PM | #10 |
Rep 59
I always waited until my car's cold start RPMs went down to the normal idle RPMs, however i don't throttle my car and hit over 3k RPMs until the engine has warmed up fully. My brother got a brand new car and he always jumps into his car and puts it into the drive and heads to work. He also throttles it when getting on the highway. Long story short i have noticed his car is idling very hard now, and it sounds terrible when it first is started on a cold start. Just to shows a couple minutes of waiting until it warms up will prevent problems later on, and im sure his car now is showing signs of what he does to it, the poor car... Luckily its a toyota and not a BMW!
Palantir219.00 |
08-23-2018, 05:58 PM | #11 | |
Rep 3,211
to start driving right off the bat is maximizing the time the engine is running with any load lubricated with sub-operating temperature oil much of the engine wear occurs in this critical period esp in cooler temps & with the B58 which reaches fairly high levels of torque at such low RPMs not good for bearings |
08-23-2018, 06:50 PM | #12 | |
Rep 799
08-24-2018, 11:09 AM | #13 |
Cheapskate
4447
Rep 4,993
Interesting this same discussion is blossoming in another thread. Users are saying their N55 takes 15 min or so to heat up but my '18 B58 heats up in 5 min or so. On warmer days it's in the middle of the gauge before I get on the highway (less than 2 miles from home). But I'm pretty convinced that, at least mine with the 6WB cluster, is a dummy gauge to some degree. I have never seen it move from the middle when I know the temps fluctuate based on normal driving conditions, and on top of that it sounds like BMW does some magic with how the cars allows temps to increase and decrease based on how you're driving.
More discussion: https://f30.bimmerpost.com/forums/sh...php?p=23634882 |
08-24-2018, 11:24 AM | #14 |
Monobloc
332
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
I would wager that most cars have their cold engines rev'd way past 4k (even redline) within the first 5-10 minutes, especially lower HP/TQ vehicles. Most people are clueless in this regard and many don't even give a damn because their cars are leases and will simply pass potential or impending problems down to the new owner(s).
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
Palantir219.00 |
08-24-2018, 11:27 AM | #15 | |
3127
Rep 5,264
The water does come up to temperature quicker for the heater then the N54/55 because the closed deck block has a “heat management module” on the B58, which is mechanically powered directly by the crankshaft through a serpentine belt. Inside the module, coolant flow rate is adjusted by a rotary valve
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 08-24-2018 at 11:36 AM.. |
08-24-2018, 11:30 AM | #16 |
Rep 5,369
Yes, the correct way to quickly warm up a motor is to drive within the first 30 seconds of a cold start and drive moderately until the oil is fully warm. As others noted, oil takes a MUCH longer time to warm up than coolant. I watch it all the time on my Torque app. During warm up, oil lags behind coolant by about 5 minutes in terms of getting up to a safe operating temp.
The N55 DME is pretty smart though as the wastegate will bleed boost until oil is warmed fully. Even so, unless it's an emergency situation, let your oil fully warm up and disregard what the coolant gauge is telling you as it's basically a dummy gauge that tells you three things: cold engine, operating, and overheating
08-24-2018, 02:38 PM | #17 | |
Rep 15,858
Being a diesel owner, I'm used to oil taking as much as twice the time to heat as coolant, particularly slow in winter months where even after 16 miles, oil is not up to temperature. When I took on the 535i, I was expecting much faster ECT heat up than a 3-litre diesel, with oil temperature still lagging well behind the ECT. Was surprised that ECT is still quite slow to warm, oil is just a few degrees behind, and virtually levels out as the N55 engine's ECT reaches close to optimum running temperature. Looking at the design I put the faster oil heating, (at least partly) down to how the oil sprays the underside of the piston crown, acting as a heater to the oil in the warm up phase. That in turn slows the ECT rise, as more of the available waste heat goes to the oil directly. BMW haven't given as much detail on the B58 oil circuit as the N55, but imagine it will be similar for heat control. If users are really getting to full temperature in so few miles/minutes, (my 5-series takes at least 12 miles/15 - 20 minutes, when the ambient temperature is below 10C/50F to get to optimum running temperatures), what's the mechanism for doing so, other than using more fuel? |
08-24-2018, 02:43 PM | #18 |
Rep 4,724
The B58 engine has a water/coolant jacket around it to help hold in temperature for up to 36 hours for less wear and tear on the engine.
This is why your car warms up faster.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
08-24-2018, 03:18 PM | #19 |
Rep 5,369
So does the N55.
08-24-2018, 03:20 PM | #20 |
Rep 4,724
Not like the B58. It was meant to keep the temperature over 3 times longer than the N55. Look up all the tech specs on the B58. It's all there.
08-24-2018, 03:27 PM | #21 | |
Rep 15,858
I must look into this a bit more, thought that only came with the latest installations, like the latest 5 & 7 series. |
08-25-2018, 02:59 AM | #22 |
2JZ-GTE
3038
Rep 3,992
My b58 takes at least 10 mins on freeway to hit normal temp
