03-23-2018, 07:35 PM | #155 | |
Rep 228
at the end it will end up costing more than BMW integrated nav which you can get for 800? from getbmwparts. But the outcome is you can have google mpas or waze or whatever you like from the android unit. |
03-28-2018, 03:41 PM | #157 |
Rep 268
I own a 2013 335i with pro nav nbt and the 8" screen as standard. Trying to fit an F15 10.25 CID part code 9347878-03 to my nbt with the CID cable on my car being 6119261850-01. When I marry the two up there is no life in my CID. I know the screen works as I seen it in operation before I purchased it. Am I wasting my time here?
03-28-2018, 05:24 PM | #158 |
Rep 20
I've been looking at upgrading the 6.5" Business Nav screen that came fitted in my March 2017 F31. This is pin sharp, so it must be the latest high resolution screen.
Courtesy of eBay, I've managed to get my hands on a 8.8" screen (65506822626) at a reasonable price and have just completed fitting this. I only changed 2 codes via Bimmerapp: DISPLAY_SIZE_RESOLUTION to 8.8" and DISPLAY_VARIANTE from 'Schamel' to 'Breite'. All I get is a constant 'NO SIGNAL' message displayed onscreen. I've done a full restart of the system by holding down the volume button for 30 seconds but still 'NO SIGNAL'. Am I missing out any codes here, or do I have a hardware compatability issue? The screen also came out of a 2017 3 Series so I'm a little surprised it wasn't just a straight swap. Is there anything else I need to check? |
03-28-2018, 09:12 PM | #161 |
Rep 20
I've just had another look at realoem (serial no: K817571) and I think the screen I have should be compatible with a vehicle manufactured during 03/2017.
It's the only option listed for an 8.8" screen as well. The major difference is between 606 and 609 support. Should I be using ESYS to update my head unit to 609? |
03-28-2018, 10:00 PM | #162 | |
Rep 228
03-29-2018, 09:01 PM | #165 | |
Rep 565
No one has yet retrofitted the new screen you bought (at least didn't write back in this topic and let us know). It may seem that the screen has a different voltage (APIX2 I think) which may not work with the older head unit (HU_ENTRYNAV). We've successfully tested 2 older models, but not the newer one. EDIT: Try double-checking if the resolution is set to 1280x480 ("8.8 1280x480"), some cars have two possible resolutions available to choose from for 8.8" screen size. |
03-30-2018, 05:08 AM | #166 |
Rep 20
Thanks Marko and to
I shall order a cable and see what the score is for ENTRYNAV. Would I be receiving a NO SIGNAL on the screen even if it wasn't the correct voltage? If I can't get this screen working, what model of 8.8 screen would you recommend? |
03-30-2018, 06:11 AM | #167 | |
Rep 565
Get an ENET cable, check via eSys which head unit you have and if you have HU_ENTRYNAV (not 2), then you can get either of these two screens: 9292248 9387453 See the post I linked for photos. My 2016 F34 with HU_ENTRYNAV works fine with both of them. There's also a chance that BimmerCode didn't code the values correctly - we have only tested eSys for this, so try to code the resolution and breites_display with eSys again before ditching the new screen. |
03-31-2018, 04:25 PM | #168 |
Rep 3
I'm just looking for a 8,8 screen to buy online.
Should I only buy the Screen with the part number (65509385202) I found for my car? Or can I buy other 8,8 screens for my F20 (07/2015) VIN: 5A76632 I think I need the LCI-Screen with 12V right? Thanks! |
03-31-2018, 06:09 PM | #169 | |
Rep 565
I suggest you get an ENET cable and check the head unit with eSys software first (you'll need them to code the larger screen anyway). You should see HU_ENTRYNAV and not HU_ENTRYNAV2. If you can, try to get a screen for your car - it will have the correct backplate and will fit perfectly. You can get a screen for F30, but the backplate will be different and won't fit your car. It can, however, be detached from the screen itself so you can change it if you get yourself a backplate for F20. |
04-04-2018, 12:06 PM | #170 |
Rep 5
F34 GT 2017 8.8 screen retrofit
Having a bit of bother with this retrofit but I think it is to with the model year and the compatibility with screens.
I have tried to put in 6822626 on my Feb 2017 HU_ENTRYNAV but i am getting the dreaded NO SIGNAL despite coding. Does this mean I need a newer part or an older part given the year of manufacture for the HU_ENTRYNAV? I have looked at some parts and in the UK they can be found for as much as £700 which seems excessive for what it is? |
04-04-2018, 04:16 PM | #171 | |
Rep 565
Everything looks as though the new screen does not work with HU_ENTRYNAV. You can try getting the two older screens (they go for $400-$500 on eBay), see my reply to JayZee72. |
04-07-2018, 03:22 PM | #172 |
Rep 20
There appear to be more than a few versions of eSys available at the moment.
What version is recommended as the stable, tried and tested one? Thanks for all the guidance so far, particularly MarkoSK. |
04-07-2018, 04:57 PM | #173 | |
Rep 565
EDIT: Sent you a PM. |
04-09-2018, 09:58 AM | #175 |
Rep 20
I haven't managed to plug eSys into the car yet, but I have found a photo of the nav unit with the following details on it:
Model No = NAV SW ID = F020-17-03-502 Accession No = CD-M10-831-C Version = ECE Date = 05 03 17 MM PN = 503551691115 HW = 004.003.003 Type = NAV ECE 01FF 04 SNR = 0002309381 I'm going to guess that the above confirms that this will be the HU_ENTRYNAV unit so will not be compatible with my 626 screen? |
04-10-2018, 04:33 AM | #176 |
Rep 6
Hello Guys, can someone please check if i can do this upgrade.
My vin is: K287328 Production date: 10/2014 RealOEM is showing: 65509292247 - S606 Thank you in advance. Last edited by Cebela; 04-10-2018 at 04:50 AM.. |
