08-11-2019, 06:09 PM | #14785 |
Rep 19
I wanted to add, for those of you who downloaded and read thru the ''cheat codes' PDF. The last page lists codes that haven't been proven yet. I tried to change mine so the brake didn't need to be pushed to start the car. Don't do it!
I changed mine and the car wouldn't start. The doors would open and the ignition would turn on, but the starter wouldn't engage to start the car. [EDIT: starter wouldn't engage with, or without the brake pedal depressed.] I immediately plugged back in to reconnect, changed that one code back, and all was well. If I were to try again, I would change that code, and there's another one that's nearly identical. Perhaps they both need to be modified? It's not that important really; I just thought it would be convenient to start the car by reaching across when I'm putting a backpack in the right-front seat. Last edited by m3shelly; 08-12-2019 at 11:20 AM.. |
08-12-2019, 04:34 AM | #14786 |
Rep 6
hello to all the members of the group, I am a new registered user, so far I have always read your discussions.
I have a f31 of 2017 I would like to kindly know the coding to do with esys to enable the moving video thanks |
08-12-2019, 07:01 AM | #14787 |
Rep 40,765
It depends on what Head Unit car has.
08-12-2019, 07:08 AM | #14789 |
Rep 40,765
08-12-2019, 07:40 AM | #14791 |
Rep 40,765
08-13-2019, 09:40 AM | #14792 | |
Rep 490
08-15-2019, 07:04 AM | #14795 |
Rep 40,765
PM sent.
08-16-2019, 03:12 PM | #14796 |
Rep 15
Drives: 2017 BMW 320d M-Sport F30
Hi Shawn, hope you are well.
Please send me the link to the latest esys software. Much appreciated. |
08-16-2019, 03:15 PM | #14797 |
Rep 40,765
PM sent.
08-16-2019, 03:20 PM | #14799 |
Rep 40,765
PM sent.
08-17-2019, 12:51 AM | #14800 |
Rep 40,765
PM sent.
08-19-2019, 03:00 AM | #14801 |
Rep 4
new data files?
Hi Shawn,
My 340i recently had a DME update from the dealership. All my coding was wiped; and now when I tried to re-apply the same coding, for HU_NBT2, E-sys now says it cannot read coding data: CAFD_00001EF6_006_040_006 Fehler: File for "cafd_00001ef6-006_040_006" not found! [C012] I am currently using e-sys 3.27.1 with v.4.16.10_PSdZData_Lite. Is there a newer version for PSdzData? Would you mind sending a pm? Thanks!! |
08-19-2019, 03:59 AM | #14802 |
Rep 2
Hi Shawn,
Can I ask for the links also? I must code new REM module (from the junkyard) with correct pin numbers for the rear PDC. As I undestrood, I must download PSdZData_Full version to code it? I want also to change area code from US to EU. In this case PSdZData is also required? Thank you in advance |
08-19-2019, 06:50 AM | #14803 | |
Rep 40,765
08-19-2019, 06:51 AM | #14804 | |
Rep 40,765
PM sent.
08-20-2019, 10:28 AM | #14805 |
Rep 31
I need latest links and info please - I'm traveling to Portugal next week and my friend has asked me to help code his 2012 F30. Was hoping I wouldn't have to lug a windows laptop but sounds like that might be the only option... Thanks in advance.
08-20-2019, 10:35 AM | #14806 |
Rep 40,765
PM sent.
