03-11-2019, 04:48 PM | #157 | |
Rep 98
ottobrill me chama no whatsapp 047-99110-7262
03-22-2019, 05:30 PM | #159 |
Rep 63
03-25-2019, 11:54 PM | #162 |
Rep 27
Code
Try this 5YJJQZA4FE2FIAFIAA7A or this lifetime code QII4WNCJ2KXIKAFIAD7Q
03-31-2019, 08:56 AM | #163 |
Rep 3
Hello great tool!
Could I get some assistance. Map type: Next Region: North America Map: Road Map North America Next 2019 -1 Vin: D085279 production date: 08/16 If you can generate codes regular and lifetime great, also what date would I select since there are only 2 options for 2016? TIA |
04-10-2019, 01:49 PM | #165 |
Rep 2
Hi all,
i'm trying to find the best software to download the 'DE' FSC file from my F32? I have an ethernet cable but I cant work out the dodgy software that came with it. I dont need to code anything i just need the FSC code so i can install the maps ive downloaded. Ideally some free software would be great! Thanks |
04-10-2019, 09:29 PM | #166 |
Rep 2
I have generated both life time code and one time code, however none of them works. I am wondering if the code generator works for BMW X5.
Can someone help generate life time code and one time code for me? VIN: 0C28434 Production date: Oct 31, 2013 Map: North America Next 2019-1 Thanks, |
04-12-2019, 01:33 PM | #168 |
Rep 7
Same issues as above.
I cannot get the 4 codes I tried to work properly.
Vin: NP32613 2014 328i North America NEXT 2019-2 I have the entire file loaded on to a usb successfully already. |
04-17-2019, 02:57 AM | #169 |
Rep 21
FSC not generating FSC for Europe Next 2019.1 ?
Hi all,
I try to generate FSC code for Europe Road Map Next 2019.1 but no luck. Anyone else have same problem, I try to generate Lifitime and normal one, same thing, all codes are incorrect. If someone else could try to generate VIN: G220934 Europe Road map Next 2019.1 This is first time in 4 yrs I need FSC for my retrofitted NBT. Every time was only to update without code. I have E sys and I done this couple of times, but now when I need it something is wrong Maybe because is retrofit? Any help is appreciated. Thanks |
04-17-2019, 03:44 AM | #171 | |
Rep 21
Navigation is locked now. UPDATE: After reset all good, back to state before navigation locked... So I'm back to 2018.2 If someone find solution for Europe Next 2019.1 please let me know. Thanks Last edited by starmanbl; 04-17-2019 at 04:04 AM.. |
04-21-2019, 12:46 PM | #173 | |
Rep 417
The 1b file attached already had a hex file inside, and the content is different from OP's 1b. The usb in the armrest didn't help pulling the hex file on my F32. I will try installing the usb in the glove box area to see if that makes a difference. If not, I at least have another usb port |
04-23-2019, 03:56 AM | #174 |
Rep 121
Hi
I have BMW X3 2016 (F25) with Professional Navigation. Using a VIN decoder I have found following which may relate to navigation system
Do I need CIC or NBT to generate FSC code? Please advise me what type of maps shall I download for UK? I have seen CIC, MOVE, NEXT etc. and I am not sure which type of map will be valid for my car? Does BMW provide OTA updates for maps and are they free? |
04-23-2019, 06:33 AM | #175 | |
Rep 21
When you download map, you will find out do you need FSC or you already have Lifetime code installed, or you still have free update from BMW... I did update mine 3 times for free now I need FSC... Hope this helps |
04-23-2019, 06:38 AM | #176 | |
Rep 21
1B is for CIC (Older unit) Most likely your BMW 4 series have NBT not CIC. Hope this helps.... |
AK415196.50 |
