07-17-2018, 05:52 PM | #1 |
Rep 10
Using different tire sizes.
Hi guys. I'm driving a 2019 440i coupe M sport package. I have 19 inch rims and am running with 225/45 R19 tires on the front and 255/40 R19 tires on the back. Now the car actually calls for 225/40 R19 on the front and 255/35 R19 on the back. Could there be any side effects or damage by using the tires i'm using now? Besides extra noise, if that's a possibility? There seems to be no sign of rubbing or wear on anything. Thanks!
07-17-2018, 06:37 PM | #3 |
Rep 10
Thank you for your reply. Would this small difference in side wall height be a cause for any extra noise? Or, if you know, can there be noise coming from the used run flats I am using?
07-17-2018, 06:40 PM | #4 |
Rep 701
Ok so you have a 2019 and you got used runflats with wrong size? What i am missing here?
The noise you are hearing is probably from the runflat tires themselves. They are loud. There is a reason why everyone hates runflats. Go get a nice set of summer tires in the correct size and the noise will go away and the car will feel MUCH MUCH better. The best mod you can do to your car is to ditch those runflats. |
07-17-2018, 07:06 PM | #5 | |
Rep 10
07-17-2018, 07:42 PM | #6 |
Covert
Rep 29
Yes, runflats can be noisy but there are non-runflats that can be noisy, too. You've probably noticed that the surface condition of the road you are diving on can contribute as well.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over) 2014 335i/Auto (F30), Mineral Grey/Black (lease over) 2017 340i/Auto (F30), ED Order, Estoril Blue 2/Black |
07-17-2018, 08:31 PM | #7 |
Rep 68
Drives: 340i M-sport
I worked for Bridgestone as a High Performance marketing and education specialist for 11 years.
The only difference in a runflat tire is a banana shaped insert in the sidewall. Many people have jumped on the bandwagon. The original runflats were heavy and crude. Just like your iphone, this technology has improved over the years. Runflats play an important part in today's automotive technology. the noise comes from the tread pattern and possibly irregular tread wear. That said, the post was about an incorrect size. With today's cars including ABS and DSC the overall diameter is important. With a different ratio than OE front to back, the driver nannies may operate at different thresholds. With an additional 25ish mm in overall diameter the system may not work as the engineers designed. Example, the ABS may see the front brake lock early and release some brake pressure. |
Machinebuilder278.50 |
07-17-2018, 08:37 PM | #8 | |
Rep 16,065
OP, the rear tire is maybe a half inch larger in diameter than the front. That won't cause any problem in and of itself. However, by going with a smaller aspect ratio in the 19s to compensate for the change from 18s the tire sidewalls are shorter, and that can result in more noise and a harsher ride. That's always a trade off to consider when you increase wheel size. Rubber absorbs both noise and road shock, aluminum doesn't. |
07-18-2018, 10:53 AM | #9 |
Rep 701
I dont know about MXM but if you are telling me that RFT are the same as summer tires, which i recommended. Then i guess one of us is imagining things.
I assume MXM is all season, i am not sure since i have not used all season tires for decades. I have not met anyone who Loves runflat for their performance, quietness or durability. |
07-18-2018, 10:57 AM | #10 | |
Rep 701
Do you know how many miles did the used tires have? There is 1 way to know for sure, put your stock 18s back on and see if there is any noise and you will know if it is the used tires. If you wanna use them up, that is fine. Just have to live with the noise until they are worn. I assume there is no vibration, just noisy? |
07-18-2018, 12:34 PM | #11 | |
Rep 10
07-18-2018, 12:44 PM | #12 |
Rep 701
Yes unevenly worn tires will cause weird noises, especially at higher speed or when you start accelerating from dead stop.
I am not sure what kind of "noise" you are hearing, but if it is just noisy in general, then it is probably "normal" but if it is the "weird noise" only at certain speed, then it could be other things like balancing. But you can inspect the worn pattern. If it is obvious enough for your eyes to see, then it is most likely the reason. But based on my personal experience with Runflats, they are louder than summer tires, especially when they are somewhat worn. |
07-18-2018, 12:45 PM | #13 |
Rep 1,503
I’d just use up the tires and switch to the correct size once they’re done. It’s hard to comment on the noise since it’s so subjective, but in general unless there’s something mechanically wrong at the wheel level (e.g. bad bearings) then tire noise can/should be ignored.
With the slightly taller height your speedo will read a touch high. BMW speedos already read 2-3 mph high anyway, though. |
07-18-2018, 01:15 PM | #14 |
Rep 16,065
The OP made no mention of summer tires, so neither did I. BTW, RFT are available as summer, A/S and winters. My RFT are A/S, so were the Michelins I had on my last car, so I made an apples to apples comparison. Not having tried RFT versus non-RFT summers I can't make any comparison there.
01-22-2020, 03:25 PM | #17 |
Rep 87
Different tires produce different amounts of road noise. The tires you have now are likely just louder than the ones you had before.
I'm still running run-flats because I am regularly driving 100+ km away from "civilization" and I don't feel like being stranded waiting 4 hours for a tow truck. I really don't like runflats, but I also don't want to have a donut taking up trunk space permanently either. If I was only ever driving in the city where tow trucks are always available I would definitely switch to regular tires. |
Tags |
440i, coupe, size, tire |
