07-31-2021, 06:22 AM | #3763 |
1296
Rep 3,533
you know, you're right. just send it!
Pussiwillow521.00 |
07-31-2021, 10:20 AM | #3764 |
Car Hypochondriac
335
Rep 901
If you weren't aware, our post-cat o2 sensor is a wide-band. it measures the A/F for the DME.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
07-31-2021, 11:46 AM | #3765 |
1296
Rep 3,533
it's the precat 02 actually.
07-31-2021, 12:11 PM | #3766 |
Car Hypochondriac
335
Rep 901
You're right, my mistake!
I bought a spare upstream a while ago just as precaution. FCP had a really good sale on them a year or two ago.
07-31-2021, 10:11 PM | #3768 |
1296
Rep 3,533
best thing you can ever do lol
08-02-2021, 04:56 PM | #3769 | |
Rep 7,607
08-03-2021, 01:04 PM | #3770 |
Shima Tatsuya
45
Rep 61
It was a legit question. If you don't ask you don't learn.
Current:'15 BSM F32 435i Msport, FBO, BM3 stg 2
Previous: E36 328i->F30 320i->F32 428i IG: Blackbird_f32 |
08-03-2021, 01:05 PM | #3771 |
Shima Tatsuya
45
Rep 61
I was not aware. Thank you for the knowledge.
08-03-2021, 01:15 PM | #3773 |
Shima Tatsuya
45
Rep 61
I saw the correction. Thank you all for the lesson on o2 sensors.
n55david1295.50 Eschmacher334.50 |
09-15-2021, 02:05 PM | #3775 |
Rep 643
what's your previous experience?
M235i rwd 6mt
09-15-2021, 03:45 PM | #3776 |
Rep 931
09-21-2021, 07:27 PM | #3777 |
Rep 367
Finally dropped down to stage1 91 after getting sick of adding 2.5 gal of E85 every fill up. Log seems OK. It's a pretty weak log but I just wanted to verify timings and no knock. Im surprised the timing arent better.
STOCK (time 2.180) STAGE1-91: (time 0.260) STAGE1-93: (time 0.550) Is there any way to get something like 15PSI target? Sucks to drop from 16 to 14 because the gas sucks here. I'd try an Ethanol map but the only one on BM3 is the Stage2+ E30. Google says its unwise to try that with stock cat. Should I just accept my fate of adding E80 (as tested) to the 93 and using the 93 tune? Is it even a good idea to use E80 since the other 20% is junk gas? |
09-22-2021, 12:42 AM | #3778 | |
Rep 7,607
BM3 has more than just the stage 2+ map or E30... They have stage 2 and probably even stage 1 (not sure about the latter no one ever logs it). Stage 2+ has nothing to do with DP persay, although DP is still required since it is for everything 2 and above, stage 2+ relies on HPFP. That extra 1psi is doing nothing if timing is worse. You need timing to make power. Slightly lower boost with more timing probably makes more power anyways. Also why would you say the non-ethanol portion is "junk gas" - what is that based on? The ethanol maps makes the most power so if you are mixing E85 already you might as well the E30 map appropriate for your mods. |
09-22-2021, 07:33 PM | #3779 | |
Rep 367
For the E85, I thought I had read somewhere it was low grade (low octane, low detergent, etc). It seems to make sense if its sold as a budget item to mix 87 or worse instead of 93 and still sell "up to" E85. |
09-22-2021, 08:00 PM | #3780 | |
Rep 7,607
I've never heard that about E85 and the key thing is the ethanol content anyways (and in turn the octane). As long as you know the ethanol content you can mix accordingly and run the ethanol maps. I would also note that some people choose to run maps that "require" a DP without an aftermarket one, but i wouldn't. |
tardboi82.50 |
09-22-2021, 09:48 PM | #3781 | |
Rep 931
tardboi82.50 |
10-30-2021, 01:13 PM | #3782 |
Rep 8
Anyone have experience with BM3 as a beginner? I have a 435i that I'm planning on going stage 2 on. Have been hearing a lot of good stuff about BM3 but I'm kinda new to it.
Detailing shop in Europe: www.CustomCarCare.eu
Currently building one of the biggest BMW online store's in Europe. Stay tuned! |
10-30-2021, 01:58 PM | #3783 |
1296
Rep 3,533
we were all beginners with bm3 when we got bm3...
10-30-2021, 02:58 PM | #3784 | |
Rep 7,607
https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
ronanz1819.50 |
