04-07-2016, 02:57 PM | #89 |
Supreme Allied Commander
3839
Rep 54,348
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
04-09-2016, 11:05 AM | #91 |
Rep 123
So the conclusion is none of the front components of the f80 will fit on xdrive? Is there anything that can be done to get more negative camber and improve the handling of a car with xdrive?
G21 M340d Touring - Skyscraper Grey over Cognac interior
04-09-2016, 11:18 AM | #92 |
Rep 1,084
04-11-2016, 02:31 PM | #93 |
3839
Rep 54,348
Drives: F80 M3
04-22-2016, 07:13 PM | #94 | |
Rep 4,323
HPA ones are for front for sure. I think two of the Megan ones are for the rear.
04-27-2016, 11:19 PM | #95 |
3839
Rep 54,348
Drives: F80 M3
05-25-2016, 04:29 AM | #96 |
Rep 186
Hi, so in conclusion, only the OE F8x front LCA would fit the F3x platforms, but the TS wouldn't fit?
And even without the TS, the benefits would still be there? |
05-25-2016, 05:04 AM | #97 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
05-25-2016, 05:16 AM | #98 |
Rep 4,515
Read this thread, particularly page 3 , post nrs 45 and 50
Current '22 X3M LCI.. |
05-25-2016, 08:21 AM | #99 |
Rep 186
Yeah, i have read those. But that was no conclusion on how this would affect suspension geometry as pointed out in another post here.
utenigma , he seems to have installed just the LCA. Any issues so far? Have u tracked with the setup? |
03-26-2017, 09:27 PM | #101 | |
Rep 3,946
Suspension: Either BMW M Performance Suspension Kit or Ohlins Road and Track coilovers. Wheels: APEX ARC-8 18x8.5 ET38 (no spacers) Tires: Michelin Pilot Super Sport 255/40/18 The wishbones sounds like a modification that will requirement an immediate alignment afterwards before even leaving the premises. |
03-27-2017, 03:01 AM | #102 | |
Rep 4,515
My reasons for installing these OEM parts were - steering lacked feel; - slow to turn-in and - soft outer shoulders of MPSS tyres were wearing prematurely. LCA (initially] and TS (fitted later on) are an OEM upgrade that sorted out all of the above foibles. After adding M4 TS's to pre-installed M4 LCAs - Geo - No impact on geo from having f8x LCAs pre-installed. Visuals - Front ride height up a smidge. Front wheels now sited back in the centre of the arch. Steering feel is same [IMHO] with LCA + TS as it was with LCA's only. Braking - much sharper as one might expect with firmer TS bushes but this is marked improvement esp with my setup MPBBK, M4 sport pads and SS hoses. NVH - slightly more in comfort but no change in sport+ mode - I think firmest adaptive damper setting is better suited to my aftermarket springs. No regrets at all and TBH I'm happier now that I have matched LCA & TS as opposed dissimilar F8x LCA and F2x/F3x TS. BP
03-29-2017, 08:47 AM | #103 |
Rep 99
Gentlemen, while I have had a few BMW's over the years and have done a ton of work on them myself, I am a novice at understanding suspension geometry. Sure, I can change out suspension parts but understanding the impact of subtle or major changes is not something I fully grasp.
So, given the conversation throughout this thread I wanted to ask the opinion given the following; 2015 335 M-Sport (5 hole struts) 225/40/19 tires on style 442 wheels w/36mm offset (soon to be fitted with Michelin PSS) What can I expect by swapping in the F80 LCA? Better camber, worse caster, alignment needed right? I don't track the car but drive aggressively both on windy roads and the highway in terms of straight line speed. Also, I see a few comments about wear to the outer portion of the tire being improved on PSS tires. The comments gave me the impression that the PSS wear excessively on the outer edge otherwise. I was about to pull the trigger on PSS and one of the primary reasons of switching away from the OEM P-zeros was because of the increased UTQG rating of 300 vs other tires in the low 200 range (softer and more wear). I just want to still have confidence in buying the PSS regardless of whether or not I swap in the F80 LCA. Thanks! |
03-29-2017, 11:12 AM | #104 | ||
Rep 1,291
Better camber for sure, increased caster unless you also fit the F80 Tension struts, you'll love it for windy roads. Alignment is more than needed, the LCA will completely change the toe so you can't even drive out. Quote:
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
04-13-2017, 07:55 AM | #105 |
Rep 1,291
Hi
So we installed the tension struts yesterday, using lemforder f30 bushings instead of f80 original bushings and a little help from a hydraulic press This has allowed the wheel to go back a little bit, really not much, but rubbing seems to be gone now
04-13-2017, 10:49 AM | #106 | |
Rep 1,291
http://www.realoem.com/bmw/enUS/show...diagId=31_0994 Part #31216856535 / 31216856536 are compatible with X Drive I have no idea what the complexity of installation is though.
Polo088161610.00 |
04-13-2017, 01:30 PM | #107 |
Rep 1,291
A few more pictures for those who are interested in this alternative way of using F8x Tension struts:
You can see the wheel remains quite a bit forward in the wheel pit, the other side is worse as there is slightly more caster.
04-28-2017, 12:25 PM | #108 |
Rep 1,291
For those interested I'm selling these 2 wishbones + 2 tension struts as I'm getting the car back to stock.
http://f30.bimmerpost.com/forums/sho...4#post21627774
04-28-2017, 01:55 PM | #109 | |
Rep 4,515
04-28-2017, 02:10 PM | #110 |
Rep 1,291
Haha no, but things are complicated with french road regulations, more than anywhere else in Europe and i can't really do what i want, so i'm considering changing to an F80 M3 base when i get a chance to get one at good price, e90's are nowhere to be found (many e92s but i need 4 doors...).
