BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Single zone climate (basic) to two zone climate (high) F30 DONE
Studio RSR
      02-07-2017, 12:34 PM   #23
il_sovero
il_sovero's Avatar
Drives: 218d Msport
Originally Posted by atzebmw View Post
Here the values from my 07/2015 F30 LCI.
Ecu isn't named IHKA, but IHKA_VA02
luftverteilung_art -> 2-zonig
innentemperaturerfassung -> uif_valeo
schichtungspoti_vorne -> ein
mischluftregler_fahrer -> regelung
mischluftregler_beifahrer -> regelung
beluftungs_temperatur_regelung_vorne -> regelung 2-zonig
klimageraet -> L7 high
klimastile -> fuenf
beschlagsvermeidung -> aktiv
auc -> aktiv
solarsensor -> aktiv
msa_schubansteurung -> nicht_aktiv
kmv_aktiv_beschlag -> aktiv
Thank you so much!
Is your panel shifting from white/amber or is always amber?
      02-07-2017, 01:04 PM   #24
atzebmw
Drives: Tesla Model 3
Originally Posted by il_sovero View Post
Thank you so much!
White/Amber
      03-17-2018, 12:36 PM   #25
Nunaat
Drives: E34 525tds F33 420d I01 bmw i3
Hello guys, I am interested about changing Ihka basis to ihka high display only.
I connected panel unit and almost everything work but i have some issues>
The temp is always 16 degrees
The wheel temperature doesnt work. The control panel is lci and my car is dated from 07/14. Do i need to install anything or only i must code the ihka and fem ecu
Thanks.
      07-02-2018, 10:20 AM   #26
zx9r1
zx9r1's Avatar
Drives: e92lci & f31
Hello I'm going to perform an exchange Klima basic on high. Need scheme cable
sensor AUC : 64119240180 - which pin cable ??
solar sensor : 61359293279 - which pin cable ??
larry_bml You have Connection diagram ?
      07-03-2018, 02:12 AM   #27
larrybml
Drives: X3 F25 2011
My inbox folder is empty even you sent me me private message, I don’t know why, but anyway diagram you can find it in Rheingold.
      07-03-2018, 05:25 PM   #28
zx9r1
zx9r1's Avatar
Thanks for the answer. I try to download, I have a problem with the installation Rheingold. ;(
larry_bml194.00
      06-12-2019, 11:36 PM   #29
Johny212
Drives: F30
Is it possible to "update" the single-zone to two-zone climate? F30 LCI
I compared the part numbers such as, the heater - and they are the same as in cars with dual zone air conditioning ...
In general, the F30 with single zone ceiling is a rarity ...
I know that there were topics about older models like E90, but the heater was different there - unless, real parts are not the same as realoem.com shows..?
What is different then? Probably amount of air conditioning factor is different but what is comes from?
Europe version VIN - K686509
      07-14-2019, 08:40 AM   #30
rogankushaf
Drives: 118i f20
Hi guys, hi larry you did a very impressive work! Congrats! Since It's too much for me i would like to just change the control panel of my single zone with the one of the dual zone but I would like also to know if the single zone could provide the air flow to the rear seats if the proper pipes are added from the front to the rear under the tunnel. Could you help me? Do you know something about that?
Thanks in advance
Rog
      07-14-2019, 09:12 AM   #31
larry_bml
larry_bml's Avatar
Romania
194
Drives: BMW F30 Sport Line 320ded
Hello, NO, single zone can not deliver air in the back. And also, if you change only controllers , it I’m not sure that it will work.
      07-18-2019, 06:32 PM   #32
rogankushaf
Drives: 118i f20
Ok.
About the controller it seems that a guy in an other forum didi it with success. He posted also the few coding instructions that he applied.
Thanks
      09-13-2019, 04:11 AM   #33
B---WLF
Romania
Drives: 2011 E92 320d xdrive
can you post those coding here? i would change only the control panel if possible
      10-02-2019, 02:27 AM   #34
Nunaat
Hi everyone. I got all the hardware for retrofit my basic ihk to high IHKA. I only need to Know If I must drain air conditioning system before change heater box with new ecu. that is, do I need to take out all the gas from the air conditioner?
Thank you larry and others.
F33 420d, E34 525 tds
      10-02-2019, 02:31 AM   #35
larry_bml
larry_bml's Avatar
Romania
194
You don't need. Close valves from pipes only, before disconnecting them
      10-02-2019, 04:41 AM   #36
bartusx
Drives: F10 525D 2012, F30 2013 318D
Hi guys.
I need to change my airbox (basic) in f31 2013.
And i can get cheap another one but from f31 (high) 2016(facelift)
Can i change and connect it plug and play ? Without any problems?
      11-03-2019, 10:18 AM   #37
Nunaat
yes you can. i am doing this retrofit right now. but you must change more pieces and use esys to Code and program.
      11-03-2019, 10:30 AM   #38
Nunaat
Next step
the Next weekend i Will finish the retrofit (i Hope so). i must drain the f134 gas and change the Air and heater box. all wires are disconnected and all pins in FEM were installed and changed.
      11-19-2019, 07:06 AM   #39
Zikkun
Morocco
Drives: BMW F36 420D Gran Coupe
Hello Guys,
I am a happy owner of a 2016 f36 and would like to know what parts would i need to have a dual zone digital climate control working.
Thanks a lot.
      11-20-2019, 02:29 PM   #40
Nunaat
finally I got the two zone ihka klima working. I changed the dash with a new M4 leather one.
      11-20-2019, 02:33 PM   #41
Nunaat
the great problem is changing the klima box with f134 gas and antifreeze water. i can help anyone if needed.
      11-20-2019, 02:35 PM   #42
Nunaat
It is an adventure, but i am Happy.
      12-13-2019, 11:58 AM   #43
MD20
Drives: Alpina B5 & BMW F20
Hey Larry, how do you close the valves? Couldn't see a way to close them? I really don't want to drain the system and my airbox arrives over the weekend Thanks in advance
      12-13-2019, 01:19 PM   #44
larry_bml
larry_bml's Avatar
Romania
194
Ask Nunat please, for AC system a friend helped me, don’t know what he did exactly.
