10-03-2020, 08:36 AM | #1 |
Rep 26
Yellowish marks and asphalt on car paint
Hi everyone,
Any advices how I could remove those marks from car paint at home? I had similar yellowish marks on rims as well and I removed it with thing which is called hydrochloric acid (could be wrong). But I think it would damage car paint. |
10-03-2020, 10:58 AM | #2 |
Rep 298
I use Autoglym Intensive Tar Remover, if that is not available in your area get something similar:
https://www.autoglym.com/intensive-tar-remover If something is still left after that then next to try is clay or mildly abrasive polishing product. |
10-05-2020, 09:51 AM | #3 |
Rep 849
Drives: BMW 435i
Stoner's Tarminator is also a good tar/asphalt removal product if available.
10-05-2020, 10:52 AM | #4 |
Rep 16,054
It's got to be available somewhere in the world.
OP, there's a reason why the forum allows you to state your location. If you need location specific advise and you're in Katmandu a reply from Ulaanbaatar won't do you much good. |
Onizukachan1076.00 |
10-06-2020, 02:17 PM | #5 | |
Rep 26
Eastern Europe Thank you everyone. I will try your suggestions. I'm worried about those yellowish things |
10-23-2020, 04:42 PM | #6 |
Rep 2,047
The yellowish things look like iron deposits (probably from the brakes) sitting on the paint and then rusting. Something like Bilt Hamber Korrosol (look for iron/fallout removers on a local detailing suppliers for an equivalent) will remove that easily enough and isn't anything to worry about. It's always more prominent on white and silver cars.
11-11-2020, 02:30 PM | #8 |
Rep 26
Status update:
Ok, so I haven't found "Autoglym Intensive Tar Remover" or "Stoner's Tarminator" at any local shop so instead of that I tried "CarPro TarX". It was quite disappointing. It took like 2 hours and a lot of scrubbing to remove all those tar marks. But I believe it is not only product fault. Those tar marks were quite big. As for those metal fallouts I was able to get "Bilt Hamber Korrosol". It was amazing. Just like in those Youtube videos: sprayed all over my car, it became pink and after power washing it looks as new. But I had to do it twice to get it off those small gaps. All that work took some time but it was soooo worth it. My car looks so shinny and clean. Again, thank you everyone! |
zeikei124.50 Onizukachan1076.00 |
