BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Cold starts (even if disabled) with BM3
      11-23-2020, 11:18 AM   #1
MaximusJ
MaximusJ's Avatar
Drives: 340Xi MG 2017
I'm currently with Bootmod3 stage 2 Oct 91 with cold start deleted. Most of the time, everything is fine, but on a random occasion, when I start the car it's still gonna do a cold start. And my DP being catless, it's quite obnoxious when that happens. And OF COURSE, this has to happen early in the morning; waking up the whole neighborhood.
This is getting annoying to the point where i'm considering my options. Even if that means going with another tune option. I hate to be "that guy" that bugs my neighbors.
I thought of reflashing with the latest version of the map; but knowing that everything was fine for months (and no reflash since i've installed the DP) makes me think there might be something else.
Is this ever happened to anyone before? Found a fix to your problem?
Thanks for sharing if you have any history with a similar problem.
Mineral Grey '17 F30 340XI
[Garage] // [Build Journal]
Jet Black '06 E90 325I
[Garage]
      11-23-2020, 11:30 AM   #2
dawidd3
Drives: F30 340Xi B58
Do DME to Stock then reinstall Stage 2 RON91.
      11-23-2020, 01:23 PM   #3
not1337
Drives: 2016 340i
I would reflash, I have mine deleted and it never returns randomly.
MaximusJ301.00
      11-23-2020, 09:26 PM   #4
MaximusJ
MaximusJ's Avatar
I did, but with the same version of the flash I had; which was fine; until recently.
But flashing back to OEM; then with the new Stage 2 map is what i'm going to try next. But even if I know this will probably fix it, i'm more curious about "why".
[Garage]
      11-29-2020, 07:56 PM   #5
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
I'm MHD with cold start delete, I've never had this issue.
      12-03-2020, 03:17 AM   #6
about94ninjas
about94ninjas's Avatar
Drives: ‘18 340i
Not really a solution but if it does still do a cold start, very lightly press the gas pedal. And I mean very lightly, you'll see when you do it. Shuts it right up. I'm straight piped turbo back and i do that every morning. It's annoying to sit there until the cold start is over, but at least I'm not that guy lol
Aldor2787.00
      12-03-2020, 07:51 PM   #7
Wires
Drives: 2016 340i xDrive
I did the cold start delete on BM3 S2, and have never had the cold start return. I'd try what other said and go back to stock and back to S2.
      12-04-2020, 08:24 PM   #8
les anderson
Drives: 340i
Weirdness is typically solved by reflashing.
      01-18-2021, 10:22 AM   #9
MaximusJ
MaximusJ's Avatar
I reflashed the ECU and everything was good; until yesterday when the cold starts started happening again. I deleted my map; redownloaded a fresh one and reflashed. But this time i've reset my adaptations. Not sure if it'll change anything but still did it anyway.
If this issue comes back, i'll contact PTF directly and if this still fails, i'll start looking for other solutions outside of bootmod3. I'm still puzzled as to why it would perform as intended for some time and then ignore bm3's map settings.
I guess my only option would be to change tune; but I'm still convinced there's a solution to this issue.
Am I the only one having this issue?
[Garage]
      01-18-2021, 10:53 AM   #10
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
Is your startup roar still on? The roar seems to last a bit long on cold days on my car, turn the roar off and should be good. hopefully
      01-18-2021, 11:11 AM   #11
MaximusJ
MaximusJ's Avatar
It was first at OEM but left it as default for the second flash. That was my first guess also. But to my understanding, the roar only activates when the engine is warm? And my issue only happens when the engine is cold.
[Garage]
      01-18-2021, 02:31 PM   #12
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
Mine happens on startup regardless of engine or external temperatures.
MaximusJ301.00
      01-18-2021, 06:23 PM   #13
G.Newt
Drives: CT4-V Blackwing 6MT
Okay so I also live in a cold weather state. Before I got my garage, on really cold mornings where I haven't started my car for a long time, it would do a normal cold start. On EXTREMELY cold mornings, it wouldn't even do a non-cold start. Literally only goes to 600rpm and stays there until it can safely bring up the rpm.
All of this was with BM3. I think there's another mechanism in place that overrides depending on extreme temperatures. Now that I'm garaged, it does a normal, non-cold start everytime. This is for sure 100% temp related.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-19-2021, 03:04 AM   #14
parch8
Drives: %E2%80%9816 340i xdrive alpine
I had the exact same experience myself spoke to them, reflashed the same map and it resolved it and hasn't happened since.
      01-19-2021, 12:17 PM   #15
MaximusJ
MaximusJ's Avatar
I also saw a relation between the morning temp and the cold starts.
[Garage]
      01-19-2021, 12:19 PM   #16
MaximusJ
MaximusJ's Avatar
I reflashed after my last visit at the dealership and the car was ok for 6-7 days until it resumed the cold starts. I reflashed yesterday with a freshly downloaded map and it now runs ok. Time will tell.
I opened a ticket on PTF's support site in the meantime. Glad to hear that it's a known issue. I first thought there might be a bigger issue than the tune itself. The car is going out of warranty in 6 months.
[Garage]
      01-19-2021, 02:43 PM   #17
parch8
Nope you're not alone! Luckily PTF responded very quickly to me and they are super helpful so I'm sure they will be able to help you if this doesn't work but I'm hopeful it will for you since it did for me. Computers are weird like that sometimes repetition fixes stuff like this sometimes not.
      01-20-2021, 06:43 AM   #18
MaximusJ
MaximusJ's Avatar
I think it's quite the opposite. When a code is written to do something it should do it times and times again. There's definitely something that triggers the code to fail under certain circumstances that the initial code wasn't wrote to consider. Luckily these guys are on the ball and hopefully they can improve the map so it deletes the cold starts under all kinds of weather.
Aaaaaaand it happened again this morning. Luckily I already had a ticket opened on PTF's site so i'll update it and update this thread when they successfully find a permanent solution.
Good news is that I apologized to my neighbor about it and he said he didnt ear anything (After a good 20-30 of these loud starts at 7am in the morning); so that's at least that
[Garage]
      01-21-2021, 04:15 PM   #19
MaximusJ
MaximusJ's Avatar
Can you remember what changes you made that got rid of your issue?
As of now, I tried a few things but since the car misbehaves only when it's ice cold in the morning, I can only make one test per day.
So far i've tried
- Minimum speed to 50; didnt work
- Force the flaps closed; (will see tomorrow morning but I dont see how this can lead the engine to not perform it's cold start, but I will try it anyway)
Next suggestion is to deactivate the active sound; which I thought the B58 didnt have. But again, if that works and that means i'll lose my burbles, this isnt an acceptable solution to me. But i'll keep working with them.
[Garage]
      01-22-2021, 07:26 AM   #20
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
So far i've tried
have you tried turning off the roar function yet?
      01-22-2021, 09:21 AM   #21
MaximusJ
MaximusJ's Avatar
yes, that was the first thing I tried.
[Garage]
      01-22-2021, 11:10 AM   #22
parch8
So far i've tried
All I had to do was reflash the map I had installed and it resolved it for me I didn't end up having to do anything else to resolve mine.
