01-06-2021, 03:53 PM | #1 |
Rep 57
TPMS for winter wheels
I want to retain my TPMS on my winter wheels. Do I just need sensors in my other set of wheels and everything will just work when I switch?
Where do you get your sensors? 2016 340xi if that matters. |
01-06-2021, 04:06 PM | #2 | |
Rep 5,392
I put my winter wheels on a month ago. I believe that I just went on the iDrive screen and reset the TPMS. Pretty simple. Last year when I checked, TireRack had a good price on them. There are several companies that make them. I needed one for a spare tire and bought one made by VDO. Part numbers on box say: VDO SE52056 TPMS TG1C 433 Mhz Tech Support 800-265-1818 My car is a 2015 335ix so it's possible that the same units are used in 2016. Hope this helps! |
01-06-2021, 04:07 PM | #3 |
Rep 5,392
Photos of VDO box
01-07-2021, 08:01 AM | #4 | |
Rep 849
Drives: BMW 435i
While you should be able to reset the TPMS manually from iDrive according to the manual and all other documentation, my car will not allow this to happen. I have to drive around for a couple minutes until an error message appears on the screen which has "Reset" as a selectable option. Not sure why, but this has been consistent after three wheel swaps. After the error appears and the reset happens, everything is fine.
01-09-2021, 03:41 AM | #7 |
Rep 178
Sorry for hijacking the thread, but i have a question regarding the sensors aswell. Can you disable the pressure monitoring to get rid of the warnings if you dont use sensors with bimmercode for example?
01-14-2021, 03:17 PM | #8 |
Rep 943
Drives: F30 328i Msport
I briefly tried, no go. Just got a set of tpms sensors to replace my old ones from amazon, waiting to get new tires to just put them on to avoid the extra installation fees.
01-15-2021, 07:05 AM | #9 |
A family of bimmers
2745
Rep 7,741
01-16-2021, 04:16 AM | #10 | |
Rep 178
No fun expense, but i bit the bullet and ordered myself a set from eBay |
RMachuca3d722.00 |
