01-06-2019, 08:38 AM | #1 |
Rep 11
Heater Woes
So a week into ownership and it looks like it's time to call on the warranty
Heater seemed to be working but a little noisy so I removed the fan to check for leaves. The motor is spinning fine in the footwell, changing speed with the controls as expected. There were no leaves found, so I reassembled everything and now there is no air blowing though at all, I've had the motor out a second time to check I've reassembled everything ok and the motor seems fine when not fitted into the housing. I then took the car to get the aircon checked incase the gas was low and the tech noted that the AC wouldn't kick in despite the correct amount of gas being in the system. I can hear the vents changing when you adjust where the air should be coming from but I don't get any airflow. Any ideas? I'd like to rule everything out before potentially losing the car for a while. |
01-06-2019, 10:13 AM | #2 |
Rep 3,216
Well, lots of warranties have the equivalent of 'amateur has fucked about with it and made it worse, so no longer under warranty' clause.
Might I suggest the first step being this : you stop digging the hole even deeper. Second step being : call the dealer, and let people who actually know what they are doing play with it. |
01-06-2019, 10:38 AM | #3 | |
Rep 1,487
If you have warranty buddy, use it and call them!! |
01-06-2019, 10:56 AM | #4 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
01-06-2019, 11:00 AM | #5 |
Rep 10,249
To satisfy natural human curiosity, investing in model specific technical maintenance manual is a good first step - if you plan to keep the car.
During the warranty: read the manual but take the vehicle to the dealer. After the warranty: read the manual and follow repair steps. Earlier comments about using the warranty make perfect sense. |
01-06-2019, 12:42 PM | #7 |
Rep 542
Warranty or not.
If the noise relates to a foreign object or something that has not actually failed, you will get a bill. OP was probably just trying to avoid this. Does nobody fiddle with things these days?
335d xDrive
01-06-2019, 01:33 PM | #8 |
Rep 8,489
A load of generally unhelpful soapbox replies to the OP's question.
OP - there's no harm in looking for the obvious things before you take the car to the dealer (e.g. leaves in the fan housing), it could save you and the dealer a lot of time and hassle, but personally I'd avoid removing the fan itself or disclosing too much to the dealer.
01-06-2019, 04:32 PM | #9 | |
Beemer Heaven
462
Rep 2,941
Scott
01-06-2019, 05:14 PM | #10 |
Rep 1,454
If you're at all technical get ISTA/D set up on a PC and buy a cable off Amazon
Lots of threads on here about how to do this Then you can run the dealer diagnostics to see if anything electrical causing an issue. This is probably the first thing a BMW dealer will do anyway However as already discussed return to the selling dealer first and get them to sort out |
01-07-2019, 06:24 AM | #11 |
Rep 268
Could it be the resistor pack has failed on the side of the motor assembly? Unlikely I know. Or even more simply, when you took it apart, the harness from the motor to the resistor pack has come unplugged or the car harness to resistor pack isn't connected correctly? You may have had one problem (leaves etc) and in fixing that created another.
02-23-2021, 12:03 PM | #12 |
Rep 105
Did you get this sorted? Mine's just done exactly the same, removed and unplugged the motor to check for debris and now it won't fire up. Controls look normal but no blower motor action.
Stupid is as stupid does...
02-24-2021, 06:24 AM | #13 |
Rep 858
My AUC F31 had this issue the day it was delivered! Heater control display worked, but no air, hot or cold. Fixed under warranty, didn't have any issues for the remainder of my time with the car.
