04-06-2017, 08:14 PM | #1 |
Rep 104
F30 2012 328i . hesitation at low rpm s
Ive got the worst of luck with this car. It only has like 19.000 miles but it has all kids of problems.
this is my problem you start to accelerate on low rpm on 1st or 2nd or any gear (like 1500-2000) and you fell like the car is hesitating or like its missing a beat. If you go beyond 3.000 rpms everything is normal. Also I you WOT the car is perfect. Another thing im feeling now is when Im stopped in Drive. And when I release the brake to accelerate I feel a small shake. CEL has not been triggered. I scanned the car and there was NO error stored. I went ahead and changed the 4 spark plugs with gem and the problem remained exactly the same. I also had 4 new injectors and went ahead a changed them and coded them. But the problem persists. My next guess is changing the coils. Any ideas. Ps dealer will not take my car cause its a direct import. |
04-07-2017, 08:52 AM | #2 |
Rep 2,389
The shake when releasing the brake pedal may be your start-stop feature turning the engine on. Is start-stop active when you drive?
Are you driving AT or MT? If AT, try accelerating in manual mode and see if you have the same hesitation. I don't mean just throwing the shift lever over to the left. You have to also push it up or down.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
04-07-2017, 02:28 PM | #5 | |
Rep 104
04-07-2017, 02:31 PM | #6 |
Rep 104
Yes . I always run it in low rpms. Shifts at around 2500 automatically. It has started with this issue just a few weeks ago. And I have the car since 2012 and never noticed it before.
04-07-2017, 02:32 PM | #7 |
Rep 104
04-07-2017, 04:12 PM | #8 |
Rep 5,983
I notice it sometimes after cold starting. It seems the torque converter locks up a little early, feels like when driving stick and you engage the clutch too soon. Happens less in sports mode. However, it seems like the poster is saying this happens all the time.
04-07-2017, 04:58 PM | #9 | |
no relation
130
Rep 442
04-07-2017, 05:42 PM | #10 | |
Rep 284
I learned this with my first bimmer 1988 318i, drove it gently not even knowing what the car was about, until one day I was told to wake up the beast.... |
04-11-2017, 09:08 AM | #12 |
Rep 104
Really havent found one with the same problem. And they dont want to do a software update if theres no check engine light on .
04-11-2017, 10:48 AM | #13 |
Rep 2,825
04-17-2017, 11:23 AM | #14 |
Rep 104
04-17-2017, 11:33 AM | #15 |
Rep 2,825
04-17-2017, 11:34 AM | #16 |
Rep 1,231
are you using premium gas?
05-18-2017, 05:21 PM | #18 | |
Rep 104
No misfire codes !! Im starting to lean on a motor mount or some kind of driveline vibration. Its all too weird. Motor shakes a bit more that i could call normal . |
05-24-2017, 09:04 AM | #19 |
Rep 104
ok, so checked the transmission fluid level on the car, thinking it might have a low level, and to my surprise the fluid was mixed with water. So that might be the problem. I will change fluid, filter/pan and transmission cooler, and report back.
05-24-2017, 11:04 AM | #20 |
Rep 30
I had a 2012 328i and it was always rough at lower RPMs unless I drove in Sport mode. Had a 328i loaner and it was the same; the 4-banger paired with 8-speed tranny seemed to struggle under about 2200-2400 RPMs
05-24-2017, 11:28 AM | #21 | |
Rep 29
turbo lag. |
10-03-2017, 04:54 PM | #22 |
Rep 1
i have the same issue with my 2014 F30 N20 . I found that air filter enclosure wasnt properly alligned and closed even if the 4 clips were closed. Car runs better and the hesitation is very minimal . I am about the order a K&N air filter to improve air flow
