BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > FBO 435i N55 ***Bootmod3 Issues***
      07-11-2019, 06:27 PM   #1
435guy
Drives: 2014 BMW 435i
I'm running FBO and BM3 on my 435, but I know I'm not getting all the power I should be. It seems to be barely faster than my stock set up. I'm on Stage 2 93 Octane map. I checked for leaks multiple times and even broke down and took it into the shop... about a hundred dollars later, they told me I had no leaks.
I logged a third gear pull to redline. I'm not sure what to make of my map... any thoughts?
http://www.bootmod3.net/log?id=5d27be41c090c63adf3b63f9
20x9 Beyern Ritz // Injen Intake // VRSF Catless Downpipe // VRSF Chargepipe // VRSF FMIC // BM3
      07-11-2019, 06:58 PM   #2
BeerHerder
Drives: F30 335, G01 X3, Victory Vegas
I really don't know much about this, but I see your timing on cyl 1 & 2 gets wonky about 5800 RPM and up. Maybe post up on the FB group as well.
https://www.facebook.com/groups/bootmod3/
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone...
Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more)
Graphite Metallic X3 (nothing yet, but... you know)
      07-12-2019, 05:14 AM   #3
Hudsonvalley435
2015 435i xdrive- 6spd, cp, dp, fmic, bm3 stage 2
Drives: F32 435i X
Try to reflash the map. Also, look at the "configure" section of your map (top right hand corner) and make sure there isn't a boost reduction per gear set.
      07-12-2019, 07:13 AM   #4
khj24
khj24's Avatar
221
Drives: 2015 m235i
Unless I'm reading it wrong, you have a major boost leak. You are targeting up to 16psi and only getting around 2psi.
Charge pipe o-rings installed? Correctly?
Silicon coupler tight?
Meth Bung tightened?
      07-12-2019, 10:30 AM   #5
435guy
No, I think you're on the money w that. I'm going to give it another look and probably just try and reinstall. I appreciate the help guys.
      01-13-2021, 12:46 AM   #6
juliomadara7
juliomadara7's Avatar
Drives: 2015 435i X-Drive
Was this ever resolved?
bm3, fbo, n55
