08-25-2021, 06:05 PM | #1 |
Rep 23
N55 PWG Hesitation/ Stutter under acceleration - BM3 stage 1 93
Hey guys I have a 2013 F30 N55 PWG with bootmod3 stage 1 93 and when cruising with everything in comfort there’s a hesitation/stutter and an occasional grinding sound. I spoke with bootmod3 and they suggested to change the ignition coils and spark plugs I change them and gapped the NGK spark plugs to .022 but still the problem persists. Above 3k RPM the car runs smooth. Additionally I have xDelete and when turned on at low rpm driving is wayy worse the sound is much louder. Below are the logs, appreciate anyone’s help
AWD: https://www.bootmod3.net/log?id=6126...0b4344f3a8591e RWD: https://www.bootmod3.net/log?id=6121...729b0ac793cda7 As far as mods I have VRSF chargepipe and Downpipe. |
08-26-2021, 07:27 AM | #2 | |
1296
Rep 3,533
harkes1078.00 |
08-26-2021, 07:37 AM | #3 | ||
Rep 23
08-26-2021, 11:41 AM | #5 |
Rep 23
08-26-2021, 02:40 PM | #7 |
Rep 688
Drives: 22 TR X3MC
Sounds like the same issue I'm having, car stutters on moderate throttle and I heard a metallic grinding noise. Getting my transfercase replaced as we speak and I hope that solves my issue.
2022 X3M Comp
2013 335i xDrive (Sold) |
09-10-2021, 11:10 PM | #8 |
Rep 23
09-10-2021, 11:12 PM | #9 |
Rep 23
Why does BM3 highly recommend it for tuned cars then?
09-11-2021, 09:53 PM | #11 | |
Rep 23
09-12-2021, 06:07 PM | #12 |
Rep 23
09-16-2021, 10:27 AM | #13 |
Rep 688
Drives: 22 TR X3MC
Alright, so here's my update. Looks like I replaced my transfer case for no reason and It was my sparkplugs this whole time. I was running the OE Bosch plugs and just switched the NGK 95706. There's no more hesitation and the problem seems to be gone. Fingers crossed it stays like that.
2022 X3M Comp
09-16-2021, 11:20 AM | #14 | |
Rep 7,606
09-17-2021, 11:13 AM | #15 |
Rep 688
Drives: 22 TR X3MC
That noise happened when the car stuttered and the car hasn't been stuttering ever since I changed the plugs.
2022 X3M Comp
09-17-2021, 12:37 PM | #16 |
Rep 7,606
09-17-2021, 02:51 PM | #17 |
Rep 688
Drives: 22 TR X3MC
I was running Bosch plugs at first, and now im running NGK
2022 X3M Comp
09-17-2021, 05:01 PM | #18 |
Rep 7,606
In the OP you said " I spoke with bootmod3 and they suggested to change the ignition coils and spark plugs I change them and gapped the NGK spark plugs to .022 but still the problem persists. "
Just trying to understand what you had before since Bosch plugs at stock gap should be totally fine for your application. How many miles were on the Bosch? If they were recently changed were they from a reputable vendor? Glad the NGKs solved your problem; your car might be one of the few that "needs" the NGKs. |
09-20-2021, 10:09 AM | #19 | |
Rep 688
Drives: 22 TR X3MC
2022 X3M Comp
09-20-2021, 11:15 AM | #20 |
Rep 7,606
09-21-2021, 12:35 PM | #21 |
Rep 139
Drives: '20 BMW F87 M2C
I'm having a similar issue.. I'm running BM3 Stage 2, 93 Octane, no issues. Ended up changing my spark plugs to the recommended one-step colder, NGK's, and all of a sudden, now I'm getting vibration/stutters under heavy acceleration. Definitely misfires, but I'm not seeing any codes whatsoever. So, hard to determine which specific cylinder to look at.
Not sure what the issue is or if anyone can relate. I'm thinking it's possibly: 1. Bad plugs (even though they're brand new) 2. Overtorqued or undertorqued the plugs 3. Bad coils (hard to imagine this, since everything was working fine prior) I'm going to remove the plugs and place them back in and retorque to spec (prior to, I just hand tightened and maybe another quarter-turn). If that doesn't work, I'm going to throw in the old plugs. |
09-21-2021, 01:07 PM | #22 | |
Rep 7,606
You can also flash back to stock and see if codes come up, BM3 is known to suppress codes, especially those related to misfires. |
bm3, hesitation, n55, stutter, xdelete |
