01-21-2022, 11:59 AM | #1 |
Jeremiah
Rep 9
Limp mode on cold days (N55)
My car (2015 335i, N55 engine, m-sport package, 35xxx miles, completely stock) is going into limp mode on cold days (<35 degrees F) and I am perplexed as to what is going on. I have taken it to an indy repair shop and they have suggested replacing a handful of parts but the problem has persisted. Before taking it back to them, I would like your collective wisdom. I bought the car 3 years ago and the problem has occurred each winter.
Situation:
Suspected Cause:
What I have done:
Any thoughts or suggestions? Thank you in advance! |
01-21-2022, 01:03 PM | #2 |
Rep 7,606
Sounds like a sensor, wiring, or potentially even DME issue. If you are getting an erroneous coolant temp reading, i dont see any way its not one of those 3 things. Once the DME sees that erroneous reading, the effects cascade and it likely goes into limp mode kicks the water pump and fan onto high as a protective measure since it doesn't know the true coolant temp.
So you need to try and figure out why you get the incorrect coolant temp reading - everything else is likely due to that. |
01-21-2022, 01:50 PM | #3 |
Rep 844
What makes me perplexed with this whole issue is the fact that if you warm it up for 10 minutes without driving then turn it off and back on it works normally. you'd think if it was a sensor you would get the codes and temperature readings in any situation. that makes me wonder if its maybe a voltage thing. Are the lines going in and out of the heater core hot? I only ask because even if you were getting an erroneous coolant temp reading the actual coolant temp SHOULD be hotter which would give you normal heat. Very interesting issue going on here. Does the car display the correct ambient temp?
EDIT: After doing some research the lowest temp your coolant sensor would register is -128 which means you likely have an open circuit fault and the computer isn't getting any information from the sensor. check the harness for loose cables and then check continuity down the chain until you find the break.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. Last edited by njdangelo; 01-21-2022 at 02:01 PM.. |
01-21-2022, 03:31 PM | #4 |
Jeremiah
Rep 9
Thanks to both of you for your thoughts.
There is a part of me that wonders if the whole problem is caused by the car being too slow to warm up. If I warm up the car for 10 minutes, it gives the system just enough of a head start that it warms up quick enough the second time to not trigger the limp mode. This brings up the question about the order in which things happen: 1) does the temp sensor fault out and this triggers the limp mode? or 2) does the slow warm up trigger the limp mode and this does something wonky to the temp sensor output in the hidden menu? I don't know if this will be helpful or not, but if I hook the car up to my computer via an obd-II cable to OBDwiz, I can still get a reading on the coolant temperature even when the hidden menu temperature says -128. |
01-21-2022, 05:27 PM | #6 |
BMW CCA 69606
86
Rep 227
Working fine after idling for 10 minutes, which raises the underhood temperatures, makes me wonder if the DME is temperature sensitive. You need to scan with ISTA or something BMW capable. There was a similar thread about an N55 with low coolant temp and fan running full speed on another forum. Was that you? I had an E30 with a temp sensitive DME. I was able to put it in the freezer to cause the problem, then heat to 150F in oven to make it go away.
01-21-2022, 05:32 PM | #7 | ||
Rep 7,606
01-21-2022, 05:42 PM | #8 |
BMW CCA 69606
86
Rep 227
Sure, if the problem is the DME, the underlying issue is the DME has a defect. It could be a bad solder joint or a cracked component that opens on low temp. The freezer and oven will sort this out quickly.
01-22-2022, 05:44 AM | #9 | |
Rep 844
2016 340i THP stage 2 - gone but not forgotten. |
01-22-2022, 10:06 AM | #10 | |
Jeremiah
Rep 9
I fully agree, driving should warm it up faster. However, in this case I shut the car off after warming it up and then restart it before leaving. Because the car is warmer when it restarts, my speculation is that it gets to a reasonable temperature more quickly avoiding whatever it is that triggers the limp mode. |
01-22-2022, 10:13 AM | #11 |
Jeremiah
Rep 9
As I step back and think about this, it is sounding more and more like a problem with the wiring heading to the electrically controlled thermostat.
I imagine BMW set things up such that any problem with the voltage, etc, the thermostat will default to completely open. If the thermostat is always open, it would explain why I am so slow to come to a normal operating temperature and have very little heat. This may be triggering something in the computer that sends me to limp mode. I will visually inspect the wires heading to the thermostat. Also, is there anywhere I could look to get more information about the expected voltage at the thermostat? The voltage probably changes as the coolant temperature fluctuates. Thanks again for all of your thoughts on this. |
01-23-2022, 07:25 AM | #12 | |
BMW CCA 69606
86
Rep 227
It seems more likely that the DME loses the engine temp reading, (-128 ... open circuit) and then goes into full cooling mode.....fan speed high, 12v to thermostat to fully open, limp mode to prevent WOT and protect the engine. I would check the connections on the coolant temp sensor for corrosion and any evidence of wiring problem at connector. If this looks OK, change the sensor, it's inexpensive. Check connections at DME, confirm wiring continuity from sensor to DME. Scanning with a BMW capable tool is essential. Here's the other thread I mentioned earlier about a similar issue, -128 temp, fan runs fast, engine doesn't warm up. This is on an N26 engine rather than N55. https://www.bimmerfest.com/threads/t...n-open.1422117 Last edited by pshovest; 01-23-2022 at 10:38 AM.. |
01-23-2022, 02:45 PM | #13 | |
Rep 7,606
njdangelo436.00 |
01-25-2022, 09:52 AM | #14 |
Jeremiah
Rep 9
Thanks for your thoughts and sending me to the other thread with similar issues.
I visually checked all the wiring/connections last night and the problem continued on my way to work this morning. My next steps will be to get a replacement coolant temp sensor and get the car scanned with a BMW capable tool. Last edited by run4ski4; 01-25-2022 at 10:45 AM.. |
01-31-2022, 06:59 PM | #15 | |
Rep 40
2013 335i xDrive Melbourne Red my first BMW BMW, you might find better but you can't pay more |
02-07-2022, 03:29 PM | #16 |
Jeremiah
Rep 9
Correct, the car won't let me go over 2000 RPM and the coolant fans come on at full blast (presumably to keep the car from overheating).
My initials thought was a problem with the thermostat but replacing it hasn't solved the problem. |
02-10-2022, 01:25 PM | #17 |
Rep 40
Have you also replaced the water pump?
02-10-2022, 04:06 PM | #18 |
Rep 161
I noticed a very limp issue on my car as well in cold weather. It was mostly when i go from stop to accelerate, the car advances very slowley and then gives me back the power (2 seconds after i press accel.)
I assumed this is to avoid slipping on cold icy roads since im rwd... This does not happen when its warmer. Perhaps its something related to this? |
02-11-2022, 02:03 PM | #19 |
Jeremiah
Rep 9
02-11-2022, 06:03 PM | #20 |
Rep 69
Hello,
Very sorry for your troubles. I wanted to just share with you how I handled the same type of issues on my car (2013 N55 M-Sport). However, please understand this worked for me and my car. I had the same exact issue as you but lacked the temperature element you are noting. I felt my issues are common enough to share. This remedy might not work for you though. I'd hate to have you continue to fall into the trap of "throwing parts" at the problem. I had several limp modes on my car. I live in Florida so the temps weren't as low as yours but were cool for Florida (60's). Extremely high fan speed/loud, can't get over 2,000 RPM in lower gears, Oil guage on dash sticking at low value. I read several posts about N-55 limp modes here on forums that were not track day related. Initially, it appeared this only affected 2013 M-Sport N55 models. However, as time went on, members with other model years chimed in with same issues (although not as many). Almost everyone (including me) could stop/shutoff car, restart and the problem would go away. I saw folks permanently solved the problem through a single or combo of the following: 1. Re-flash ISTA to newest avail version, 2. replace fan relay, 3. replace 850W fan. The fan replacement is linked to fans produced up to November 2013. After that date of manufacture, they are supposed to be good. The date of manufacture is on the fan module. The relay was helpful to some and not for others. The ISTA flash was helpful to several folks. This is what I tried first and it worked for me - no more issues. I did the flash first (at Indy not BMW to avoid potential lock-out issues) because it was the easiest first step for me, and I wanted to try one remedy at a time. I wanted to share because of similar issues, but realize my ambient temp is nowhere near what you are dealing with which could make it something completely different. Sorry! Best of luck.
2013 335i M-Sport || MPPK || M-LSD || M-BBK || VRSF CP - DP - FMIC || Bilstein B16 PSS10 || Vorshlag CPs
02-12-2022, 07:33 AM | #22 |
BMW CCA 69606
86
Rep 227
Interesting. Thanks for the info and link.
Here are the (2) SIB's referenced. Both have specific codes that should be stored in the DME. Edit: Note that one the SIB's refers to cars with 0337 M-Sport package and the other does not. Last edited by pshovest; 02-13-2022 at 10:21 AM.. |
