11-26-2018, 03:30 PM | #155 |
Rep 5,088
If the shifter is on the right but the transmission does switch from D to M1 and then back to D by itself, then it may be an issue with mechatronics (the CPU box that runs the ZF 8AT).
So when D->M1 occurred(rpm did going up, indicating downshift) in the video, the car was at 25mph. Normally at that mph the 8AT should shift into 1st gear anyway. The failure can be that mechatronics incorrectly shows M1(should only displace in D/S) while still in D, if true that will be a minor issue. Is there any more dramatic D->M1 than shown in video, e.g. traveling 60-70mph on freeway, and the transmission shifts into 2nd gear? Last edited by bavarianride; 11-26-2018 at 03:38 PM.. |
11-27-2018, 10:16 AM | #156 |
Rep 50
The meter I have in km/h. And at higher speeds it just reduces by one gear. (It always reduces by one and as it returns to D sets one higher) It behaves as if I switched from D to S. And why the problem intensifies at cold temperatures?
11-27-2018, 12:38 PM | #157 | |
Rep 5,088
This can become a serious problem quickly, so it is prudent to seek diagnosis from indy/dealer soon. |
11-29-2018, 06:49 PM | #160 |
Rep 316
upgraded turbo, i.e. anything larger than stock turbo i.e. the car is FBO with a bigger turbo pushing bigger power numbers with or without upgraded fueling. anyone?
02-05-2019, 07:40 AM | #161 | ||
Rep 308
Can I use ISTA to reset my transfer case after replacing the fluid? Can I use the below link to source and install ISTA to do my transfer case and transmission? https://www.motor-talk.de/forum/akti...hmentId=750191
2017 F31 328d xDrive
M Sport M Performance |
03-12-2019, 08:08 PM | #162 |
Rep 1
Argh, all I can contribute is "don't do it" unless you have the right tools. Mainly, a scan tool that will give you the transmission oil temp. I tried Torque - and it has a transmission temp for the F30 - but I noticed its the exact same value as the coolant temperature, always. So, I can only assume it's a glitch in the app. I also tried a Foxwell NT510. Others have reported success with this, but I see no trans temp option within the scanner. I tried a infrared temp gun - and that's highly inaccurate because the trans fluid will be hot long before the trans will be. Argh. Now I'm sweating over potentially overfilling / underfilling.
03-12-2019, 08:28 PM | #163 |
Rep 5,457
Drives: F30
^ BimmerLink has two different transmission temperature readings available.
03-13-2019, 08:02 AM | #164 | |
Rep 424
03-13-2019, 11:47 AM | #165 | |
Rep 308
Which oil and trans temp do you use in Bimmerlink?
03-13-2019, 12:29 PM | #166 |
Rep 5,457
Drives: F30
I would double check and report back....
03-18-2019, 11:05 AM | #169 |
Rep 5,457
Drives: F30
I have not done this procedure but if I were to change my fluid - I would use the straight up Transmission Temperature one... Not positive exactly what/where the other one is reading from. Someone else with a more technical background/education might be able to help us...
03-18-2019, 04:43 PM | #170 |
Rep 98
I just this procedure on my X1 same 8 speed... Using ISTA+
for now i just did a drain and fill, but for some reason the software did not make me go through the gears like some has said here in the forum and video online. did anyone have the same experience ? a drain and fill was only 3.5 liters- in the adjustment i put in about the same amount. about 200ml less. maybe i have to click on part replacement? not on fault code? Last edited by mreric; 03-18-2019 at 05:23 PM.. |
04-01-2019, 07:40 PM | #171 |
Rep 46
04-02-2019, 10:55 AM | #172 |
Rep 235
04-09-2019, 03:34 AM | #173 | |
Rep 44
Will I need to use the Oil Change function as well (which resets the adaptations) after or before the Oil Adjustment function ? |
04-09-2019, 05:49 AM | #174 | |
Rep 44
I am confused with the procedures a bit. The youtube video later on this thread recommends to wait 5 sec on R and D and then letting off the brakes and rev for 5 sec at 2. gear directly and then reving to 2000 rpm on neutal for 5 sec. I dont know which one I should apply. However in case I apply your 3. step (Get in the car and shift to reverse, then D, then go into the manual shift gate and hold gears 1 & 2 for 10 seconds.): I know I should press brake and make sure to stop the wheels spinning between gears R and D and even M1. Question1: Should I again press the brake and stop the wheels once I rev at M1? And then take the gear to M2 and let the wheel run from M2. But in that case M1 should appear again automatically. So will I spin the wheels at 2000rpm on M1 for 10 sec and manually shift to M2 while the wheels are spinning and rev 2000rpm for another 10 sec? Question2: Ista+ will ask the reason why I do the oil adjustment. What answer should I choose? Question 3: Should I also go to the Oil Change menu under Oil Adjustment on Ista+ which will probably reset adaptations? |
04-09-2019, 05:56 AM | #175 | |
Rep 44
04-26-2019, 01:02 PM | #176 |
Rep 44
Changed the transmission fluid on my F30 (5 years old 37K miles) following ZF procedures with ZF oil and all is perfect. Smooth shifts got even smoother.
I recommend everyone to change the transmission fluid as early as possible to take no risk. |
