03-21-2019, 06:27 PM | #1 |
Rep 302
Valve cover gasket
Just trying to gather opinions on this...i need to do my valve cover gasket soon and was pondering buying an entire new valve cover also, the Hamburg or genuine.
Refreshing the cover itself and getting a fresh pcv seems kinda nice. I also don't want to pull the old one to find its cracked and need one anyways. Thoughts? |
03-21-2019, 08:45 PM | #3 |
Rep 1,571
Probably a good time to replace the cover and PVC- especially since you are FBO. I'm stock at 106K and just had to replace mine as the PVC had finally failed,
03-23-2019, 09:27 AM | #4 |
Rep 2,195
Our 2013 with 45K miles had a leak due to a warped cover, apparently. Just replaced yesterday with some warranty help.
03-24-2019, 11:50 PM | #5 |
Rep 387
Since you are going to go through the hassle of removing the cover, just replace it, one and done. I know for myself that I would be extremely irritated if I replaced the valve cover gasket, and then five or 10,000 miles down the road the PCV failed, or the valve cover cracked and I had to do the job all over again. I would go genuine.
By the way, where are you buying the parts from? |
03-25-2019, 05:49 AM | #6 | |
Rep 3,946
03-25-2019, 06:02 AM | #7 |
Rep 3,946
03-25-2019, 07:34 PM | #8 |
Rep 1,571
In my case (yours may vary), rough idle and uneven acceleration. Biggest give away was the hiss/whistle from VC area even at idle. Other dead give away was the amount of vacuum on the oil filler cap when I removed it. it was hard to pull off. |
03-26-2019, 10:54 AM | #9 | |
Rep 10,256
03-26-2019, 01:06 PM | #10 |
Rep 302
I think it was ecs had a hamburg brand cover for 250. I'm willing to buy the oem but if the cheaper option is just as good, I'll use that. Never heard of the brand before this.
03-27-2019, 12:02 AM | #12 |
Rep 302
03-27-2019, 12:36 AM | #13 |
Rep 2,639
injectors.
03-27-2019, 12:57 PM | #15 |
Rep 2,639
I mean our injectors aren't too expensive, I believe if you get the bosch ones, they're around 50$ for one. If you're going to remove the valve cover, you should do the injectors at the same time as its easy access, or else if it ever fails on you later, its a couple hours job and a new valve cover gasket to put new ones in.
03-27-2019, 08:47 PM | #16 | |
Rep 3,946
https://www.fcpeuro.com/products/bmw...-13647639994kt Also, ISTA doesn't indicate that you need to remove the valve cover to change them... https://www.newtis.info/tisv2/a/en/f...lines/ITkr1aNI |
03-27-2019, 09:21 PM | #17 | |
Rep 2,639
03-28-2019, 03:36 AM | #18 | |
Rep 3,946
03-28-2019, 07:59 PM | #19 | |
Rep 2,639
