10-26-2017, 11:59 AM | #89 |
Rep 1,499
Do they honor the return policy for wear items? Brake pads, windshield wipers, clutch disc, etc?
10-26-2017, 01:54 PM | #90 | |
IG @bmwF9xG80
3813
Rep 7,593
I got these https://bootmod3.atlassian.net/wiki/...+and+which+gap
60-130mph 6.5s X4M #HCP
10-26-2017, 02:19 PM | #91 | |
Rep 2,080
10-26-2017, 02:34 PM | #92 |
Rep 775
The more i read, the more 0.022 seems the sweet spot with NKG.
BTW, thanks for link above, yet never heard of the S55 plugs cracking. Hmmm...
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
10-26-2017, 03:09 PM | #93 |
Rep 1,499
I purchased the 97506s as well and will be gapped at 0.024" at EatMoreLobsters did as out setup is similar.
EatMoreLobsters151.50 |
10-26-2017, 03:58 PM | #94 | |
IG @bmwF9xG80
3813
Rep 7,593
I also ordered some Liquid Moly 0w-40 oil and planning on buying most things from there that will require swapping for full refund
10-26-2017, 07:01 PM | #95 | |
Rep 2,080
https://www.fcpeuro.com/products/bmw...plug-ngk-96987 You still haven't answer with what gap you are going man.
10-26-2017, 07:34 PM | #96 | |
IG @bmwF9xG80
3813
Rep 7,593
10-30-2017, 11:27 PM | #97 |
Rep 1,805
Spark plug question with my BM3 PS2, 93 octane flash.
-MY14 335ix 8-speed EWG -Pure Stage 2 w/ High flow inlet and diverter valve upgrade -ER Cattless DP -ER Charge pipes -ER Turbo to intercooler charge pipe -Remus axleback -Dinan intercooler -Eventuri intake Engine Type N55 EWG Octane US 93 Issue -Sport mode, auto shifting, full throttle... When my car hits 3rd or 4th gear it very often just hits redline and bounces for 1-2 seconds. Sometimes it shifts up, but more often than not, it will bounce off redline and not shift up until I decide to just let off the gas so I don't hurt the engine. Dzenan at PTF recommended I use the recommended NGK plugs gapped at 0.018". I don't believe I'm pushing past 25psi so could this be the potential issue? should a re-gap the plugs to 0.02"? Appreciate any advise. Pete
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
10-31-2017, 10:13 PM | #98 |
Rep 2,376
(A Dane in China) |
05-20-2018, 09:44 AM | #99 |
Rep 115
I've been running around the forums for awhile now and can't come to a decision.
If i'm in a 2014 335xi running FBO on a HFC DP, i'm on JB4 map 2 with plans on switching to BM3 as soon as I switch these plugs, which plugs would I go with? Options seem like NGK 5992 gapped to .022" or NGK 97506 gapped to .020". Thank you for any help I really appreciate it, I've been leaning the NGK 5992 route.
2014 BMW 335xi FBO Wagner catted DP, VRSF CP, VRSF HD FMIC, M-Performance exhaust, BM3, AG 359M 19in Rims, ExtremeContact Sports Tires
05-20-2018, 05:34 PM | #101 |
Rep 808
Literally just installed a set of these. I wouldn't say it's a huge difference over stock but there is a noticeable difference. The real story will be told when I capture some logs on the new plugs, I just haven't had a chance to yet. I'm hoping it clears up my intermittent knocks and timing variation.
I am on bm3 stage 2 |
Triple8894.50 |
05-20-2018, 05:55 PM | #102 | |
Rep 115
05-20-2018, 06:12 PM | #103 | ||
Rep 808
05-20-2018, 06:32 PM | #104 |
Rep 832
Drives: 2019 G01 X3
the dope steez Triple88 Did you gap to 0.020"?
05-20-2018, 06:44 PM | #105 |
Rep 808
Yes. Although I did not gap the OEM plugs when I installed them a couple months back. I was told not to as they were 'pre-gapped'.
I don't believe gapping them has as much to do with their performance as heat range, but it is certainly part of the equation so I made sure to gap the NGKs to 0.020 |
05-20-2018, 09:06 PM | #106 |
Rep 803
I have a JB Stage 1, ER charge pipe. AFE air filter and a VRSF fmic. I'm thinking I should get the NGK 97506 and gap them at .20. It seems to be the popular setup to go with.
05-21-2018, 11:00 AM | #107 |
not good, but bad
333
Rep 361
Can someone explain why you need to use something other than the OEM Bosche plugs on the stock turbo? Are your logs showing timing corrections? Are you getting misfires?
I really don't get it, from what I've learned from multiple tuners the stock OEM plugs are fine for almost all N55 applications, unless you get way into the 650+HP range the OEM plugs work well. Even harkes post above gives hard data showing the OEM plugs ran better than aftermarket. I just don't get it, I see spark plugs threads/chats all the time with no reason what so ever as to why the switch. I'd love to see some logs showing an actual improvement from different plugs (not old worn out OEM's vs new aftermarket)
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
Triple8894.50 |
05-21-2018, 02:21 PM | #108 |
Rep 266
You probably don't need to get new plugs with your setup, stock ones will be fine. Colder plugs gapped down are needed once you start running more aggressive tunes (higher boost)
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
05-21-2018, 02:44 PM | #109 | |
Rep 1,541
Colder plugs help to prevent this. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber. E85 also helps prevent this with it's lower igniting temperature.
05-21-2018, 08:46 PM | #110 |
Rep 808
Yeah so I just logged some pulls, not enough as I would have liked to but I do have a couple comparable ones. Variables are all the same: car, fuel, mods etc.
BEFORE (stock plugs w/3,000 km): 5th gear pull: http://www.bootmod3.net/log?id=5acfab8bd10b437d64eb5fdd 4-5 pull: http://www.bootmod3.net/log?id=5acfab77d10b437d64eb5fdc AFTER (NGKs): 5th gear pull: http://www.bootmod3.net/log?id=5b034a11d10b4326703f2d14 4-5 pull:http://www.bootmod3.net/log?id=5b034a12d10b4326703f2d16 Minimal difference if any... the NGKs are noticeably smoother feeling though. Not by a lot, but a little. |
