03-09-2013, 03:34 PM | #1 |
Rep 153
Collision Assist on the F30
Hey guys. My dad is potentially thinking about the new 3er to replace his C250 (sadly it was trashed in a side impact collision a few weeks back). I am wondering if the collision warning system also has automatic braking in emergency situations, or does the car need to be equipped with Active Cruise Control as well? I searched here and couldnt find a definitive answer; the BMW website wasnt helpful at all either.
03-09-2013, 05:39 PM | #2 | |
Rep 68
03-09-2013, 05:44 PM | #3 |
Rep 614
AFAIK, the auto brake feature you're looking for is only available on Volvos at the moment.
The ACC feature can perform the same function but it has to be activated every start up. |
03-09-2013, 06:03 PM | #4 |
Rep 153
03-09-2013, 08:08 PM | #5 |
Dinosaur supervisor
3030
Rep 4,214
You select in the iDrive menus if you want it active or not and can chose between two distances. No need to do anything on each startup. It will be on by default if you want it too. There is a button to the left of the steering wheel too where you can switch it on/off.
It works great, the other day it braked before I could react when a cyclist cut in front of me. In traffic I mostly see the red warning light approaching traffic that is slowing down. I have the active cruise with stop&go, so mine brakes. Otherwise you just get the warnings. So to answer your question - you don't have to do anything to activate collision warnings once you set it up the first time, but cruise control needs to be activated and set each time (obviously). |
03-09-2013, 08:32 PM | #6 | |
Rep 153
03-09-2013, 08:36 PM | #7 |
Dinosaur supervisor
3030
Rep 4,214
No, as I said above the collision warning works automatically as long as the option is set active and the last setting is remembered on each startup. So you don't have to do anything on each startup to have it active once you activated it the first time. Mine was off by default.
03-09-2013, 08:41 PM | #8 | |
Rep 153
03-09-2013, 08:46 PM | #9 | |
Dinosaur supervisor
3030
Rep 4,214
You can use the collision warning system (incl emergency braking) 100% independent from the cruise. |
03-09-2013, 08:48 PM | #10 |
Rep 153
oh ok, thanks Rossifumi . Thats exactly what i wanted to know. So now to find a car here with active cruise and the driver assistance stuff.
03-09-2013, 09:55 PM | #11 |
517
Rep 3,612
Collision warning will pre-load the brakes but will not engage them for you. That being said, if the vehicle detects a inevitable crash, it will slightly apply brakes to ease impact
03-10-2013, 01:04 AM | #12 | |
Dinosaur supervisor
3030
Rep 4,214
If you have active cruise control with stop&go it will brake. There are two different versions for the F30, and we are talking about the one that uses the active cruise control sensor and not the camera. It will not brake to a standstill, but it will begin to brake for you so that you can take over. |
03-10-2013, 11:57 AM | #14 | |
Rep 43
03-10-2013, 01:04 PM | #15 | |
Dinosaur supervisor
3030
Rep 4,214
03-10-2013, 03:01 PM | #16 |
Rep 43
OK, that wasn't clear from your original message. If you don't have ACC, the car will not "begin to brake for you." If you do have it, the car will brake for you (and stop the car). So I'm not sure what you were referring to when you say the car will "begin to brake for you."
03-10-2013, 03:07 PM | #17 | |
Dinosaur supervisor
3030
Rep 4,214
03-10-2013, 03:27 PM | #18 |
Rep 43
"If you have active cruise control with stop&go it will brake. There are two different versions for the F30, and we are talking about the one that uses the active cruise control sensor and not the camera. It will not brake to a standstill, but it will begin to brake for you so that you can take over."
I'm sorry, but I still find this unclear. Did you mean that there is an anti-collision feature that applies the brake? Because as far as I know, this option doesn't exist in the U.S. -- which is where the original poster is from. In the US you only get the audible warning and the brakes are prepared to stop but do not actually engage (as someone else pointed out). Therefore, can you please explain which feature will "begin to brake"? This is still unclear to me. Sorry if this is crystal clear to everyone else. |
03-10-2013, 03:42 PM | #19 |
Dinosaur supervisor
3030
Rep 4,214
Yes, as I say in the quote. If you have ACC it will come with a collision warning that also brakes. If you just have the collision warning as a stand alone option that uses the camera it won't.
03-10-2013, 03:50 PM | #20 | |
Rep 43
Did you make a mistake? If not, what were you referring to? |
03-10-2013, 05:46 PM | #21 | |
Rep 9,709
If ACC is not activated, but collision warning is, it warns of a hazardous situation, and pre loads the brakes, but doesn't activate them until it thinks a collision is unavoidable, then it deploys the brakes to 'take the edge off' a collision. It won't stop the car though. |
03-10-2013, 06:18 PM | #22 | |
Rep 43
