02-26-2020, 03:46 AM | #1 |
Rep 37
Eco pro charge meter
Hi, I have just collected my 320d G20 that has around 8000 miles on it and after doing around 70 miles driving the display in eco pro that show the charge (battery) has not being charged so to speak, I've had 3 other bmws that show this as fully charged most of the time, any ideas why it's not charged? The car was driven in eco pro to charge it
Picture attached Thanks |
02-26-2020, 04:07 AM | #2 |
Rep 266
If this is like the F30 version I think that only fills up when you driving along and coasting/foot off the accelerator?
Not sure about the G20 version though. |
02-26-2020, 04:20 AM | #4 |
Rep 2,128
As said above, that shows how much you are charging the battery through coasting/light braking.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
02-26-2020, 04:23 AM | #5 |
Rep 291
I understand. Its a bit counter-intuitive but it's a thing with eco pro mode. Presumably in a good state of charge, when you coast in ecopro, the alternator disconnects to reduce rolling resistance and the car uses the the battery to power the car to maximise the coasting distance. This is further enhanced as the car can also (if selected in the menu) reduce the power draw of the air conditioning and seat heating. Hence the battery isn't charging (its discharging to a point). When you use the throttle again the alternator reconnects and tops up the energy used during the coast (but that won't register on the dash).
This doesn't happen in Comfort or Sport where the alternator stays connected (and charging) all the time. |
02-26-2020, 05:09 AM | #6 |
Rep 1,993
Drives: F30 335d
Isn't it the other way round? In my F30 even in Sport the battery will charge on coasting according to the dash, therefore the alternator is connected during coasting and disconnects during acceleration.
if I've helped - an Appreciate would be, er, very appreciated!
02-26-2020, 05:44 AM | #7 |
Rep 291
Sorry i wasn't clear, by coasting in eco pro mode (as opposed to sport for example) the power between the engine and gearbox is cut and the engine idles so there is no overrun to charge the battery.
02-26-2020, 06:45 AM | #8 |
Rep 1,993
Drives: F30 335d
I'm with you now.
