11-29-2018, 01:55 PM | #23 |
Rep 176
11-29-2018, 02:48 PM | #24 |
2095
Rep 43,350
Most of our customers have a CEL free experience with our downpipes but we've been working hard on our existing F chassis lineup and we should have a Euro6 standard catted option on the way for both the 3.5" and 4.0" models that will be guaranteed to pass inspection.
They'll be the same price as our existing options and should be ready for purchase Q1 2019. Last edited by Tiago@VRSF; 11-29-2018 at 04:32 PM.. |
11-29-2018, 03:09 PM | #25 | |
Rep 1,572
Uh, it's currently Q4 2018. Either you're 3 Qtrs late or you mean 2019 |
scostu1623.00 |
11-29-2018, 06:23 PM | #27 |
Rep 440
Drives: 2013 335i xDrive
By comparing the readings of the two O2 sensors, the computer monitors the effectiveness of the catalytic converter. If the computer does not see the second sensor, it throws a hissy fit and lights up your dashboard. It doesn't mean anything is wrong with the motor.
I'm not completely useless, I can be used as a bad example.
11-30-2018, 07:33 AM | #28 | |
Rep 472
12-04-2018, 09:25 AM | #29 | |
Rep 75
When the tech had the old downpipe off the car and he noticed when trying to install the new fabspeed pipe that the flange on the pipe was too tall and would not let the downpipe sit flush to the turbo or the clamp hold on it. I have some pictures of the 2 flanges so you can see , the measured stock unit is about 4.5mm tall, the new downpipe was about 5.5mm. I had them mill down the flange on the new downpipe to match to ensure a good tight fit.. cost me an hours labor and have run with no problems.. That said I love the pipe, love the sound, and run a kind of stage 2+ custom tune pushing the stock turbo for everything its got.. (PS2 next spring) .. so although disappointed I would still recommend.. such is the life of playing with aftermarket parts.. No I did not contact FabSpeed.. meant too but sometimes lifes events over run us .. Let me know how yours turns out. Mike [IMG][/IMG] |
12-04-2018, 09:36 AM | #31 |
No 55mph
1622
Rep 8,476
[QUOTE=VAF30;24070823]Sorry for the delayed reply.. got caught up in the real world...
When the tech had the old downpipe off the car and he noticed when trying to install the new fabspeed pipe that the flange on the pipe was too tall and would not let the downpipe sit flush to the turbo or the clamp hold on it. I have some pictures of the 2 flanges so you can see , the measured stock unit is about 4.5mm tall, the new downpipe was about 5.5mm. I had them mill down the flange on the new downpipe to match to ensure a good tight fit.. cost me an hours labor and have run with no problems.. That said I love the pipe, love the sound, and run a kind of stage 2+ custom tune pushing the stock turbo for everything its got.. (PS2 next spring) .. so although disappointed I would still recommend.. such is the life of playing with aftermarket parts.. No I did not contact FabSpeed.. meant too but sometimes lifes events over run us .. Let me know how yours turns out. Mike I didn't have this problem with my Fabspeed Sportcat on my 435 EWG - installed it over 1 yr ago & fitment was perfect, mebbe yours fell thru the quality control check?
12-04-2018, 10:06 AM | #32 |
Rep 75
Mike
I didn't have this problem with my Fabspeed Sportcat on my 435 EWG - installed it over 1 yr ago & fitment was perfect, mebbe yours fell thru the quality control check?[/QUOTE] Agreed.. did a lot of research and thinking and never heard of a fitment issue.. so I am assuming it was a one off.. |
12-04-2018, 11:42 AM | #33 | ||
Rep 1,288
12-04-2018, 12:42 PM | #34 | |
Rep 1,055
[QUOTE=1QuikWS6;24070875]
12-04-2018, 01:10 PM | #35 |
Rep 1,288
Just checked the flange... measures with the calipers 5.6-6.1mm stick-out from flange ... will tell installer to watch out for fitment...
12-04-2018, 06:26 PM | #36 |
Rep 170
So what's the verdict? Is the catted DP worth the expense? Sounds like exhaust sound is improved a bit but did anyone notice any hp gains according to the butt dyno?
2015 335xi Black/BLK, FBO BM3 Stage 2, AA FMIC, CTS Turbo CP, FabSpeed Sport Cat DP, MPPK airbox w/high-flow filter, 18" AG M310's black
12-04-2018, 06:32 PM | #37 | |
Rep 1,288
https://datazap.me/u/fastf30/log-154...og=0&data=4-17 https://datazap.me/u/seba77w/log-154...0&data=3-13-22 |
12-04-2018, 07:06 PM | #38 |
Rep 211
I just installed a Fabspeed catted DP (thanks Mike), and the AA Stage 2 tune. The difference is very feels substantial. The Stage tune added low end boost over my Stage 1+. The sound with the Akrapovic is addictive. I do find myself leaving it in comfort mode more often with the wife aboard and when riding through the neighborhood. In Sport and Sport+ its more than loud enough for me.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
12-17-2018, 09:19 AM | #39 | |
Rep 176
So since my VRSF catted downpipe threw a cel, I will not be able to pass emissions here in NY... so can I clear the code and pass emissions with jb4 or bootmod3?? |
04-22-2019, 06:04 PM | #40 |
Rep 34
2015 435i xdrive. Installed a Fabspeed Sport Cat Downpipe 2 weeks ago - no cel so far with about 1500 miles. Throttle response is excellent and the car pulls much harder than before. Sounds much more aggressive yet restrained. Worth every bit it cost me.
04-22-2019, 08:17 PM | #41 |
A family of bimmers
2748
Rep 7,742
No. It'll have a readiness check not set to ready even if you clear the cel
EDWYER1676.00 |
04-22-2019, 08:50 PM | #42 | ||
Rep 5,395
When your downpipe was swapped out these two wiring connections at that dual clip would have been disconnected so that the two wiring harnesses could be fed down and then out with the old downpipe. Then the two sensors get unscrewed from the old downpipe and screwed into the new downpipe. Then some sort of pull-string is used to pull the two wiring harnesses back up into the engine bay to be reconnected. Check out Kies Motorsports on YouTube for a downpipe install video. It shows exactly what I just described. It appears that during the downpipe replacement one of the sensors and its wiring harness either was not reinstalled, or wasn't installed right enough and fell out. I suspect the former, because if the sensor fell out the wiring harness would have been found hanging. (Doesn't sound like that was the case unless they didn't tell you.) Hope this helps! |
10-23-2019, 03:19 AM | #43 |
Rep 38
Anyone try China DP with 200 cell ?
10-23-2019, 04:47 PM | #44 | |
Rep 14
M-Sport; VRSF CP, AR design catted DP (ceramic coated), CTS turbo intake, AFE air scoop, Turbosmart EM BOV, BM3 OTS stage 2
