10-14-2014, 06:15 AM | #1 |
Rep 28
F30 - What tyre pressure are you using ?
Hello all. I am new to BMWs and to run flat tyres. I have recently purchased a new 3 series.
I have a F30 with 225/50/R17 94W tyres all around. I think I am being a bit dim, but pillar b seems to imply that I should be inflating the front tyres to 2.4 bar which I think is 34 PSI and rear tyres to 2.9 bar which is 42 PSI. Not sure if I have interpreted this correctly and was wondering if this is correct and why the rear tyre pressure is higher than the front ones ?. Thanks in advance. |
10-14-2014, 09:15 AM | #2 | |
Rep 15,858
Yes, rear tyres are a higher pressure, RWD being one factor, BMW's established pressures for best handling balance another, and you'll notice we increase the rear tyre pressure more than front when running the higher settings for more load. HighlandPete |
10-14-2014, 09:39 AM | #4 |
2006 TIME Person Of The Year
9720
Rep 6,445
I believe the rear tire pressure listed on the pillar assumes maximum cargo load is present. I suggest you lower the rear tire pressure slightly when less than maximum passengers and cargo are on board.
10-14-2014, 09:51 AM | #6 |
Rep 28
Thanks all for taking the time to reply. I did think the tyre pressure for the rear set looked a bit on the high side.
I currently have 34 PSI at the front and 38 PSI at the rear. |
10-15-2014, 07:15 AM | #7 |
Rep 1,003
33 psi front 35 psi rear, cold, on my square 225-18 Contis. With iDrive coded to show actual pressure I'm seeing about +2 psi all around for typical steady-state driving.
10-15-2014, 08:19 AM | #9 |
Rep 1,003
It requires getting set up with an OBDII/serial cable and E-Sys, which is about a 5-6/10 difficulty, maybe a tad higher or lower depending on your fluency with a computer. Check out the DIY/Coding subforum for more details.
10-15-2014, 08:37 AM | #10 |
Rep 28
Excellent. Many thanks for that. I will have a look to see what I can find on the subject.
10-15-2014, 08:53 AM | #11 |
Rep 102
Drives: 2013 328xi Sport Line
You also need the TPMS sensors in the wheels. In Canada, it is built into the ABS (not sure if this true all the time). I coded this on my car, not realizing that was the case, so all I get is blanks for tire (tyre) pressure and temperature, but a green indicator implying all is well.
10-15-2014, 09:00 AM | #12 | |
Rep 28
I assume the dealership would charge a premium to have it done ?. Thanks |
10-15-2014, 09:03 AM | #13 | |
Rep 102
I'm pretty familiar with computers, so the coding was not that complicated. However, Shawn in the DIY coding forum is of tremendous help and there is a plethora of how-to's and guides in there too. The added benefit is that there are so many other things you can open up in your vehicle that you would have had to pay big $$ to get. |
10-15-2014, 09:07 AM | #14 | |
Rep 28
10-15-2014, 11:14 AM | #15 | |
Rep 1,003
It's worth a shot to ask, maybe your dealer is friendly and kind enough to offer, perhaps for a half hour of labor. |
10-18-2014, 06:27 PM | #17 |
Rep 296
I use 2 lbs heavier than the door says. Most of my miles are highway and don't have any potholes where I live. This helps keep the mileage up a little.
10-19-2014, 07:49 AM | #18 |
Pace Car Driver
1548
Rep 3,164
10-20-2014, 06:15 PM | #19 |
Rep 296
Not really concerned about mileage, I get about 27mpg. I've just always kept a little firmer pressure in my tires - for long trips you can see a slight gain in MPG if you go a little firmer.
