02-04-2017, 04:08 PM | #1 |
Rep 465
Bmw Servicing (gold Mine)
I recently took my 2015 Bmw 335 xdrive with stock 18 inch rims with run flats. (LEASE)
I live in the NY/NJ area so the roads arent the best but im not riding off of freeways. I took my car in and I am suppose to recieve back today. I recieved a call from an Advisor saying I will need to get the tires change soon because they are worn. also my rims are bent and I also need an alignment. Non of which are free apperantly. Am I missing something ??? I thought atleast the tires and alignment would be free. She gave me an estimate of over $2200 bucks. Im super angry about this. So I want to know any tips that can help me now or in the future of owning my car. Is there anyway I can avoid this or get out of paying this total amount ?? If I got new tires and rims and alignment from local shop would my lease warranty be voided ?? im not sure what to do and need help Thanks Bimmer Boy |
02-04-2017, 04:13 PM | #2 | |
Rep 698
02-04-2017, 04:22 PM | #3 | |
Rep 1,029
Here in LA. the streets are also a mess so I feel your pain. Good luck.
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
02-04-2017, 04:22 PM | #4 | |
Rep 465
Thanks I appreciate that. my last bmw was financed so I did what I wanted just dont feel financing is the best idea. but dont wanna get off topic here |
02-04-2017, 04:24 PM | #5 | |
Rep 465
Could I get balance and alignment elsewhere aswell ? And im thinking about just buying my own tires and rims and fit them on. & put back oem when I have to return the car. Does that make sense? |
KGB_123_99404.50 |
02-04-2017, 04:36 PM | #8 |
Rep 465
02-04-2017, 04:37 PM | #9 | |
Rep 465
I will take off these rims. Put on my own rimsand tires. ride that out till im about to turn it in and buy oems and put them on and return the car. |
02-04-2017, 04:44 PM | #11 |
Rep 465
Sounds like a good idea for lease end. But what about now. Still stuck on what I should do. Not trying to spend $2200 right now on new tires rim straightening and alignment
02-04-2017, 04:59 PM | #12 |
Rep 16,140
Look into reconditioned OEM wheels, they come off wrecks. They usually run around $150 each, as opposed to new at $400 each. Get the tires from tirerack.com, they should be around $200 each. Also look into junk yards, you could find wheels with tires on them.
02-04-2017, 06:54 PM | #13 |
Rep 243
lots of single wheels on eBay
02-04-2017, 07:57 PM | #14 |
Rep 1,342
First thing I'd do is take it to a good independent tire shop and get a 2nd opinion.
You can get the tires anywhere you want, but have to be similar to what the car came with (run-flat in your case)...unless you want to swap again before lease turn-in. If you have a bent wheel, look for a reconditioned replacement (like Billfitz said). Last time I got tires, the couple places I checked (like Discount Tire) would not do the alignment, they said I should have BMW do it. Do you have a vibration or something? Why did you take it in? Also, did they tell you the tread depth? If it's less than 3/32", then you'll need to replace. |
02-05-2017, 12:23 AM | #15 | |
Rep 1,986
eluded3065.50 |
02-05-2017, 09:27 AM | #16 |
Rep 123
Only 17K miles and you're in need of replacement?!?
Edit: Next time get the tire warranty (my biggest regret this time around) I've had 3 replacements and 3 patches thanks to Chicago road conditions - I would advise that for anyone who lives in a major, cold-weather city. Also, you can definitely get the tire replaced for $100-150 less at an independent shop and it won't void your warranty. Only issue is that the shop may not have run-flats that'll fit your car readily in stock and it could take a day or two to arrive. |
02-05-2017, 09:28 AM | #17 |
Rep 1,648
Take it to a good independent alignment shop. During routine service, a dealer here in NJ told me that my rims were bent and quoted be ~$2k to replace all four rims. Instead, I went to an alignment shop to get the bent rims repaired and he said there was nothing wrong whatsoever with any of my rims! I just ended up getting my tires rotated and was out in half an hour with a $30 bill. Stealerships are called stealerships for a reason!
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
02-05-2017, 12:09 PM | #18 | |
Rep 465
Thanks alot. |
02-05-2017, 12:10 PM | #19 | |
Rep 465
No vibration just service due for the first time. OEM rims must be pretty cheap for this to happen so easily |
02-05-2017, 12:11 PM | #20 | |
Rep 465
02-05-2017, 12:12 PM | #21 | |
Rep 465
02-05-2017, 12:25 PM | #22 | ||
Rep 10,288
Tags |
alignment, damage, f30, rims and tires |
