04-10-2019, 07:39 AM | #111 |
Rep 545
04-10-2019, 08:02 PM | #112 | ||
Rep 5,392
The LL-01 designation was recently removed from Castrol European Formula only because they stopped paying a licensing fee to BMW. Same oil so I continue to use it! Simplest & cheapest BMW oil solution is to go to Walmart and buy Castrol Edge SAE 0W-40. Make sure that it says "European Formula" on the front. On the back in tiny print it says that meets the "BMW Longlife-01" specification which is what you want. Please see attached photos. Walmart sells 5 quart jugs for $25.xx and single quarts for $8.xx The manual for my 2015 335i xDrive N55 engine says to use 6.9 quarts of one of the following: 0W-30, 0W-40, 5W-30, 5W-40 Hope this helps! |
sspade2464.50 |
04-10-2019, 08:47 PM | #113 |
Rep 243
Been using OEM BMW motor oil for a few years under the free maintenance, my next OCI going to try LM and will report back if any difference.
04-10-2019, 10:20 PM | #114 | |
Rep 928
04-11-2019, 05:56 AM | #115 | |
Rep 227
Drives: 2000 BMW E39 M5
Let us know what your impressions are!
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
learntocode53.50 |
04-11-2019, 08:52 AM | #116 |
Rep 5,457
Drives: F30
Liqui Moly SAE 5w40 every five thousand miles. Worth the extra few dollars for me. Buy two or three 5L jugs at a time on eBay.
04-13-2019, 07:26 AM | #117 |
Rep 172
Drives: 2015 328i
Talked to a bunch of Germans and European enthusiasts here. They all said Liqui Moly is not as good as it used to be and everybody hypes it.
04-18-2019, 07:33 PM | #118 | |||
Rep 3,947
110,000 miles on my N55 engine which has been tracked a LOT. OCI every 5k miles with Castrol Edge 0w-40 from Walmart at $25/5quarts. Done. Quote:
04-18-2019, 09:30 PM | #119 |
Rep 16,076
It's in my iDrive too, 2 MPG better gas mileage after going from BMW oil to Liqui Moly Molygen plus Ceratec. I haven't noticed any change in the engine sound or smoothness or anything else, and I wasn't expecting better mileage, but I doubt that my dashboard readout is lying to me.
04-18-2019, 09:43 PM | #120 | |
Rep 3,947
I'm very skeptical that you'd see a 2 MPG increase when using the same SAE viscosity engine oil. If it were that easy to get such an increase, BMW would have made that oil the standard and therefore used for the EPA fuel economy tests. You could easily see a 2 MPG increase from a variety of factors on a typical drive. |
04-19-2019, 05:15 AM | #122 |
Rep 3,947
04-19-2019, 01:01 PM | #124 |
Rep 16,076
04-19-2019, 06:58 PM | #125 | |
Rep 3,947
Does that pass the common sense test? If BMW could get an 8% improvement in fuel economy from a minor change in motor oil, why even bother with tech like direct injection. Just make Liqui Moly the factory fill and the specification all other motor oils have to meet. Or is more plausible that some other variable other than engine oil is resulting in your 2MPG gain? Is it possible it could even be psychological - self fulfilling prophecy? "I just changed engine oils. I'm going to see if this results in improved fuel economy." And you subsequently drive more conservatively than you did with the other motor oil because now you're actually paying attention. |
04-19-2019, 10:36 PM | #126 |
Rep 5,457
Drives: F30
For me, its about $8 more expensive per oil change to use the Liqui Moly Leichtlauf 5W-40.
At four changes a year (20k) thats about $32 total. When I think about all the studid shit I waste money on throughout an entire year... this becomes a no brainer. Also... I love the fact that my LM containers are the perfect quantity for my engine (5L) and dont leave me short like stuff you find at your local Walmart, AutoZone, etc. |
04-19-2019, 10:58 PM | #127 |
Rep 5,457
Drives: F30
To the contrary...
My last oil of choice (about 4 changes ago and back) is looking like the BEST overall value on the market. Being the factory fill for countless high end vehicles. Can be had for under $25 with tax for a 5qt jug. Leaves you a touch short though. https://mobiloil.com/en/article/why-...il-1-motor-oil |
04-22-2019, 05:57 PM | #129 |
Rep 182
What do you folks think about this analysis on motor oil?
https://540ratblog.wordpress.com/201...-test-ranking/ by 540ratblog. Seems like an impartial and factual analysis...unless someone has any info if this guy has been bought out or is shady? |
04-24-2019, 12:47 PM | #130 |
Rep 1,686
Drives: 2014 428i and 2018 X5
I found this video interesting... Amazon Motor Oil???
04-24-2019, 01:13 PM | #131 |
Rep 387
08-04-2019, 06:41 PM | #132 |
Rep 5,577
