10-21-2020, 04:59 PM | #1 |
Rep 18
Drives: BMW F30 318d M Sport LCI
Brake Upgrade
Evening/Afternoon/Morning All,
I'm sure that this has popped up a 1000+ times by now but I am looking to upgrade the brakes on my vehicle and looking to do a BBK without paying stupid costs. Now I've seen various older generations of BMW using calipers from other Manufacturers that are using Brembo Calipers (Not cheap, any day of the week!) My question is, I have seen a rather nice set of Range Rover Sport SVR 6 Pot Front Calipers for sale on eBay (Yes, ebay!) and was considering to pair that with the 4 Pot M Perf Calipers and a set of F80 M3 Discs to retain the PCD and the Centre bore. My question is, would this set up work? (I know that with enough money, anything will work!) I'm just concerned about the bias of it all and the fact that I would be potentially using calipers meant for the front of the vehicle on the rear and have seen on other forums that this could cause severe lock up if not done right. Am I ambitious, stupid or a bit of both? (I haven't bought anything yet so just looking to get all my research in before making a potentially very stupid decision!) Thanks all for the help and here are a couple of links to what I am looking at. SVR Calipers: https://www.ebay.co.uk/itm/Ranger-Ro...7726%7Ciid%3A1 M Perf Calipers: https://www.ebay.co.uk/itm/BMW-M-Per...7726%7Ciid%3A1 |
10-21-2020, 06:20 PM | #2 |
Rep 923
bmw engineers didn't forget to engineer your brakes. As they are they're better than almost any car on the road--leading me to get rear-ended when I stopped to save the life of two stupid f'n deer.
If they don't stop you as fast as you want, perhaps a prior owner put some pad designed to keep your wheels look pretty longer instead of stop shorter. Also, I would be concerned with messing the bias and how the car might control things with its systems...but more I'd be concerned with your creating instability braking in a turn or that sort of thing. I worry about everything, truth be told, but brakes are very fundamental and probably the most important system you have on your car. I wouldn't mess around too much with them. How about a nice paint job and cool decal on the caliper instead? Textar pads are the ones I'll always use, fyi. ...and a bump.
Billfitz8220.50 |
10-21-2020, 07:17 PM | #3 | |
Rep 5,391
10-22-2020, 10:30 AM | #4 | |
Rep 18
10-22-2020, 10:32 AM | #5 |
Rep 18
Ahh, sorry! It is a 2016 318d M Sport but without the M Sport/M Performance brakes. Once Rona has decided to stop screwing us over, I would start getting into track days as always liked that side of things and I feel confident enough now to start venturing into that side of things.
10-22-2020, 04:07 PM | #6 | |
Rep 5,391
First, it's a lot of hassle to attempt to get this to function correctly. Brakes are a life/death safety system that you cannot afford to not work perfectly. Second, in the costs in the links that you provided there is no advantage versus doing a factory approved F3x brake upgrade. Third, the power of the engine in your car, even if it was heavily modified, would just never be too much on the track for a well done F3x brake upgrade. So 6-pot/4-pot, assuming that it could be rigged to work correctly, would be such overkill. The extra braking capacity, over an F3x brake upgrade, would never really be used. Having said that, you can do a cracking F3x brake upgrade that will absolutely amaze you on the street and on the track. I wish you lived around the corner to be able to try my brakes. The M Performance brakes that you mentioned are Front 370mm and Rear 345mm. They are contained in an official BMW M Performance aftermarket brake kit. They only come in red, orange or yellow. The exact same calipers come in blue on F3x 6-cylinder models as a $600 factory line item option. So you'll need to purchase used calipers: Please see photo of front and rear calipers. FRONT 370mm CALIPERS Front calipers in the link that you provided that will say "370/380" in raised lettering on the rear of the casting. Make certain of this. There is an almost identical caliper that says "340" on the rear of the casting. You do NOT want 340's! In the US, a used pair of 370's would cost between $450-$600 depending on market and condition. REAR 345mm CALIPERS Used rear 345 calipers would need to be purchased. Typically they cost $400-$500 per pair. I've seen a set of four calipers that were discolored and in need of being rebuilt for a total of $700. I've also seen a set of four 370/345 calipers from chipped to pristine condition from $850-$1,100. I wouldn't pay more than $1,100 for a perfect set. If anyone tries to sell calipers from an M3/M4 at a higher price because they are "///M" brakes, don't fall for the con. They are exactly the same as F3x calipers. The same goes for red, orange or yellow calipers with the claim that M Performance are better than blue M Sport. The calipers are identical except for color. Do not pay more for either of these reasons. F3x Brembo calipers are rock solid. The only things to visually inspect if you purchase front or rear calipers in person are below. You can also ask the seller these questions and have many closeup photos can be emailed to you. 1) Do the brake bleeder screws turn open and closed freely with a wrench. Just make sure that they aren't frozen or cross threaded. But that is rare. There are replacement parts available. 2) When you look inside the caliper body you will see four round rubber dust caps. (The rear calipers have only two dust caps.) The dust caps cover the brake pistons and piston seals. Just look to see that they are not frayed or worn or leaking brake fluid. Again there are replacement parts available for brake pistons, seals and dust caps. If dust caps appear worn but none are leaking, then that's no big deal. It's cheap to pop on new rubber dust caps. 3) Inspect the paint on the outside of the caliper for cosmetic appearance. The blue Brembo paint dries out over time and chips easily. So don't be surprised if there are chips. When you are handling the calipers do not let them touch each other or they will chip like crazy. Wrap each caliper in their own towel or bubble wrap. 4) You are most likely to find these used calipers in blue (rather than red, orange or yellow). If the blue color has turned greenish, that typically means that the car has been tracked and the sustained high brake temperatures have caused some discoloration. That doesn't mean that the brakes aren't fully functional. Just make sure to inspect them as in #1 above. I got a great price on a greenish set that had been raced on an M3. (These same calipers come stock on M3/M4.) I had them powder coated and replaced seals & dust caps. Pistons were fine. You can always buy an Estoril Blue touchup paint pen. Or you can change the color of the four calipers completely for as little as $60 using G2USA Caliper Paint. Or a more costly option is to have the pistons/seals removed, calipers media blasted, powder coated and reassembled with new seals and dust caps. Powder coating is roughly $200-$250 per set of four calipers, plus any replacement parts. I have more recommendations on pads, rotors, dust shields and stainless steel brake lines that I will put in subsequent posts. Hope this helps! |
10-22-2020, 04:33 PM | #7 | |
Rep 18
Thank you for the detail on this one. I have seen many 4 Pot/2 Pot kits for sale and some of them are asking silly money due to them being off of an M Car and yeah, you are right in the fact that it is the same calipers that are used on a non-M car. Think once I've costed it up including the installation costs, you are right in the fact that it would be more than getting the factory upgrade 4f/2r upgrade and some decent discs and pads (I know someone who works for EBC that may be able to help out with the pads and possibly rotors as well!) Thank you for the insight into this. I think I was being a bit over zealous and wanting the look more than the functionality (As great as it would be to have a 6 Pot/4 Pot configuration on the car!) Thanks johnung! |
johnung4525.00 |
10-22-2020, 06:24 PM | #8 | |
Rep 1,109
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
10-22-2020, 09:04 PM | #9 |
Rep 16,054
Aside from the fact that BMW M Performance brakes are perfectly OK, calipers that fit on a Range Rover are not going to fit onto a BMW, and BMW front calipers are not going to fit onto the rear of a BMW anymore than can the front doors of a Range Rover fit onto an F30 or the front doors of an F30 be swapped with the rear doors.
10-23-2020, 09:11 AM | #10 | |
Rep 1,934
Moreover, it takes a lot of engineering skill and time spent to retrofit Brembos from other cars onto a car the model wasn't made for, but it is entirely possible. You just need to keep in mind the brake bias figures, and master cylinder flow compared to the calipers piston surface area. This information is readily available on the internet. The same information Brembo and AP Racing, Willwood, and everyone else uses to sell us aftermarket kits. I'm pretty sure the Brembo GT is able to be used without any changes to our MC, so there's that. This kind of modding takes skill and know how, but again it's not impossible. It's a critical part so not anyone should or can do it, especially when there are perfectly capable kits like the 4pot Brembos we have.
10-23-2020, 09:24 AM | #11 | ||
Rep 500
10-23-2020, 10:55 AM | #12 | |
M Enthusiast
438
Rep 624
Drives: 2018 F80 M3 ZCP
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
10-23-2020, 10:59 AM | #13 |
M Enthusiast
438
Rep 624
Also OP, F80 rotors will not work with the F30 platform. This has been confirmed by multiple people on the forums. You can make the SVR calipers fit. As a matter of fact, you can get pretty much any calipers to fit as long as you engineer a bracket that fits. But will that be safe? Guess that's up to you to decide.
10-23-2020, 11:06 AM | #14 |
Rep 16,054
10-23-2020, 11:09 AM | #15 | ||
Rep 1,934
10-23-2020, 11:12 AM | #16 |
Rep 1,934
I know the op didn't say plug and play, just Whether it would work. And it could. The F80 rotors would require the F80 upright. And that is only possible if you are rwd, etc etc.
The key point I made is that's it's possible, but definitely not worth the effort. Especially for a 20i that will never outrun the 4pot Brembos that are readily available.
BimR245.00 BMWF30GuyUK8.00 |
10-23-2020, 04:49 PM | #17 |
Rep 18
Evening all.
Thank you all for proving some of your time to help me with this query. I think my decision has been made with the help from all of the replies that I've had. Having weighed up the costs again, it will be more cost effective (Safer too!!) to get the M Sport/M Performamce brakes retrofitted to the car. As for the post from BimR, yes, I was lookong for a BBK that was an easy fit and would still work with the F30 Platform. Gonna keep scouring for a good set of calipers and then get some new rotors! Thanks all. I'm sure that I'll be back woth the progress of the build!! 😊 |
BimR245.00 |
11-15-2020, 11:23 AM | #18 | |
Rep 68
2017 440ix w/ M Sport/Aero packages/ MPPSK/MPBBK/6MT
2018 X5 xDrive 35i w/ M Sport |
11-15-2020, 08:10 PM | #19 | |
Rep 833
Drives: BMW F36, E36, E93
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
11-16-2020, 12:40 AM | #20 | ||
Rep 5,391
Crossdrilled rotors have the best bite and best performance in rain. That's why you'll see crossdrilled on street performance cars from Porsche, Mercedes, McLaren, etc. Your car has Front 370mm x 30mm and Rear 330mm x 20mm. [typo correction: Grey fronts are 340mm x 30mm] The M Performance red calipers and the M Sport blue calipers for your car are identical. Front 370mm x 30mm and Rear 345mm x 24mm. M Performance also come in yellow or orange. A set of used 370/345 blue calipers in great condition are about $1,100. A set of new 370/345 red calipers from the M Performance Kit are about $1,900 discounted at the GetBMWParts website. The kit also includes the BMW Front 370mm x 30mm dimpled/slotted rotors and all four sets of BMW brake pads. IMO the dimpled/slotted are noisy/not much better bite than plain, and the BMW pads are no better than average. I'd sell them and buy StopTech Crossdrilled rotors and Hawk 5.0 pads. Both have superior bite. Whether you go with new red or used blue 370/345 calipers, the front grey 340 calipers can be sold for about $400-$500 on the used market. The rear 330 might be worth $100-$200 if you can find someone with F312/R300 brakes who wants to upgrade to F340/R330. Used rotors have some value if you sell them locally. They are too heavy/costly to ship. Another brake upgrade option is to keep the front 340 calipers and upgrade to rear 345mm calipers. F340/R330 tend to nose dive under heavy braking. But F340/R345 will squat very controllably under heavy braking. Rear 345mm calipers in excellent condition cost about $450-$500. With all of these options, I recommend StopTech Crossdrilled rotors and Hawk 5.0 pads. And I'd upgrade to Stainless steel brake lines for more solid pedal feel. G2USA Caliper Paint is the best way to change the color of your brakes. It's a two part epoxy like paint that brushes on right on the car and levels out as it dries to a sprayed on finish. Photo shows my buddy's calipers. He bought them used in blue but water red so he painted them with G2. Hope this helps! |
paulymu62.50 |
11-16-2020, 07:54 PM | #21 | |
Rep 68
11-16-2020, 09:00 PM | #22 | |
Rep 83
Drives: 2016 340ix MPPSK| 2015 R60 JCW
Base 40i cars with 340i stamped calipers have 340mm front rotors, 345mm rear rotors. Bigger caliper in front but slightly smaller front rotors. F8x M3/M4 and 35i/40i with 370/380 stamped calipers have 370mm/380mm front rotors and 345mm rear rotors. M cars use the bigger 380mm front rotors since the hub mount is 10mm offset. Last edited by ImBlue; 11-16-2020 at 09:10 PM.. |
paulymu62.50 |
