BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N20 1/4 Mile Thread
proTUNING Freaks
      08-23-2019, 10:58 PM   #199
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
Bmw f30 328i. BM3 stage 1
98 degrees outside
1/4 - 13.7012
Update 13.2 1/4
Running stage 2 e30 bm3
Slowest n20 of them all
      08-28-2019, 01:57 AM   #200
jan31
jan31's Avatar
Drives: 2014 F32 428I Xdrive (N26)
Originally Posted by DR.Nefario View Post
Post up your results. I did 14.1@99.5 with a horrible 2.2 60ft. It started raining before I could get another run. Only mod is BMS Stage 1 tune.
I did same time stock, 428 xdrive
      09-01-2019, 02:20 PM   #201
Sleepy_N20
12 F30 N20
Drives: BMW 328i
just ran my 2012 F30 N20. Best i got with street tires was 13.59
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
MST turbo intake inlet
diverter valve
i ran a 13.83 with DSC off then a 13.59 with it on
      09-02-2019, 02:33 AM   #202
bmwchue
Drives: 2013 bmw 328i
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
dam somethings wrong there
sspade2464.50
      09-02-2019, 10:53 AM   #203
Sleepy_N20
12 F30 N20
Drives: BMW 328i
I agree. im pretty sure I was leaving at the wrong RPM. I was launching at 2k and I need to leave probably around 3k so my turbo is fully spooled.
what do you think I should run the 1/4 mile in with my mods?
I haven't dyno it yet. but the description of the turbo said with the Epic tune and MHI turbo I should have 400hp. plus other mods I'm thinking I have around 440 crank hp. thoughts?
      09-02-2019, 12:31 PM   #204
jordan35i
jordan35i's Avatar
Drives: 340i
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
All that and no downpipe?
CURRENT: '18 340i
      09-02-2019, 12:38 PM   #205
Sleepy_N20
12 F30 N20
Drives: BMW 328i
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
i don't think my car will pass emissions with catless down. this is still my daily.
      09-02-2019, 04:00 PM   #206
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Depends on how aggressive the tune is. I can't imagine it could be all that agressive with a stock downpipe. 400whp sounds waaaay too optimistic. With a proper tune, catless DP (and internals to support) you have a setup capable of 12.7-12.8 I would imagine. As the car sits, probably making around 300whp, you should be around 13.0-13.2. Keep in mind times vary a bunch depending on conditions, temp, humidity, altitude etc. (DA).
      09-03-2019, 07:46 AM   #207
Sleepy_N20
12 F30 N20
Drives: BMW 328i
yeah 300whp sounds more realistic. once I get it dyno I'll post up results. 13.0 seems doable if I iron out my launch. 12's if i get sticky tires..... hopefully???
I'm not sure how aggressive the tune is. maybe I'll reach out to Epic and ask em questions.
      09-03-2019, 08:02 AM   #208
rjd_F30
rjd_F30's Avatar
300whp should be enough to go 12.9's with a good low DA.
And yah, I would definitely reach out to whoever tuned the car and ask them, at the very least, what the boost, timing, and air/fuel targets are.
      09-03-2019, 09:40 PM   #209
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
I'm thinking about a pure stage turbo. Was the big turbo worth it. Honestly.
      10-02-2019, 05:41 PM   #210
SVTruong
SVTruong's Avatar
Drives: '15 428i GC, '15 640i GC
Hot 90 degree weather. I ran a 14.1 on my stock run flats and trapped at 100mph. I think I can do mid 13 on a cooler day.
      10-18-2019, 10:53 AM   #211
Sleepy_N20
12 F30 N20
Drives: BMW 328i
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
mods i have:
MHI big Turbo
Epic tune
intercooler
boost/charge pipe
diverter valve
I'm not sure what kind of boost you will get with a Pure turbo but I am happy with my setup. my gas mileage is still pretty good as long as I'm not flooring it at every stop light.
I spent close to $4K and I did all the installs myself. it took 3 of us 12hrs to install everything.
      06-04-2020, 03:27 PM   #212
335Abuser
Drives: 2011 550i M-Sport
I didn't see a thread on the newer B46 330s anywhere so I'd figure I'd post our numbers for reference. My dad's 2017 Sportline 330i. Stock except for 19" F32 M-Sport wheels and JB+ at max setting. The drag strip run was with a really strong headwind, so maybe another mile or two is possible. I once trapped it 102 with the dragy. Also attached are best runs on the street with the dragy. And for people wondering if the dragy is accurate, it sure is! I ran it concurrently on my 550i and it ran within a thousandth of a second and 0.1mph
2015 Estoril Blue 6-Speed M235i
VipinLJ1941.50
Avaley731.00
      08-22-2020, 04:15 AM   #213
SRHosein
Trinidad_and_tobago
194
Drives: BMW 330e M-sport
BMW 330e Hybrid B48
Owner: Shane Hosein
Car: BMW F30, 2016, 330e Hybrid, B48 engine
Drivetrain: 8AT RWD
Time: 13.382s (13.382 on track which was not properly prepped as it was a street car shootout event, during day about 32C ambient temperatures, wheel spin 1,2,3 gears - fastest with dragy 13.03s)
MPH: 126.19 (Dragy was around 106mph so I believe there was an issue with the mph for the timing system.)
Stage: 2
Tune: Bootmod3 91 octane stage 2 OTS map
Fuel: 91 Octane (Trinidad low grade 91 octane fuel)
Mods: ER catless downpipe, FTP charge pipe, FTP intake pipe, BMS intake, Snow Performance Stage 2.5 kit - WMI (not tuned for methanol), 19" m437 rims from M3 using Michelin Pilot super sport (275/35/19 rear, 225/35/19 front), Tire Pressure was 32psi cold.
Curb Weight: rated at 3920lbs
Dyno: 350whp, 441wft-lbs. (stock was 268whp, 318wft-lbs)
I tested dragy and both time-slip, see also attached pretty accurate with dragy being 0.101s more. Dragy was 13.58s while time-slip was 13.481s.
Location: Wallerfield International Raceway (Trinidad and Tobago).
FB Page for more details: https://www.facebook.com/BM3ShahsMachineShop
Avaley731.00
      08-22-2020, 09:06 AM   #214
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
@335Abuser
Join and post your slip here so we can add you to the leaderboard.
https://www.facebook.com/groups/2443...651/?ref=share
      10-11-2020, 04:07 PM   #215
Avaley
Avaley's Avatar
731
Drives: f32 430ix & 982 GT4 PDK
Not my car but Dronamashina ran a 12.43 1/4 mile.
B48.
pretty sure RMMAGA has a B48 also running 12s
      10-17-2020, 04:17 PM   #216
Dronamashina
Dronamashina's Avatar
64
Drives: Bmw 340ix
Didn’t used launch control here, just floored it. E50 was used of course.
2018 340ix AWD B58 8AT | MGflasher ST1 |
Instagram: andreykrop
Youtube: DronaMashina
Avaley731.00
      02-19-2021, 11:34 PM   #217
sqwinny
Drives: 2013 6MT 328i M Sport
Went to the track today. Time is on the left 13.7. Just trying it out, nothing to expect. Grip vs street vs track is life changing. Was afraid to launch the car and break things.
I didn't find out that bm3 had coded in launch control for the 6MT until after I left. Tried it a couple times and wow what a difference on the street/parking lot. Bm3 appears to have 3 levels of launch control. 3100, 3300, 3600 and stops at 4000. Just hold clutch all the way down in sport + and mash the gas.
I Should be deeper into the 13s and run faster. Some cars are getting 13.1,13.2 with less mods. Next time I know what to expect so maybe I can break 12.
Gearing seems a little more difficult as I hit 102-103mph in 3rd gear with about 80-100 feet to the end of the track but it's too short to shift into 4th. Didn't think to flat foot shift into 4th at the time. Perhaps with a better launch and 60' this can happen. Either way, had fun, learned more about the car on this grippy surface.
2013 328i 6MT FBO stage 2 E30 blend.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
sspade2464.50
VipinLJ1941.50
      02-20-2021, 05:30 AM   #218
sspade
sspade's Avatar
Drives: F30
@sqwinny join this group and post your slip so you'll be added to the leaderboard.
https://www.facebook.com/groups/244324833434651/
      02-20-2021, 01:56 PM   #219
sqwinny
I don't use Facebook, won't be added to the database unless someone does it for me.
      05-01-2021, 09:11 AM   #220
SRHosein
Trinidad_and_tobago
194
Good day all,
Could we start accepting dragy results as all other platforms recognize them?
B58/S58 ect.
I believe we will get more people on leaderboard that way and also there are COVID restrictions for track and people who do not have an official track.
Regards,
Shane
VipinLJ1941.50
