BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Super small oil leak, can anyone tell me what this part is?
      03-17-2019, 05:41 PM   #1
Ahanix
Drives: 2016 340i
I purchased my 340ix CPO about a month ago and I started noticing a bit of oil (maybe a dime worth) on my floor of my garage the last two nights. Got under the car today and noticed the following.
Can anyone tell me what part this appears to be? Just want to have a clue before I talk to a service advisor tomorrow.
      03-17-2019, 06:00 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Looks like the transfer case to me...
      03-17-2019, 06:01 PM   #3
sspade
sspade's Avatar
Drives: F30
^ there is a drain plug visible and an axle sticking out of it...
You are also xDrive.
Its definitely your transfer case leaking.
      03-17-2019, 10:02 PM   #4
Ahanix
Drives: 2016 340i
Thanks!
      03-18-2019, 08:29 AM   #5
JimKden
Drives: 2016 340xi
It' engine oil. Gear case oil is almost clear in color.
      03-18-2019, 08:36 AM   #6
obert
obert's Avatar
Drives: 2013 328i
Curious to know what’s leaking. OP you don’t see a leak from up top anywhere? To have it dripping like that means it’s leaking a lot.
      03-18-2019, 10:20 AM   #7
Ahanix
Drives: 2016 340i
No other leaking present, if you look at the bolt from those angles you can see it appears to be leaking out of that lower area, almost like the bolt isn't tight enough. I'll be taking it in tomorrow and will keep you posted.
      03-18-2019, 10:29 AM   #8
obert
obert's Avatar
Drives: 2013 328i
CPO is a good thing for stuff like this
Just had a oil leak fixed under CPO.
      03-18-2019, 10:42 AM   #9
sspade
sspade's Avatar
Drives: F30
I do agree, looks a bit dark for gear oil but it does appear to be coming directly out of the transfer case (third pic).
Then again, when I replaced the gear oil in my rear differential last month - it was BLACK... not clear like when it goes in fresh.
Interested to hear what the dealer tells OP.
      03-18-2019, 12:42 PM   #10
Ahanix
Drives: 2016 340i
Thanks for the info, this has been really helpful! Trying to get all of this squared away before Bootmod3 for B58 is released.
sspade2464.50
      03-19-2019, 11:26 AM   #11
Ahanix
Drives: 2016 340i
Figured I would update this thread. Service found a leak on the turbo oil return line and are ordering it in and fixing it tomorrow. Was just a coincidence that it was dripping down on the transfer case.
obert1781.00
      03-19-2019, 02:02 PM   #12
doodlebro
Drives: '17 X3 35i
Are they replacing the turbo as well? A leaking return line points to issues with the turbo and getting old oil out/new oil in. I'd be a pest about it and make sure the return line was physically broken and not leaking from where it connects to the turbo.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      03-19-2019, 02:16 PM   #13
Ahanix
Drives: 2016 340i
They sent me back with the car today while they overnight the return line, they didn't seem to have any concern since the line has a very small leak from the oil pan side rather than the turbo.
They were just going to replace the o-rings, but the technician came back and said the line should be replaced as a precaution (I am assuming based on this comment that it is broken)
Thanks for the heads up, I am going to push on them about the Turbo. I don't really need a failed turbo / reason to get a Pure Turbo any time soon, especially when I'm still under warranty.
      02-08-2023, 07:43 AM   #14
Elipiz23
Drives: Bmw 3 series 335I x drive F30
OP I know it’s been a while but any update on the repair? How’s it holding up? Recently had an oil leak as well and your post was identical to the leak I have. Going into service today
      04-10-2023, 05:28 AM   #15
danneha
Drives: 340i
Have almost the exact same leaking. Oil adds up under the front diff after a coupel of days.
2019 340i with only 30000 miles.
Taking it to service tomorrow.
      04-10-2023, 05:29 AM   #16
danneha
Drives: 340i
Did they find anything?
