04-20-2020, 04:24 PM | #45 | |
Rep 618
04-20-2020, 04:30 PM | #46 | ||
Rep 1,934
04-20-2020, 04:33 PM | #47 | ||
Rep 468
Could have been on the UK forums, I'll take a look |
04-20-2020, 04:47 PM | #48 |
Rep 618
04-20-2020, 04:49 PM | #49 |
Rep 618
Yeh aware of this case with the OP & yes the MC’s on cars with the blue brakes from factory are the correct size for this upgrade.
04-20-2020, 05:09 PM | #50 | |
Rep 1,934
04-20-2020, 05:30 PM | #51 |
Rep 618
Correct, the cars with the grey 340mm 4 pots also get the larger MC
04-20-2020, 11:19 PM | #52 | |
Rep 185
04-22-2020, 02:14 PM | #54 |
Rep 185
I definitely need to get the brakes coded in. I haven't really driven the car in a couple of weeks but I just expected the brakes to be more responsive. Though I've been driving my panamera turbo all this time so I guess I expected the new calipers to be the same or better than the porsche.
04-22-2020, 02:55 PM | #55 |
Rep 618
I’m willing to bet that there is still air in the system, and it needs a proper bleed using ISTA.
I’m fairly confident that this will get things working as they should. I can confirm that these brakes bite hard and do not have a soft pedal |
04-22-2020, 03:18 PM | #56 |
Rep 185
I think so too, that's why I have to get them coded, again my opinion is biased because I'm comparing to a different car.
04-23-2020, 06:11 AM | #60 | |
Not stock
474
Rep 617
The number of pistons is irrelevant. Hydraulic systems are all about displacement and displacement, just like engines, is all about volume (cubic inch, cubic mm, whatever). So if the stock front pistons, say, had single 1.90" pistons then the surface area behind the piston is 16.62 sq in. Converting to a 4-piston caliper with 1.65" pistons results in 34.2 sq in. You can see how a simple 1:1 swap of these pistons is going to result in much less travel of the brake pistons vs. the pedal without an MC change or other clever pump trickery. I don't have that specs of the F10 M5 calipers but "you only added 2 more pistons" could be insignificant or quite significant. When I built my custom Wilwood kit for my other BMW I went with 6-piston SL6R calipers but with staggered piston sizes that, when added up, were within the same region of surface area as the stock single piston calipers so I did not have to swap MCs, etc. The F30 is trickier yet - the coding might adjust brake bias, but more over, it actually adjusts some sort of valving within the ABS unit. I put the oranage M Performance BBK on my car and drove around the neighborhood with them fully bled and it was garbage - the pedal went nearly to the floor, it'd "lose pressure" if you stayed on it, it was just wrong. Fired up the laptop, loaded E-Sys and programmed it for the sport brakes - all better, 100%. So be careful - if you have the piston measurements we can do the math (its very simple) but swapping these calipers (with two piston rears, too) may put the system outside of what it can displace w/o a MC change... coding or otherwise.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
04-23-2020, 06:16 AM | #61 | |
Rep 618
04-23-2020, 07:44 AM | #62 | |
Rep 185
04-23-2020, 07:54 AM | #63 |
Not stock
474
Rep 617
Nice - I didn't read for technical specs just wanted to chime in and let that poster know that the number of pistons is only part of the equation.
Nice - depending on the MC size and ratios you may not need/want to code. If it is working great now, I don't think the coding will make it "more great" - my brakes felt like absolute garbage after the M Perf install, and coding put it right back to stock feeling or dare I say even a little too grabby at low speed.
04-23-2020, 07:57 AM | #64 | |
Not stock
474
Rep 617
I have an N26 328 which obviously does not have the 370mm/380mm option. I don't have PNs handy but I also did not have to change my MC to go to 370/345mm. Coding is not only for the ABS but is absolutely for pressure restriction/proportioning. My pedal felt like I forgot to bleed my brakes (used a Motive). I drove around the block with garbage pedal, pulled into garage, coded performance brakes, and its been amazing since. No MC change, no bleeding further, etc. Edit: MC PN# on my car going by my VIN is 34336851095 If you look that part up, it's the same part on ALL F20/F21/F22/F23/F30/F31/F34/F32/F33/F36 from the "316d" to the 355/340/etc. NO F80 models use the same MC but ALL of the non-M cars use it.
04-23-2020, 08:41 AM | #65 | |
Rep 618
If so, this is inaccurate. Your car with the base brakes (328) would not have the larger MC, and you are correct that this smaller MC is in fact capable of powering the BMW M Performance upgrade brakes (370 / 345) this is also verified by the fact that BMW themselves sell the orange / red / yellow brake retrofit kit without a MC upgrade included as part of the package. However, on MOST (but not all) cars that are optioned from the factory with blue the S2NHA M Sport brakes (which have identical piston sizes to the M Perf) the cars come with the same MC as the F8x ///M cars. In the USA, this is p/no: 34337849878 (for left hand drive cars) and in the UK it is p/no: 34337849879 (for right hand drive cars) ETK: https://bimmercat.com/bmw/en/parts/i...9878/appliance For example, if your N26 328 had been optioned from new with the M Sport brakes, it would have been fitted with 34337849878, as shown on the ETK: https://bimmercat.com/bmw/en/search/...26/ECE/34_1966 |
04-23-2020, 09:10 AM | #66 | |
Not stock
474
Rep 617
That part is not true - the 335i and M3 by default are NOT the same. I have had a number of people tell me that their 335s (base) have M3 MC's and "can I swap brakes because of this?" which is obviously loaded several ways. That said, take a look at the 34337849878 cross reference you linked. You'll find that the 335i is NOT listed as cross reference: https://www.realoem.com/bmw/enUS/par...78&series=F30N In fact, if you go to the 335i specifically, regardless of VIN or package, you'll see only one master cylinder available for that vehicle, of which is shared with every other non-M car, and no F8x. I am only trying to squash the "335i's have the same MC as M3s" - no they don't, not according to any ETK, S2NHA or otherwise.
