02-20-2021, 03:42 PM | #1 |
Rep 33
N47 vs B47
About to buy a 2015 lci 320d but when I did an HPI check I noticed the engine code N47N20o1
I was under the impression all Lci’s had the newer modular engines. Coming from petrol engines,specifically 320i B engine,I’m worried it may be too noisy.Is the B engine much quieter? Thanks |
02-20-2021, 03:55 PM | #2 | |
Rep 1,705
Personally, unless it is an exceptionally good deal I would look elsewhere and get the newer modular engine, lights, interior trim, updated suspension and steering, to name some of those LCI upgrades. |
02-20-2021, 04:07 PM | #3 |
Rep 33
It is an lci car.I’m a tad confused as I did quick free HPi checks on other lci cars so see if it mentions the engine code but doenst.It only tells you the power output,which most seem to match 188hp and 140kw even a 2017 shadow edition.I did another 2016 lci which must have had an older engine as that mentioned 181bhp.
So very confused |
02-20-2021, 04:22 PM | #4 |
Rep 1,705
Can you look here to see what engine it says;
https://www.mdecoder.com/ My current car shows the engine listed. |
02-20-2021, 04:31 PM | #5 |
Rep 33
Hpi check only gave me the last 4 digits of the vin.
The hpi records engine code as N47N2o1 188hp 140kw All other newer 320d cars I’ve looked at on auto trader and did a quick check came back as same power output.Obviously without paying for full HPi I can’t check exact engine code. |
02-21-2021, 02:21 AM | #7 | |
Rep 33
Guess the vin is the only way of knowing |
02-21-2021, 03:36 AM | #9 |
Rep 749
Drives: F31 320d xDrive M Sport
N47 was 181hp/280lbft and B47 was 188hp/295lbft.
I think.
02-21-2021, 03:39 AM | #10 | |
Rep 33
Yep it has two.Should be all good. Question is,can I live with the diesel noise after always having petrols.My brother has an N47 and sounds like a tractor compared to my 320i |
02-21-2021, 04:41 AM | #11 |
Rep 1,705
I wouldn't think that BMW would fit an old engine to an LCI car, that wouldn't happen. If it has all the other LCI bits, it must have a B series engine, but see if you can get the chassis number for the Decoder check. Isn't the chassis number on the HPI check?
02-21-2021, 04:48 AM | #12 | |
Rep 33
Still waiting for the vin from seller but I’m sure like you’ve all mentioned,it will be the B engine. |
02-21-2021, 05:10 AM | #13 |
Rep 1,992
Drives: F30 335d
The 4 pot diesels sound a bit tractor-like when cold and idling but once on the move they are refined.
02-21-2021, 05:11 AM | #14 |
Rep 573
Most likely a B47 if it has a twin exhaust.
When I put my reg in here, it gives me the engine code. https://www.bmw-warranty.co.uk/Login/Index |
Stuart j55.00 |
02-21-2021, 05:23 AM | #15 | |
Rep 33
02-21-2021, 08:59 AM | #18 |
Rep 1,158
02-21-2021, 02:04 PM | #21 |
Rep 1,992
Drives: F30 335d
Mine wasn't that bad, but only because it got a new bottom end and timing chain replacement courtesy of the BMW warranty.
if I've helped - an Appreciate would be, er, very appreciated!
