02-21-2021, 06:19 AM | #1 |
Rep 121
F36 side skirt extensions
Hi, I fancy fitting some genuine side skirt extensions to my F36. Messaged a seller on EBay who said they are just glued on and the fixings were not included. Checked the BMW instructions and that says use the fixings (15 a side I think) and glue.
Don't really fancy using glue as it would be messy if they ever had to come off. So my question is, how did you fit yours? Thanks! |
02-21-2021, 07:09 AM | #2 | |
Rep 2,118
Since fitting, I have used screws, washers and bolts to make sure they don't budge. They also have a thin strip of double sided tape across them.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
02-21-2021, 07:12 AM | #3 | ||
Rep 121
02-21-2021, 07:13 AM | #4 | |
Rep 2,056
You could use small bolts but they would be subject to corrosion. They shouldn’t be glued as such. The process is to use the 3M tape to align the blade and then use plastic rivets to secure (all which come with the blades). If the fixings are missing, the rivets are available from BMW and are not expensive. |
02-21-2021, 07:15 AM | #5 | ||
Rep 121
02-21-2021, 03:06 PM | #6 |
Crustacean denier
389
Rep 577
3M tape is how I did mine on the F31. The blades for that model have a raised strip toward the inner side, you sort of hook it behind the panel and it lines up perfectly.
02-22-2021, 02:09 AM | #9 | |
Rep 1,303
Although in hindsight its was probably easier to just remove the sideskirts from the car to fit them on a bench. |
02-22-2021, 02:29 AM | #10 |
Crustacean denier
389
Rep 577
02-22-2021, 03:48 AM | #11 | |
Rep 121
