08-03-2014, 03:37 AM | #881 |
Rep 44
Trunk Problem
Hello every body,
Happy Eid I have a BMW 328i Luxury with comfort access the trunk was working very will and once i was going to Mall and they check the Trunk i open the lock and they open from outside normal then when i finished and try to open it even physically or with the comfort access but i can it only open with the remote . Any one know this issue ? Thanks |
08-08-2014, 04:40 PM | #882 | |
Rep 389
I have same as you comfort access. There are three ways to open the trunk. 1- with all car doors unlocked you open by the button in the trunk Handel above the number plate , you need to press it in hard 2- you kick your foot under the car in the middle and then out, try to have your foot close to the bumper 3- remote key button to open the trunk In 2 and three the car doors can be Locked or unlocked and in the comfort access your key remote must be in your pocket or hand Now since it's working with remote then it looks like there is nothing wrong with your locking and unlocking mechanism. My only guess if it's not working using the Handel or comfort access assuming you are doing it correctly is that they use a different signal than the remote to open the trunck lock Your only option is to take it to Bavaria unfortunately Best of luck and keep us posted
08-09-2014, 03:07 AM | #883 | |
Rep 44
i think the problem on the physical key.... I send the car today to BMW and they told me it may be the trunk physical key also they have some changed must be done for this model as requirement from Germany and must leave the car till tomorrow... |
08-09-2014, 03:05 PM | #884 |
Rep 389
I hope they fix it for you Essam, keep us posted on the result and what they did. I think I have the same model and may need to do the same as well.
08-11-2014, 01:49 AM | #886 |
Rep 37
Hey everyone
So today i had the first problem with my car :/ I got error about the tyre pressure in ALL tyres suddenly and its not the first time, it happened to me 2 days ago and i int. the pressure Thing is, today also i had error on the Rear-right Tyre and i checked and it was normal i also noticed a nail in the Left-Front tyre is this the reason? or is it the sensors? Best Omar |
08-11-2014, 02:40 AM | #887 | |
Rep 44
I got the same but i go to check and found two tires without any air after i supply it with air and int. it work will without any issue. |
08-11-2014, 04:01 AM | #889 | |
Rep 389
You can try and fix it at fit and fix. As long as the nail is not near the side wall , it can be fixed. The reason is that you do not want a weak side wall in a run flat tire.
08-13-2014, 12:55 AM | #890 |
Rep 37
08-16-2014, 12:55 PM | #892 | |
Rep 44
They change the key and they change some thing on the machine and move two plastic plug from the front of the car and make software update. |
08-16-2014, 03:14 PM | #893 | |
Rep 389
Thanks ESSAM Kol dah !! It must have been a major bug. I wonder if I should talk to them about it in my next service, I have the comfort access but it has no problems yet
08-17-2014, 04:33 AM | #894 | |
Rep 44
My problem was not with the comfort access it was the trunk key and they change it ...for the others when i go they told me it is necessary and you should do it so i do it |
08-20-2014, 06:29 PM | #896 | |
Rep 389
Nobody will bug you about rims or tires or a spoiler For other changes I would change stuff which can be removed before going to maintainace easily as they are not to friendly
09-11-2014, 03:15 AM | #899 |
Rep 152
Hello Guys,
it has been quiet since some time. Hope all is well with you all. Anyways, I have some exciting news to all those who are interested, Finally & Proudly i was able to retrofit the NBT to my Car. SO now I believe I might be the first & only 316i with NBT The Unit is fully functional El 7amdoulelah with the following features: Navigation Voice Control Touch Controller Enhanced Bluetooth BMW Connected Apps BMW Live BMW Internet I will post some pics later today Cheers |
09-11-2014, 07:58 AM | #900 | |
Rep 1,436
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
09-11-2014, 04:00 PM | #902 | |
Rep 8
Congratulations! :)
How about the warranty? I have a 316i too that i bought this April but i am in dubai and i wanna do it but i guess it will void the warranty. |
