BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 New Feature Release - Import OTS Maps, learning experience ***
proTUNING Freaks
      05-22-2018, 10:08 AM   #1
proTUNING Freaks
proTUNING Freaks's Avatar
4496
Drives: powered by bootmod3
Hey guys,
We've mentioned this feature in the past as something we've been working on adding and it is now available in the editor. OTS maps that we provide as FREE which are basically OEM like calibration data can now be used as really great reference points if you have a desire to learn how to tune on this platform.
In the S55 case you can import the GTS, CS and CSL OTS maps. On the N55 EWG you'll have access to the M2 map and on the S63tu to the Comp Package (600hp) map.
As an example, you can open your Stock Tune first in the editor, do "Save As" to make a copy of it for custom tuning reasons (stock tune itself cannot be edited). Once you create a map, name it as you wish and proceed to the editor to import one of these OTS maps that you find most appropriate/intriguing and go from there. Editor will highlight tables changed in 'red' between your stock and the imported map. If you click on any given 'red' table you can hover on and off the button called 'Original' and see changes in your original (stock) map and if you hover off you'll see the imported changes in bold.
Let us know if any questions at all
Here's a quick vid we put together to demonstrate how its done:
      05-22-2018, 03:35 PM   #2
kenand1988
Drives: 2012 BMW 328i
So..... are you saying we can edit OTS maps now across all engines?
      05-23-2018, 12:21 PM   #3
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Looks like just OEM maps. So if the S55 GTS gives you another 10HP and shift changes, then you can see those values. Only OTS maps they give for free. I don't know if we have any.
bm3, bootmod3
