10-20-2018, 10:47 PM | #1 |
BMW forever!
1389
Rep 2,418
M performance suspension and diffuser installed
So far I have done 3 mods to the car..
1. Installed Michelin 4S tires 2. M Performance Suspension (OEM) 3. M Rear diffuser (OEM) 2 and 3 give the car a fresh look and feel. The rear looks more aggressive and the stance is slightly lowered with minimal wheel/fender gap. Next I am planning to install the black grills. Already got them in my garage.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
10-21-2018, 01:55 AM | #2 |
Rep 145
Drives: 2016 F30 340i
Very nice, what’s the eta on the M2?
10-21-2018, 02:27 AM | #3 |
Rep 2,499
I have a 2014 as well and the M Performance suspension is an absolute must for anyone with the M Sport suspension. I've been waiting for my S001s to wear down before I replace my tires, though.
Did you do the tires before or after the suspension? I'm considering either PSS or PS4S and I'm curious to know your thoughts about the difference in ride quality. |
10-21-2018, 02:43 AM | #4 |
BMW forever!
1389
Rep 2,418
I had both the PSS and PS4S before the suspension install. If you are deciding between the two then I think both are equally good. PSS is a little more stiff and noisier compared to PS4S. You can hardly tell the difference, unless you go to track you will be happy with both.
PS4S is more suitable for daily driving due less noise and more comfy ride but at the same time providing outstanding grip. Also I think steering feels slightly better with PS4S with 38 Psi in front and 39 Psi rear. Try to keep both front and rear pressures close and the car will rotate around corners much better. Yes that M performance suspension totally changes the personality and in my opinion the best mod you can do to the car.
2020 BMW X5
upsidedownfunnel1996.00 |
10-21-2018, 02:48 AM | #5 |
BMW forever!
1389
Rep 2,418
Still waiting to get more info on ETA
2020 BMW X5
10-21-2018, 05:05 AM | #6 |
Rep 878
Did you go for the stock tyre sizes or change them for wider tyres?
10-21-2018, 08:40 AM | #7 |
BMW forever!
1389
Rep 2,418
Just stock tire size.
2020 BMW X5
10-21-2018, 01:32 PM | #8 |
Rep 878
Cheers, my fronts need replacing and I was wondering if I should increase the profile.
