03-27-2020, 09:18 AM | #376 |
Rep 299
Mine on 235 and 255...OEM 437m.
Stick out a bit but no rubbing
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
03-27-2020, 09:32 AM | #377 | |
Rep 1,502
Drives: F36 435xd
Do you have any pictures from behind and down the side to see the poke?
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
03-31-2020, 03:38 PM | #379 |
Stance to make her dance
708
Rep 2,002
Hey guys,
I'm looking for more photos of OEM 437's with 235/35 and 265/30 tires lowered on H&R Sport Springs. I went with those tire sizes already because thats what was readily available at the time, and it was $100 cheaper (otherwise I would have gone 40/35 sidewall). My car is not currently lowered, but I have a set of H&R Sport Springs on hand - I just need to purchase some Bilstein B8's and I should be ready to go. So, if anyone has those tire sizes and is lowered on H&R Sport springs, I'd like to see pics of the setup! Thanks!
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon |
05-23-2020, 10:29 AM | #380 |
Rep 15
I recently purchased the 437M wheels for my 2014 BMW 328i XDrive .
The wheels came directly off an M4 with the OEM Specs 255/35/19 19x9 ET 29 275/35/19. 19x10. ET 40 I understand this will not work with the XDrive system so I decided to square the set and bought 2 more 255/35/19 to match the front My question is, Am I safe with this set up? Not sure how much my offset has changed with moving down the rear size from 275/35/19 down to 255/35/19 . I've noticed my EPS seems to be heavy one second then lighter the next. Is this incompatible with the F30 X-Drive? Notes- Stock suspension Not lowered Any feedback would be greatly appreciated! |
06-12-2020, 03:31 PM | #381 |
Rep 819
Drives: 2021 BMW X3 M
Has anyone with an F30 tried 245/40 and 265/40 with these wheels? I really want to get a 40 sidewall for better ride quality. I know 245/35 and 265/35 confirmed fits with no issues.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
06-13-2020, 02:04 PM | #383 | |
Rep 105
Stupid is as stupid does...
06-14-2020, 09:48 AM | #384 |
Rep 22
Here is my OEM 437Ms with 235/40 and 265/35 Continental ExtremeContacts on H&R sport springs. Love the look and ride!
2012 335i Sport
Bootmod3 stage 2, CSF IC, VRSF CP, VRSF catless DP, H&R sport springs, 437M wheels, S2NHA M Sport brake retrofit |
06-19-2020, 12:23 PM | #385 |
Rep 819
I decided to pull the trigger on this setup after surfing through this thread. I tried to get a couple of pictures from different angles.
Estroil Blue F30 x OEM 437m Wheels x H&R Sport Springs. Tire Sizes: 245/35/19 Fronts and 265/35/19 Rears wrapped in brand new Firestone Firehawk Indy 500's. Alignment: -0.5 degrees of camber up front and -1.5 degrees in the rear. (Within factory specs) If I had to do it again I would definitely put a 245/40 on the front. It would fill in the small gap upfront and I am pretty sure it would clear. The rear is filled in perfectly.
freespirit82.50 mrexcuse33.50 |
06-22-2020, 08:50 PM | #386 |
Rep 741
hello
will 255/35/19 and 275/35/19 rub on a 2016 f36? what if i ran spacers? assuming it did rub. bad idea?
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
06-23-2020, 03:08 PM | #387 | |
F36 GC
143
Rep 259
Michelin Pilot Sport 4s on: 19x9 et 35 front 19x10 et 45 rear Fits perfectly and have had 0 rub on my 2015 F36. That being said I believe the 437s are 19x9 et 29 front and 19x10 et 40 rear. That will make the fronts poke 6mm farther out/farther from the suspension than mine. The rears 5mm farther out/farther from suspension than mine. I dont believe you will rub you just may have a little bit of poke on all 4 corners. |
F36GC_NYC159.50 |
06-23-2020, 09:33 PM | #389 |
Rep 111
06-24-2020, 01:41 AM | #390 |
Rep 36
06-24-2020, 12:29 PM | #391 | |
Rep 741
would you mind posting a pic of your vossen wheels? please
06-24-2020, 06:02 PM | #392 | |
F36 GC
143
Rep 259
This is stock M sport suspension. Last edited by ozymandias435; 06-24-2020 at 06:24 PM.. |
06-29-2020, 09:39 AM | #394 |
Rep 111
Here you go. It looks more aggressive in person.
Edit: Stock height xDrive 235/40 & 265/35 Hankook S1 EVO3 tires Last edited by Horn High Aces; 06-30-2020 at 10:23 AM.. |
06-30-2020, 10:39 AM | #395 |
Rep 1
437m, f30, rims, wheels |
