11-28-2020, 02:38 AM | #155 | |
Rep 415
If I ever go bigger turbo I’d need more fuel than my Dorch stage 1, I’d definitely consider a meth system with this canbus upgrade for a bit more fuel and iat control 🙂 |
11-28-2020, 11:15 AM | #156 |
Rep 1,288
12-03-2020, 03:10 PM | #157 |
Rep 1,288
Man this car is finicky about it's ethanol... was down to a 1/2 tank of E20... I was only supposed to put in 1.05gallons of "E85" but just wanted to see how much I could get a way with... so I put 1.2 gallons in and 6.7 gallons of gas (surprised how accurate the gas gauge is) in the car... I found a beautiful 4 lane wide street under the freeway bridge with no cross traffic,fencing on both sides and all by myself... like a dream...lol..... surprised again I could rip thru all the way of 3rd gear and had more than plenty of room to stop for the next light here in Mexico... well ... the car didn't like it... so gotta drive enough now to drop a gallon or 2 in it.... see graph....
https://datazap.me/u/fastf30/log-160...og=0&data=4-22 P.s. thejeremyman9 ... My torque Nm's are like yours now since I uploaded XHP.... Last edited by FastF30; 12-04-2020 at 01:45 AM.. |
12-10-2020, 10:26 AM | #158 |
Rep 2,653
Any reason this topic has been moved to "Exhaust Modifications"?
12-10-2020, 11:20 AM | #159 |
Rep 7,606
12-10-2020, 12:44 PM | #160 | |
Rep 2,653
12-10-2020, 01:33 PM | #161 | |
Modder of everything I own
147
Rep 491
I was looking at the Dorsch2 but I was not sure if it could support e50 @ 700hp, any thoughts?
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
12-10-2020, 01:38 PM | #162 | |
Rep 7,606
https://f30.bimmerpost.com/forums/sh....php?t=1723999 |
12-10-2020, 01:42 PM | #163 | |
147
Rep 491
12-10-2020, 11:11 PM | #164 |
Rep 1,288
Great video showing comparisons of fuel...
12-11-2020, 01:52 AM | #165 |
Rep 1,288
12-11-2020, 03:35 PM | #166 |
Rep 1,288
Finally got to do some pulls with my new plugs... I'm very very Happy... .... It pulled like a MONSTER! .... I did 2 pulls back to back... one in 3rd gear and one in 4th gear... 3rd gear pulled unbelievable.... never had it pull like that!... My E20 mix is almost perfect... 1/2 gallon more should do it...I also added 8oz Boostane cause timing wasn't so great on a short pull I did earlier... dips in horsepower/ Torque Nms correlates with dips in Fuel pressure...
Old plugs ambient pressure was 15.0... New plugs AP is 14.85... this matters alot IMO... if pressure was exact at 15.0 for both we would see better gains new plugs... I attached logs old/new and HP graph.... both sets of 3rd/4th logs were taken back to back on that day... same exact road both times... Blue is old plugs 4th Gear Red is new plugs 4th Gear Green is old plugs 3rd Gear Orange is new plugs 3rd Gear Old plugs https://datazap.me/u/fastf30/log-160...data=1-4-22-32 https://datazap.me/u/fastf30/log-160...og=0&data=4-22 New plugs https://datazap.me/u/fastf30/log-160...og=0&data=4-21 https://datazap.me/u/fastf30/log-160...og=0&data=4-21 |
12-11-2020, 05:11 PM | #167 | |
Rep 2,653
E20 for me is where it's at with the stock HPFP. Anything over and it crashes. What plugs and GAP did you use?
12-11-2020, 06:56 PM | #168 | |
Rep 1,288
Plugs are NGK 97506.... .022 gap.... there is now a NGK 97506KT which looks like it's an upgraded washer... figures... Boostane really helps a lot... the guys in the video dump a whole 32oz in the tank when they do it... lol... I only did 8oz per tank but if you need more just add it until you get clean timing .... I'd stop 12 oz to be honest if your running 93octane...anything more for this tune better start looking other places.. plugs, coils, etc.... |
12-11-2020, 07:31 PM | #169 | ||
Rep 2,653
12-11-2020, 08:22 PM | #170 | |
Rep 1,288
aaah... what kind of issues... if I was to redo this I'd probably just stick to stock... most of driving is just putting around... don't think it needs it... maybe for track use... seems from old logs to new logs I should probably replace the coils.. #2 always seems to be an issue... Maybe throw meth on it this spring... we'll see how bitcoin works out first...lol... |
12-11-2020, 08:37 PM | #171 | ||
Rep 2,653
12-11-2020, 08:52 PM | #172 |
Rep 1,288
Wow... never heard that one... hopefully that was a one off... I have to say my car runs awesome ... handles awesome ... can't complain.. just have to get that steering rack thruster piece replaced and that's basically it...
12-11-2020, 09:01 PM | #173 | |
Rep 2,653
12-26-2020, 07:59 PM | #174 |
Rep 2,653
Guys quick question... I have to bring my car in for a valve cover gasket replacement under warranty and wanted to flash BM3 back to stock and lock. Problem is I have E20 in the tank (a little less than 3/4 tank). Can I flash back to stock and lock with E20 in the tank without any detrimental issues?
12-26-2020, 08:04 PM | #175 | |
Rep 1,105
XxThe_RemedyXx967.00 |
12-26-2020, 08:06 PM | #176 | ||
Rep 2,653
