12-01-2020, 01:54 AM | #1 |
Rep 2,357
Going lean post-rev
Hello friends
I need your help here. My car consistently goes lean after revving it in P/N. Would someone care to check their car to see if this is "just the way a N55 behave"? Happens both in Stg0 and OTS/custom maps. https://datazap.me/u/harkes/stg0-goi...rk=137-282-452
(A Dane in China) |
12-01-2020, 08:05 AM | #2 | |
1296
Rep 3,532
12-01-2020, 11:24 AM | #3 |
Rep 7,597
Yes, normal. Just think of it as the engine being under decel (even though you are in neutral) - all modern cars will essentially shut off or dramatically decrease fuel injection during these periods, whether you are in gear engine braking or just in neutral
12-01-2020, 09:12 PM | #4 | |
Rep 2,357
Try open the log I attached then you will understand.
(A Dane in China) |
12-01-2020, 09:48 PM | #5 |
Rep 7,597
I did. The negative fuel trims look like they are just bringing the AFRs closer to stoich. I thought by AFR spike you were talking about when it goes over 20 right after the rev; that's what i was decribing.
12-02-2020, 03:05 AM | #6 | ||
1296
Rep 3,532
12-02-2020, 08:04 AM | #7 | |||
Rep 2,357
I am very interested in seeing a log with some revs if anyone could provide, thanks.
(A Dane in China) |
12-02-2020, 11:26 AM | #8 |
Rep 7,597
12-02-2020, 09:19 PM | #9 |
Rep 2,357
Happening on stock map also so not tune related. Even running stock intake and MAF is connected. Might try disconnecting MAF...
(A Dane in China) |
12-03-2020, 07:45 AM | #10 | |
Rep 3,679
I know you've expressed that you feel otherwise but I'll put another vote in for this being normal. Modern cars nearly or do shut down fuel injection on decel to save gas.
n55david1295.50 |
12-03-2020, 08:07 PM | #11 | |
Rep 2,357
Decel -> Idle is resumed (closed loop) -> STFT goes negative and engine RPM start dropping (down to 550) -> AFR climb to 16 -> STFT goes positive to correct I know very well that injectors are shut off during decel (unless needed for burbles).
(A Dane in China) |
12-04-2020, 08:09 AM | #12 | |
Rep 3,679
EDIT: didn't realize how extensively modified your car was. Maybe don't flash to stock and instead seek advice from your tuner.
12-04-2020, 11:44 PM | #13 | |
Rep 2,357
(A Dane in China) Last edited by harkes; 12-04-2020 at 11:51 PM.. |
12-07-2020, 09:14 PM | #14 |
Rep 931
Its normal after shifts to have that, I see it on every log but will you ever get your car sorted out already? Its been forever with issues it seems. Time for an upgrade?
12-07-2020, 10:05 PM | #16 | |
Rep 1,127
n55david1295.50 |
