08-20-2019, 03:29 PM | #1013 |
Rep 43
This might have been answered already, sorry but if I flash this and I have to take my car in to the dealer . I know I can flash this back to stock but can the dealer know?
08-20-2019, 07:30 PM | #1015 |
Rep 153
08-21-2019, 08:51 PM | #1016 |
Rep 1,133
So I raced a 540i with my 340i stage 1 today. He had no chance!!! About 2 car lengths in a little less than a 1/4 mile. Next week I'll have a dp installed and will go to stage 2 😱
motorcitybmw4.50 |
08-23-2019, 09:18 PM | #1017 |
Cheapskate
4464
Rep 4,995
Yep I'm switching to Stage 1 E30 after my next dealer service. It's just too easy to squeeze extra juice out of these cars.
08-25-2019, 11:25 AM | #1019 |
Cheapskate
4464
Rep 4,995
I've never driven a platform where the stage 1 to stage 2 jump was mind blowing. I'm not sold it would be any different on this platform tbh, but it seems for once they are actually increasing boost and timing. Most tunes just account for increased airflow so power comes on sooner and stays up for longer. You'd need to race them side by side to get a true comparison.
08-25-2019, 06:01 PM | #1020 | |
Rep 1,133
08-26-2019, 06:03 AM | #1021 |
Cheapskate
4464
Rep 4,995
That's funny because I didn't feel a big difference on my GLI lol. I had to race my friends Stage 1 GTI to see the difference. Down low it was the same, but it gave it more top end. Even on their dyno graphs it didn't show a huge difference, maybe 5-10whp across the curve. But I was in a mk5 with a gen1 tsi...if you were in a mk7 then the difference may have been more.
08-26-2019, 07:39 AM | #1022 | |
Rep 1,133
08-26-2019, 08:05 AM | #1023 | |
Cheapskate
4464
Rep 4,995
But on our cars, the BM3 tune actually adds 2-3psi so I'd expect it to be somewhat noticeable. Personally I'm trying out Stage 1 e30 first to see if I really notice anything. A fuel change is easier for me than buying and installing additional hardware. Less noticeable at the dealer level too. If I don't feel a big improvement, I can just switch back to 93 until proper fuel upgrades and E85 support is available. |
08-26-2019, 08:22 AM | #1024 |
Rep 5,316
Drives: G80 M3 6MT
Anyone notice a loud air sucking or escaping noise with BM3 Stage 1 and a DP? I feel like something is leaking to be hearing this sound, but I don't see smell anything... So just wondering if its a combination of the extra boost and the DP.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-26-2019, 10:37 AM | #1025 | |
Cheapskate
4464
Rep 4,995
If you spray some soapy water on the connections while the car is cold and start it up, you'll see if there's a leak somewhere. check around the turbo and the O2 sensor for leaks. |
08-26-2019, 07:11 PM | #1026 |
Rep 4,923
If its leaking, you will typically hear a ticking/rattle sound at the turbo flange when the engine is running.
With my Active Autowerke exhaust, it's a huge "whoosh!" sound at WOT. That became more pronounced with the DP. |
08-27-2019, 09:02 AM | #1027 | |
Rep 336
08-27-2019, 11:26 AM | #1028 |
Cheapskate
4464
Rep 4,995
Nope. I experienced the same thing with Shell 93 and even with the bit of e85 added. Regapping my stock plugs seemed to help significantly. I'm switching to the E30 map after my dealer service on Friday so I'm not as worried about it anymore.
08-28-2019, 03:22 PM | #1029 |
Rep 1,239
Just flashed my car to stage 2 93 and havnt even started it yet and I have a drivetrain error, I have pushed the dme reset button but that’s not clearing it !?
Any ideas ? |
08-28-2019, 03:37 PM | #1030 |
Rep 1,363
Will the car start? If not, then recode the DME.
If the car runs, then just restart it. First time I flashed, I got a drive train error 20 feet after pulling out of my driveway. Re-started car and it went away. Same thing after flashing the E30 map. Subsequent flashes back to stock and then back to Stage 2 never gave any errors.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
08-28-2019, 03:55 PM | #1031 |
Rep 1,239
It didn’t like getting started, said transmission was hot and to stop and put it into P
Did an online recode and it’s sorted it out! How does my log look? http://www.bootmod3.net/log?id=5d670b06c090c6114e49a464 Last edited by jackstrath; 08-28-2019 at 06:33 PM.. |
08-28-2019, 07:41 PM | #1032 | |
Rep 1,449
You're also getting knock and the timing looks low. What kinda gas are you using? Try the Stage 2 91 map or the Stage 1 93 map if you have 93 available. Edit: I have slight throttle closure as well. Last edited by G.Newt; 08-28-2019 at 09:01 PM.. |
08-29-2019, 04:43 AM | #1033 | |
Rep 1,239
Yeh i seen the throttle closure, but i have seen alot of logs with similar throttle closure in that area, boost control i think as the boost spikes there, did see the 2 knock counts, Im using shell vpower should be 99Ron, i have only done 30 miles since the flash do you think it could just be taking a bit of adjustment ? |
08-29-2019, 01:49 PM | #1034 |
Rep 1,239
Clear Pull today knock wise -
http://www.bootmod3.net/log?id=5d67e34ec090c6114e49a61b Then got another knock count - Done 60 miles now. http://www.bootmod3.net/log?id=5d67e35bc090c6114e49a623 |
bm3, bootmod3 |
