09-09-2018, 06:34 PM | #1 |
Rep 2,319
Oil temperature not getting as hot as usual
The dealer just replaced my valve cover gasket recently so I'm not sure if they might have messed with something that's causing the following:
Before the normal oil temperature for my car would get up to around 240-250 degrees (halfway mark on the gauge). Now when I drive in sport+ the temperature only indicates about 205-210 (about 1/4 mark on the gauge) no matter how much I beat on it. And when I come to a light it begins to drop to around 200. The weird part is when I switch back to comfort mode the temperature almost immediately begins to rise and gets back to around around the halfway mark. Not sure if this should be a cause for concern. I'm running bootmod3 tune and other bolt ons. |
09-09-2018, 07:20 PM | #2 | |
Rep 134
2016 435i xdrive Gran Coupé
2011 E82 1M Custom Frozen Brilliant White 2006 E60 M5 Alpine white SMG DELETE 6MT swap. Gone : 135i 2008 | Gone : 2008 535i Touring| |
09-09-2018, 07:25 PM | #3 | |
Rep 1,502
Usually toodling around town or long boring cruise-control slogs on the highway have me in the efficiency range of 240-245F. The last time I went bombing through the mountains, uphill at 80-100mph, frequently flooring the gas to pass left lane hogs on the right, ignoring signs saying “turn off a/c to prevent overheating”, I was down around 200F. |
09-09-2018, 07:40 PM | #4 | ||
Rep 2,319
Only thing was them replacing the valve cover gasket and replacing some hose that broke. Quote:
09-09-2018, 10:05 PM | #7 |
Rep 4,724
I have read the engine will run at cooler temps when pushing it hard. It then runs at higher temps in comfort and eco for better fuel efficiency.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
09-10-2018, 11:41 AM | #8 |
Rep 2,499
The engine oil should be running at least at 220 degress. If not, water in your oil will not be able to burn off. The normal operating temperature for our engines is about 250F and should not be significantly below that when fully warmed up. If your cooling system is working properly, you should always be very close to that operating temperature.
My car gets up to 250 fairly quickly and almost never goes above or below 240 no matter how hard or easy I drive it. |
09-10-2018, 12:13 PM | #9 | |
Rep 2,319
09-10-2018, 12:52 PM | #11 |
Rep 878
I’ve never noticed any difference in the temp in different modes?
09-10-2018, 09:27 PM | #12 |
Rep 1,502
If you google “BMW N55 engine manual” you’ll find an informative document with the following info. The Economy mode temp sounds a bit low as I think mine runs in the 240 range, but I’d have to go look at my gauge to double-check. IIRC the manual is from the E90 era so it’s quite possible there’ve been updates to the F3x. [edit: just realized the temps quoted below are probably coolant and not oil; coolant temps are lower than oil temps]
As I mentioned earlier, I did see a significant drop in temp when hammering the car uphill through some mountains in sport mode. Also not sure if it matters, but I do have an m-sport which IIRC has an extra radiator of some sort (oil cooler, I think). "The engine management sets a higher temperature (108°C) when, based on vehicle operation, the engine control unit detects ”Economy” mode. The engine is operated with relatively low fuel requirements in this temperature range. The internal engine friction is reduced at higher temperatures. The increase in temperature therefore results in low fuel consumption in the low load range. The driver wishes to utilize the optimum power developed by the engine in “High and control with characteristic map thermostat” mode. For this purpose, the temperature in the cylinder head is reduced to 90°C. This temperature reduction promotes improved volumetric efficiency, thus resulting in an increased engine torque. Adapted to the relevant driving situation, the engine control unit can now regulate a defined operating range. In this way it is possible to influence the fuel consumption and power output through the cooling system." The engine control unit regulates the following temperature ranges: • 108°C/226°F = Economy mode • 104°C/219°F = Normal mode • 95°C/203°F = High mode • 90°C/194°F = High mode and control with characteristic map thermostat System Protection If the coolant or the engine oil overheat during operation, certain vehicle functions are influenced to the effect that more energy is available to the engine cooling system. These measures are divided over two operating modes: • Component protection - Coolant temperature between 117°C/242°F and 124°C/255°F - Engine oil temperature between 150°C/300°F and 157°C/314°F - Result: The output of the air conditioning system (up to 100%) and of the engine is reduced • Emergency - Coolant temperature between 125°C/257°F and 129°C/264°F - Engine oil temperature between 158°C/316°F and 163°C/325°F - Result: The power output of the engine is reduced (up to 90%) Last edited by chiefneil; 09-11-2018 at 08:06 AM.. |
akgambino271.50 |
09-11-2018, 07:32 AM | #13 |
Rep 775
What about those aftermarket thermostats? One had a spring so temps got to 210 fairly quickly and stayed there (generally).
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
09-11-2018, 08:01 AM | #14 |
Rep 16,082
BMW thermostats are electrically controlled. That's why they cost $50, not $5. Being controlled by the ECM they allow faster warm up than passive spring operated thermostats. It also allows the coolant temperature to be varied as required, which a passive themostat can't do.
BMWM5NYC496.00 |
09-19-2018, 11:38 AM | #15 |
Rep 21
This is after driving my 40 mile commute in sport mode the whole way.
Picture wouldn't load, but the needle was on the notch halfway between 160 and 250F. |
09-19-2018, 12:13 PM | #16 |
Rep 2,319
09-19-2018, 03:36 PM | #17 | |
Rep 2,499
09-20-2018, 09:45 AM | #18 |
Rep 943
Drives: F30 328i Msport
Mine has never gotten to 250, ever. Always around 200 or below, brought this up with mu SA and was told its normal. Dont know if i should believe them.
09-20-2018, 09:57 AM | #19 |
Rep 937
I dont know the exact number, but mine is always pointing directly up... and a little below whatever number that is at the top, i think it's 250. I live in Florida, but during the winter, it takes longer to get to that spot, and sometimes it doesnt get there on my commute.
Hi
