BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Oil Drain Plug
      09-18-2018, 02:58 PM   #1
joshhwhaa
Drives: F30 328i
Oil Drain Plug
I believe some have a plastic plug, while others have a metal plug. Is it possible to replace the plastic drain plug with a metal one?
Thanks
joshh-o0o-whaaa
      09-18-2018, 03:05 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The plastic plug is used on plastic oil pans, so that it won't strip the threads on the pan. They're not interchangeable. I believe only XDrive N20 have metal oil pans.
      09-18-2018, 03:06 PM   #3
joshhwhaa
Drives: F30 328i
I see. I'm getting ready to give the car an oil change and just wanted to know prior to actually getting underneath the car lol.
Thanks man
joshh-o0o-whaaa
      09-18-2018, 04:12 PM   #4
bimmer456
Drives: 340i
The oil change kit should include the drain plug. The filter should come with new gaskets that you apply oil to and install on the filter before installing the filter.
      09-18-2018, 04:21 PM   #5
Billfitz
Billfitz's Avatar
Depends on the filter. If you have a plastic pan and get the right one it will contain a new plug. If you have a metal pan and get the right one it will have a new washer for the metal plug. Get the wrong one and you won't have what you need.
      09-18-2018, 06:20 PM   #6
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
It would help to know what model car you have.
      09-18-2018, 06:21 PM   #7
joshhwhaa
Drives: F30 328i
2015 F30 328i.
joshh-o0o-whaaa
      09-18-2018, 06:39 PM   #8
XxThe_RemedyXx
967
2015 F30 328i.
xDrive?
      09-18-2018, 06:40 PM   #9
joshhwhaa
Drives: F30 328i
2015 F30 328i.
xDrive?
Rear Wheel Drive.
joshh-o0o-whaaa
      09-18-2018, 06:59 PM   #10
XxThe_RemedyXx
967
2015 F30 328i.
xDrive?
Rear Wheel Drive.
If I'm not mistaken RWD 328i's get new plastic plugs with oil changes. AWD vehicles get new crush washers and reuse plugs:
https://www.autopartsway.com/part.cf...roc0tkqavd-bwe
